| 0000939 | FreeCAD | Bug | public | 2013-01-02 11:10 | 2017-03-27 08:33 |
| Reporter | ghia | Assigned To | |||
| Summary | 0000939: Pressing Escape while pivoting a box crashes | ||||
| Description | Create a box from the Part workbench Double click Box in the treeview The 3D circles and arrow crosses for manipulating the box appears arround the box Middle mouse button click and hold can drag the box while moving Middle + left mouse button click and hold can rotate the box while moving Left mouse button click and hold on a face can pivot the shape (around the origin?) So far so good Repeat the last operation (Left mouse button click and hold on a face to pivot) and press ESCape on the keybord, while pivoting and the mousekey is hold down. Result is that the program crashes (windows 7) | ||||
| Additional Information | Why did I push Escape? In other drawing programs, when you accidential move an object or you regret the move, you press Escape and the objects position is restored to its start position. It is a kind of implicitit undo. In FreeCad the Escape has no particular function in this respect. When pressing Escape while doing the drag or rotation, this closes the 'edit mode' and the 3d circles and arrow crosses disappear, while the object can be further dragged or rotated as long as the mouse is hold and moved. Only in the case of pivoting something bad happens. | ||||
| 2013-01-02 11:10 | ghia | New Issue | |
| 2013-01-03 14:50 | wmayer | Note Added: 0002790 | |
| 2013-01-03 14:50 | wmayer | Status | new => closed |
| 2013-01-03 14:50 | wmayer | Resolution | open => fixed |
| 2013-01-03 14:50 | wmayer | Fixed in Version | => 0.13 |
| 2017-03-27 08:33 | Kunda1 | Changeset attached | => FreeCAD releases ef1190bf |
