| 0000962 | FreeCAD | Bug | public | 2013-01-19 23:15 | 2017-03-27 08:32 |
| Reporter | vik | Assigned To | yorik | ||
| Summary | 0000962: Attempting to import an SVG file fails with "invalid literal for int() with base 16" | ||||
| Description | © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## matplotlib not found, Plot module will be disabled pycollada not found, collada support will be disabled. processing element 1: svg existing group transform: [] name: svg3066 done processing element 1 processing element 2: metadata existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] name: metadata3091 done processing element 2 processing element 3: rdf:RDF existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] done processing element 3 processing element 4: cc:Work existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] done processing element 4 processing element 5: dc:format existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] done processing element 5 processing element 6: dc:type existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] done processing element 6 processing element 7: dc:title existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] done processing element 7 processing element 8: path existing group transform: [Matrix ((0.282222,0,0,0),(0,0.282222,0,0),(0,0,1,0),(0,0,0,1))] Exception (Sun Jan 20 13:07:40 2013): invalid literal for int() with base 16: '' | ||||
| Additional Information | Attepmting to import the SVG causes the above error. SVG De novo creation done in Inkscape. It's meant to be all paths. It's the box for a Roofl RepRap and is GPLv3'd :) Vik :v) PS If you miss the category when entering bug reports, then hit back arrow after the error message, you lose all the helpful Additional Information that you entered. | ||||
2013-01-19 23:15
That's funny, here is a type of SVG file I had never seen before, where the points of a path are also separated by commas. I'll try to fix that. Can I ask with what application was that file created? |
2013-01-20 18:23
i did not yet test the fix |
The file was created with inkscape 0.48.3.1-1ubuntu1 The shapes were made mostly by converting objects to paths and boolean operations on the same. Vik :v) |
i tested the fix: git://github.com/5263/FreeCAD.git svgcolorfix |
Fixed in 5e46bea. Thanks shoogen! |
| 2013-01-19 23:15 | vik | New Issue | |
| 2013-01-19 23:15 | vik | File Added: attempted_import.svg | |
| 2013-01-20 14:56 | yorik | Note Added: 0002859 | |
| 2013-01-20 14:56 | yorik | Status | new => assigned |
| 2013-01-20 14:56 | yorik | Assigned To | => yorik |
| 2013-01-20 18:23 | shoogen | File Added: svgcolors.diff | |
| 2013-01-20 18:24 | shoogen | Note Added: 0002863 | |
| 2013-01-20 20:46 | vik | Note Added: 0002864 | |
| 2013-01-21 09:42 | shoogen | Note Added: 0002865 | |
| 2013-01-21 11:48 | yorik | Note Added: 0002866 | |
| 2013-01-21 11:48 | yorik | Status | assigned => closed |
| 2013-01-21 11:48 | yorik | Resolution | open => fixed |
| 2013-01-21 11:48 | yorik | Fixed in Version | => 0.13 |
| 2017-03-27 08:32 | Kunda1 | Changeset attached | => FreeCAD releases c3b11b53 |
