| 0001865 | GCS | Bug | public | 2014-12-19 10:31 | 2018-06-09 09:09 |
| Reporter | s-light | Assigned To | abdullah | ||
| Priority | low | Severity | minor | Reproducibility | have not tried |
| Platform | DELL Latitude E6510 | OS | Windows 7 Proffessional 64Bit | ||
| Summary | 0001865: Sketch Solving problems (LevenbergMarquardt) | ||||
| Description | Had some trouble with a sketch and solving. in the ReportView i got the following: .... Sel : Clear selection Sel : Add Selection "Unnamed.Sketch003.Vertex20(45.000000,20.000000,6.005000)" Sel : Add Selection "Unnamed.Sketch003.Vertex36(-62.956375,18.612762,6.005000)" Important: the LevenbergMarquardt solver succeeded where the DogLeg solver had failed. If you see this message please report a way of reproducing this result at http://www.freecadweb.org/tracker/main_page.php Important: the LevenbergMarquardt solver succeeded where the DogLeg solver had failed. If you see this message please report a way of reproducing this result at http://www.freecadweb.org/tracker/main_page.php Sel : Clear selection Active view is Netzteil_Halter : 1 so i register and reported this problem. file is attached i hope that helps. | ||||
| Tags | Solver | ||||
| related to | 0001223 | closed | chrisb | Dimensional constraint - Unknown C++ exception (LevenbergMarquardt) |
| related to | 0001267 | closed | chrisb | Sketcher error message "the LevenbergMarquardt solver succeeded where the DogLeg solver had failed" |
| related to | 0002363 | closed | chrisb | the LevenbergMarquardt solver succeeded where the DogLeg solver had failed |
The sketch seems to be overconstrained. It is common to see such sketches behave badly or not function at all. Please seek assistance on the forum. |
@DeepSOIC does this issue merit a ticket? |
With current master it was relatively easy to fix this one. The improved redundancy detection helped a lot removing all that was not necessary. The DoF finder pointed to what needed to be constraint. I regard the issues as fixed. |
Fixed. |
| 2014-12-19 10:31 | s-light | New Issue | |
| 2014-12-19 10:31 | s-light | File Added: Netzteil_Halter.FCStd | |
| 2014-12-19 12:15 | shoogen | Tag Attached: Solver | |
| 2014-12-19 12:23 | shoogen | Assigned To | => logari81 |
| 2014-12-19 12:23 | shoogen | Status | new => assigned |
| 2014-12-20 00:44 | DeepSOIC | Note Added: 0005412 | |
| 2014-12-29 00:28 | wmayer | Relationship added | related to 0001223 |
| 2015-01-02 18:27 | normandc | Project | PartDesign => Sketcher |
| 2017-04-02 08:56 | kkremitzki | Assigned To | logari81 => |
| 2017-04-02 08:56 | kkremitzki | Status | assigned => new |
| 2017-05-02 21:24 | Kunda1 | Note Added: 0008858 | |
| 2017-05-09 12:27 | Kunda1 | Relationship added | related to 0001267 |
| 2017-05-09 12:28 | Kunda1 | Relationship added | related to 0002363 |
| 2017-05-09 12:35 | Kunda1 | Summary | Sketch Solving problems => Sketch Solving problems (LevenbergMarquardt) |
| 2018-06-09 09:08 | abdullah | File Added: Netzteil_Halter_fixed.fcstd | |
| 2018-06-09 09:08 | abdullah | Note Added: 0011377 | |
| 2018-06-09 09:09 | abdullah | Assigned To | => abdullah |
| 2018-06-09 09:09 | abdullah | Status | new => resolved |
| 2018-06-09 09:09 | abdullah | Resolution | open => fixed |
| 2018-06-09 09:09 | abdullah | Note Added: 0011378 | |
| 2018-06-09 09:09 | abdullah | Status | resolved => closed |
