| 0000941 | FreeCAD | Bug | public | 2013-01-04 13:02 | 2017-01-15 02:08 |
| Reporter | plata1234 | Assigned To | wmayer | ||
| Summary | 0000941: Zoom with scroll doesnt work | ||||
| Description | Freecad 0.13 Build 1811 Win 32: Zoom with scroll doesnt work anymore | ||||
I've downloaded this version from SF and cannot reproduce the behaviour you described. Which navigation style do you use? |
The bug occurs at all navigation styles only when i loaded a .stl file (Laurana50k.stl - a Meshlab sample). With normal drawing everything is fine. |
....Interesting: After changing preferences and restarting the program everything works normal. Si i don't think that this behavior is reproducable... |
Hm, I'll set this to status "Resolved". Feel free to open again if you can repeat it. |
| 2013-01-04 13:02 | plata1234 | New Issue | |
| 2013-01-04 14:02 | wmayer | Note Added: 0002793 | |
| 2013-01-04 14:12 | plata1234 | Note Added: 0002794 | |
| 2013-01-04 14:24 | plata1234 | Note Added: 0002795 | |
| 2013-01-04 14:27 | plata1234 | Note Added: 0002796 | |
| 2013-01-05 09:31 | wmayer | Note Added: 0002798 | |
| 2013-01-05 09:32 | wmayer | Status | new => resolved |
| 2013-01-05 09:32 | wmayer | Resolution | open => no change required |
| 2013-01-05 09:32 | wmayer | Assigned To | => wmayer |
| 2013-01-23 04:57 | plata1234 | Tag Attached: I found out that this behavior only occurs when one tries to open an stl file fom the link in the st | |
| 2013-05-14 12:33 | wmayer | Status | resolved => closed |
| 2013-05-14 12:33 | wmayer | Fixed in Version | => 0.14 |
| 2017-01-15 02:08 | Kunda1 | Tag Detached: I found out that this behavior only occurs when one tries to open an stl file fom the link in the st |
