| 0000893 | Draft | Bug | public | 2012-11-28 22:38 | 2017-03-27 08:30 |
| Reporter | more10 | Assigned To | yorik | ||
| Summary | 0000893: Fail to upgrade wire to face in drafting module | ||||
| Description | In draft module the working plane is set to a surface not aligned to any axis. Four lines are constructed using snap when possible. The lines are sucessfully upgraded to a wire (Found several edges: wiring them). The wire however cannot be upgraded to a face (One wire is not planar, upgrade not done). | ||||
| Additional Information | Revision 1694 on a 32 bit ubuntu 12.04 running in vmware workstation 8.0.5 | ||||
Apparently the message says the cause of the problem... The vertices of the wire are not on a same plane, so the wire cannot be turned into a face. If you think this is wrong, and all the vertices are on the same plane, please upload the file so I can check what is wrong... |
Well all vertices are constructed on a set working plane in draft module. So they should be on the same plane. Ill see if I can reproduce the problem in a macro. |
2012-11-29 00:16
Uploaded drawing file. It has a wire constructed as below. In order to reproduce: "Set to rear view". Choose "Draft". Mark face of "Baffle". Set working plane. Create the 4 vertices. Upgrade, upgrade. |
Hm there is indeed some problem, probably related to precision... OCC doesn't consider the wire planar, so it cannot make a face. I'll investigate... |
Fixed in e18fb98 Used another more robust method for creating faces |
| 2012-11-28 22:38 | more10 | New Issue | |
| 2012-11-28 23:45 | yorik | Note Added: 0002592 | |
| 2012-11-28 23:45 | yorik | Status | new => assigned |
| 2012-11-28 23:45 | yorik | Assigned To | => yorik |
| 2012-11-28 23:49 | yorik | Status | assigned => feedback |
| 2012-11-29 00:00 | more10 | Note Added: 0002595 | |
| 2012-11-29 00:16 | more10 | File Added: bug.fcstd | |
| 2012-11-29 00:22 | more10 | Note Added: 0002596 | |
| 2012-11-29 20:16 | yorik | Relationship added | parent of 0000891 |
| 2012-11-29 20:16 | yorik | Status | feedback => assigned |
| 2012-11-29 20:17 | yorik | Note Added: 0002602 | |
| 2012-12-05 13:50 | yorik | Project | FreeCAD => Draft |
| 2012-12-20 22:27 | yorik | Severity | major => minor |
| 2013-02-04 19:22 | yorik | Relationship added | parent of 0000921 |
| 2013-10-18 19:21 | yorik | Note Added: 0003769 | |
| 2013-10-18 19:21 | yorik | Status | assigned => closed |
| 2013-10-18 19:21 | yorik | Resolution | open => fixed |
| 2013-10-18 19:21 | yorik | Fixed in Version | => 0.14 |
| 2017-03-27 08:30 | Kunda1 | Changeset attached | => FreeCAD master e18fb989 |
