| 0001491 | File formats | Feature | public | 2014-03-25 14:36 | 2019-07-30 22:40 |
| Reporter | barleyman | Assigned To | |||
| Platform | PC | OS | Windows | OS Version | 7 x64 |
| Summary | 0001491: IDF import fails on spaces and underscores on filename | ||||
| Description | Opening IDF files (.EMN) fails if there's a space in the filename | ||||
| Steps To Reproduce | From the FILE menu, select OPEN and select an *.emn file which has spaces in the filename | ||||
| Additional Information | When you open an IDF file that has spaces on it, freecad 0.14.3310 throws an exception. Traceback (most recent call last): File "<string>", line 1, in <module> File "C:\Program Files\FreeCAD 0.14\Mod\Idf\Idf.py", line 63, in open FreeCAD.setActiveDocument(docname) <type 'exceptions.Exception'>: Try to activate unknown document 'snap100x2 hv psu v2.1 rev 0.68 noextraconnectors' This does not happen with "import" so it's possibly a bug elsewhere. Removing line 63 from idf.py fixes the issue FreeCAD.setActiveDocument(docname) | ||||
FreeCAD: master d40d5a3e 2014-03-25 16:07:20 Details Diff |
Update Idf.py Fixes for bugs 0001491, 0001492, 0001493 |
Affected Issues 0001491, 0001492, 0001493 |
| mod - src/Mod/Idf/Idf.py | Diff File | ||
FreeCAD: master 69044c6b 2014-03-29 13:00:41 Details Diff |
Merge branch 'patch-1' of https://github.com/Barleyman/FreeCAD_sf_master |
| 2014-03-25 14:36 | barleyman | New Issue | |
| 2014-03-25 14:36 | barleyman | File Added: test idf.zip | |
| 2014-03-29 12:55 | wmayer | Changeset attached | => FreeCAD Master master 69044c6b |
| 2014-03-29 12:55 | wmayer | Status | new => closed |
| 2014-03-29 12:55 | wmayer | Resolution | open => fixed |
| 2019-07-30 22:40 | Kunda1 | Changeset attached | => FreeCAD master d40d5a3e |
