| 0001492 | File formats | Feature | public | 2014-03-25 14:46 | 2019-07-30 22:40 |
| Reporter | barleyman | Assigned To | |||
| Platform | PC | OS | Windows | OS Version | 7 x64 |
| Summary | 0001492: IDF import does not find footprints | ||||
| Description | idf.py is using wrong directory for libraries | ||||
| Steps To Reproduce | From the FILE menu, select OPEN and select an *.emn file | ||||
| Additional Information | Opening IDF file throws an exception Traceback (most recent call last): File "<string>", line 1, in <module> File "C:\Program Files\FreeCAD 0.14\Mod\Idf\Idf.py", line 66, in open process_emn(doc,filename) File "C:\Program Files\FreeCAD 0.14\Mod\Idf\Idf.py", line 133, in process_emn place_steps(doc,placement,board_thickness) File "C:\Program Files\FreeCAD 0.14\Mod\Idf\Idf.py", line 334, in place_steps model_file=pythonopen(model_tab_filename, "r") <type 'exceptions.IOError'>: (2, 'No such file or directory', 'C:/Program Files/FreeCAD 0.14/data/Mod/Idf/lib/footprints_models.csv') This is caused by lines 38 and 42 presuming "MOD" dir is under resourcedir, it is not. Changing this model_tab_filename = FreeCAD.getResourceDir()+ "Mod/Idf/lib/footprints_models.csv" ## path to directory containing step models step_path=FreeCAD.getResourceDir()+ "Mod/Idf/lib/" to this model_tab_filename = FreeCAD.getHomePath()+ "/Mod/Idf/idflibs/footprints_models.csv" ## path to directory containing step models step_path=FreeCAD.getHomePath()+ "/Mod/Idf/idflibs/" corrects the problem | ||||
FreeCAD: master d40d5a3e 2014-03-25 16:07:20 Details Diff |
Update Idf.py Fixes for bugs 0001491, 0001492, 0001493 |
Affected Issues 0001491, 0001492, 0001493 |
| mod - src/Mod/Idf/Idf.py | Diff File | ||
FreeCAD: master 69044c6b 2014-03-29 13:00:41 Details Diff |
Merge branch 'patch-1' of https://github.com/Barleyman/FreeCAD_sf_master |
| 2014-03-25 14:46 | barleyman | New Issue | |
| 2014-03-25 14:46 | barleyman | File Added: test idf.zip | |
| 2014-03-29 12:55 | wmayer | Changeset attached | => FreeCAD Master master 69044c6b |
| 2014-03-29 12:56 | wmayer | Status | new => closed |
| 2014-03-29 12:56 | wmayer | Resolution | open => fixed |
| 2019-07-30 22:40 | Kunda1 | Changeset attached | => FreeCAD master d40d5a3e |
