| 0000921 | Draft | Bug | public | 2012-12-20 16:06 | 2013-10-18 19:22 |
| Reporter | ts468 | Assigned To | yorik | ||
| Summary | 0000921: Upgrading wire to face deletes object | ||||
| Description | Upgrading the lines in the attached file to a wire works, subsequent upgrade to a face deletes the object. Guess for the cause of the problem: The wire defines a clear inside and a clear outside, but not all inside areas are connected. Also, some points on the wire are shared by more than two edges/lines. Idea: Hatching the same structure with e.g. LibreCAD works fine, and maybe its algorithm can be used to convert the wire into a face as well? Many thanks in advance for your efforts!! | ||||
| Additional Information | OS: Debian GNU/Linux testing (wheezy) Platform: 64-bit Version: 0.13.1779 (Git) Branch: master Hash: 480f28032279505f2399fe08ee41a32228026c0f Python version: 2.7.3rc2 Qt version: 4.8.2 Coin version: 3.1.3 SoQt version: 1.5.0 OCC version: 6.5.2 | ||||
2012-12-20 16:06
I think thats one for you Yorik |
That's a very complex case... The lines form a wire that overlaps itself several times. I think it is (at least at this moment) much to ask that the draft module would be so intelligent as to sort out what to do with that... LibreCAD has another purpose, which is to find an area enclosed by boundaries, which would be of little use here. I'll have a look if the OCC wire healing stuff can be of any use here, but if not, I'm afraid there will be little I can do at the moment. Anyway in such a case, I think it is easy to manually select the segments and form separate faces one by one... |
More test cases: http://forum.freecad.org/viewtopic.php?f=3&t=3527 |
I committed a little fix already (commit 60ccb19) that at least doesn't make the selected object disappear if the face cannot be formed, but this problem is still not solved... |
Fixed with commit e18fb98 |
| 2012-12-20 16:06 | ts468 | New Issue | |
| 2012-12-20 16:06 | ts468 | File Added: test2.dxf | |
| 2012-12-20 18:34 |
Status | new => assigned |
| 2012-12-20 18:34 |
Assigned To | => Jriegel |
| 2012-12-20 18:34 |
Assigned To | Jriegel => yorik |
| 2012-12-20 18:34 |
Note Added: 0002684 | |
| 2012-12-20 22:20 | yorik | Note Added: 0002731 | |
| 2012-12-20 22:26 | yorik | Severity | major => minor |
| 2013-02-04 13:31 | yorik | Note Added: 0002879 | |
| 2013-02-04 19:19 | yorik | Note Added: 0002881 | |
| 2013-02-04 19:22 | yorik | Relationship added | child of 0000893 |
| 2013-10-18 19:22 | yorik | Note Added: 0003770 | |
| 2013-10-18 19:22 | yorik | Status | assigned => closed |
| 2013-10-18 19:22 | yorik | Resolution | open => fixed |
| 2013-10-18 19:22 | yorik | Fixed in Version | => 0.14 |
