| 0001267 | GCS | Bug | public | 2013-10-06 20:14 | 2018-06-03 05:59 |
| Reporter | jmvillar | Assigned To | chrisb | ||
| Summary | 0001267: Sketcher error message "the LevenbergMarquardt solver succeeded where the DogLeg solver had failed" | ||||
| Description | this is the message I got Important: the LevenbergMarquardt solver succeeded where the DogLeg solver had failed. If you see this message please report so I do it. | ||||
| Additional Information | message apears when I was moving with the mouse a point of the leading edge of the sketch named "perfil ala". this is same output info... .... Sel : Add Selection "pp2.Sketch003003002.Vertex5(11.830063,92.289330,0.005000)" Sel : Add Selection "pp2.Sketch003003002.Vertex14(141.830063,0.000000,0.005000)" Sel : Clear selection Sel : Add Selection "pp2.Sketch003003002.Constraint17(278.969086,65.229179,0.002000)" double click constraint:17 Sel : Clear selection Important: the LevenbergMarquardt solver succeeded where the DogLeg solver had failed. If you see this message please report a way of reproducing this result at https://sourceforge.net/apps/mantisbt/free-cad/main_page.php Important: the LevenbergMarquardt solver succeeded where the DogLeg solver had failed. If you see this message please report a way of reproducing this result at https://sourceforge.net/apps/mantisbt/free-cad/main_page.php Sel : Clear selection Hide main window | ||||
| Tags | Solver | ||||
thanks for your report, however I am not able to reproduce this situation by dragging points of the leading edge randomly. |
OS: Ubuntu 14.04.2 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.16.5036 (Git) Build type: Release Branch: master Hash: a12f700aa27792f0ecdf09c5ee190d0bf88b0e81 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 I just got the same message, and it is easily repeatable: http://forum.freecadweb.org/viewtopic.php?f=3&t=11170&p=90266#p90266 I'll attach the file (D9.fcstd) here just as a precaution in case, for some reason, it gets deleted from the forum. |
Also see bug 0002172 and 0002363 |
Updated summary, unassigned issue from logari81 since he's no longer active. -NC |
@bejant Thanks, I finally managed to reproduce this one following these instructions: https://forum.freecadweb.org/viewtopic.php?f=3&t=11170&p=230451#p230451 |
https://github.com/FreeCAD/FreeCAD/pull/1429 |
| 2013-10-06 20:14 | jmvillar | New Issue | |
| 2013-10-06 20:14 | jmvillar | File Added: pp3.FCStd | |
| 2013-10-07 12:25 | wmayer | Status | new => assigned |
| 2013-10-07 12:25 | wmayer | Assigned To | => logari81 |
| 2013-11-04 13:38 | yorik | File Deleted: pp3.FCStd | |
| 2013-11-04 13:38 | yorik | File Added: pp3.FCStd | |
| 2014-02-08 07:44 | logari81 | Note Added: 0004168 | |
| 2015-06-03 16:45 | bejant | Note Added: 0006188 | |
| 2015-06-03 21:18 | bejant | Note Edited: 0006188 | |
| 2015-06-03 21:20 | bejant | File Added: D9.fcstd | |
| 2015-06-03 21:21 | bejant | Note Edited: 0006188 | |
| 2015-06-26 20:38 | bejant | Note Added: 0006233 | |
| 2015-12-12 19:33 | bejant | Note Edited: 0006233 | |
| 2017-01-11 17:35 | Kunda1 | Relationship added | related to 0002172 |
| 2017-01-11 17:36 | Kunda1 | Relationship added | related to 0002363 |
| 2017-01-11 17:36 | Kunda1 | Note Edited: 0006233 | |
| 2017-01-12 14:41 | Kunda1 | Tag Attached: Solver | |
| 2017-04-01 16:23 | normandc | Assigned To | logari81 => |
| 2017-04-01 16:23 | normandc | Summary | I got a message for developers. working with sketcher module on windows xp => Sketcher error message "the LevenbergMarquardt solver succeeded where the DogLeg solver had failed" |
| 2017-04-01 16:23 | normandc | Note Added: 0008743 | |
| 2017-05-02 21:17 | Kunda1 | Status | assigned => confirmed |
| 2017-05-09 12:27 | Kunda1 | Relationship added | related to 0001865 |
| 2017-12-12 15:40 | abdullah | Category | Feature => Bug |
| 2018-04-27 09:32 | abdullah | Note Added: 0011201 | |
| 2018-06-03 05:59 | chrisb | Assigned To | => chrisb |
| 2018-06-03 05:59 | chrisb | Status | confirmed => closed |
| 2018-06-03 05:59 | chrisb | Resolution | open => fixed |
| 2018-06-03 05:59 | chrisb | Note Added: 0011343 |
