| 0001571 | FreeCAD | Bug | public | 2014-06-05 10:46 | 2019-04-06 19:00 |
| Reporter | denem | Assigned To | |||
| Platform | All | OS | All | OS Version | All |
| Summary | 0001571: Sweep with closed profile with acute angles does not work | ||||
| Description | Sample project contains two sketches. If we select more than one segment from Wire Sketch to make sweep than resulting figure will either be obstructed (see pic 1) if we will set solid=false or the sweep process will be failed with message "--------------------------- Input error --------------------------- --------------------------- OK --------------------------- " This bug affects .13 and .14 | ||||
| Steps To Reproduce | Use the attached project | ||||
| Additional Information | This issue arrears to be related with bug 0001570 | ||||
| Tags | OCC 7.3, OCC Bug, sweep, upstream | ||||
| related to | 0001570 | confirmed | Part sweep bug with acute angle (Upstream OCC bug) |
your example contains acute angles. In what way is the result different from the problem described in 0001570 ? |
The behaviour is slightly different for open and closed wires. For open wires we always able to see the result. For closed profiles system appears to have an internal exception at least in the half of the cases and because of that does not generate any profile at all. I think that after the fix these two bugs should be tested together. I can provide more sample projects if it wil help you to solve this problem. I'm interested in gothic cathedral windows construction, so this issue makes completely unable to use this wonderful program! Looking forward to get the fixed version. |
Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 109.23955054578 Projection not done Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 116.063732202451 Projection not done Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 107.096928594517 Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 109.239550545767 Projection not done Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 116.063732202547 Projection not done Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 107.096928594518 Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Fail of TrimCorner Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 109.239550545781 Projection not done Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 116.063732202247 Projection not done Projection not done SameParameter : Tolerance not reached! tol visee : 0.0001 tol obtained : 107.096928594516 Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Compile with option DEB : if problems with intersection : IntWalk_PWalking_1.gxx (lbr le 1erdec98) Fail of TrimCorner DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null Draw[6]> checkshape Sweep **** probleme de SameParameter au point : 26.2613909351997 14.35961570099 0.85548271990202 Erreur detectee :3.78592234732288 Tolerance :1e-07 **** probleme de SameParameter au point : 29.1343753167111 13.3580154836856 3.59739187306738 Erreur detectee :1.27496243309754 Tolerance :1e-07 **** probleme de SameParameter au point : -25.1235054537064 15.5632238381015 0.855482719902038 Erreur detectee :3.61390646301809 Tolerance :1e-07 BRepCheck_NoCurveOnSurface or BRepCheck_InvalidRange **** probleme de SameParameter au point : -25.4572733285634 18.552101405819 3.59739187306756 Erreur detectee :1.0944119327006 Tolerance :1e-07 BRepCheck_NoCurveOnSurface or BRepCheck_InvalidRange **** probleme de SameParameter au point : -6.77744491084376e-09 -31.1264476644595 0.855482719902033 Erreur detectee :4.19853418392951 Tolerance :1e-07 BRepCheck_NoCurveOnSurface or BRepCheck_InvalidRange **** probleme de SameParameter au point : 8.80184813922824e-13 -37.1042028116357 3.5973918730673 Erreur detectee :3.4016855877909 Tolerance :1e-07 BRepCheck_NoCurveOnSurface or BRepCheck_InvalidRange DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null DBRep_IsoBuilder : PCurve is null On Shape faulty_1 : BRepCheck_UnorientableShape Shape faulty_2 on shape faulty_1 : BRepCheck_InvalidCurveOnSurface BRepCheck_InvalidSameParameterFlag On Shape faulty_3 : BRepCheck_UnorientableShape Shape faulty_4 on shape faulty_3 : BRepCheck_InvalidCurveOnSurface BRepCheck_InvalidSameParameterFlag On Shape faulty_5 : BRepCheck_UnorientableShape Shape faulty_6 on shape faulty_5 : BRepCheck_NoCurveOnSurface Shape faulty_7 on shape faulty_5 : BRepCheck_InvalidCurveOnSurface BRepCheck_InvalidSameParameterFlag Shape faulty_8 on shape faulty_5 : BRepCheck_NoCurveOnSurface On Shape faulty_9 : BRepCheck_UnorientableShape Shape faulty_10 on shape faulty_9 : BRepCheck_NoCurveOnSurface Shape faulty_11 on shape faulty_9 : BRepCheck_InvalidCurveOnSurface BRepCheck_InvalidSameParameterFlag Shape faulty_12 on shape faulty_9 : BRepCheck_NoCurveOnSurface On Shape faulty_13 : BRepCheck_UnorientableShape Shape faulty_14 on shape faulty_13 : BRepCheck_NoCurveOnSurface Shape faulty_15 on shape faulty_13 : BRepCheck_InvalidCurveOnSurface BRepCheck_InvalidSameParameterFlag Shape faulty_8 on shape faulty_13 : BRepCheck_NoCurveOnSurface On Shape faulty_16 : BRepCheck_UnorientableShape Shape faulty_17 on shape faulty_16 : BRepCheck_NoCurveOnSurface Shape faulty_18 on shape faulty_16 : BRepCheck_InvalidCurveOnSurface BRepCheck_InvalidSameParameterFlag Shape faulty_12 on shape faulty_16 : BRepCheck_NoCurveOnSurface On Shape faulty_19 : BRepCheck_NotConnected Faulty shapes in variables faulty_1 to faulty_19 |
@yorik please advise |
Don't know what to say, the bug is more than 2 years old... MAybe the OP can tell if the problem still exists? |
@denem ping |
@denem does this problem still exist? |
@denem i know this is an old ticket but could you possibly re-up the attachment so testers can recreate the problem and also test for when it is solved? |
Lemme check if i still have it. I'll create new ones if i don't. |
@denem please re-up attachments.. OCCT 7.3 was just released and I'd like to know the outcome on this issue. |
@denem ping |
@denem ping |
@denem ping |
@denem please respond |
@denem this ticket would usually be closed by now but since it's a child of 0001570 it won't. Can you please, nevertheless, add an example file as requested (which you chimed in and said you would?) |
Closing ticket as it is referenced in 0001570 Still haven't heard from OP, which is a shame. |
| 2014-06-05 10:46 | denem | New Issue | |
| 2014-06-05 10:46 | denem | File Added: Freecad_bug.zip | |
| 2014-06-05 15:46 | shoogen | Relationship added | related to 0001570 |
| 2014-06-05 15:52 | shoogen | Note Added: 0004733 | |
| 2014-06-05 15:53 | shoogen | Tag Attached: OCC Bug | |
| 2014-06-05 15:54 | shoogen | Tag Detached: OCC Bug | |
| 2014-06-06 08:23 | denem | Note Added: 0004736 | |
| 2014-06-06 15:22 | shoogen | Note Added: 0004738 | |
| 2017-01-19 17:03 | Kunda1 | Tag Attached: sweep | |
| 2017-06-20 20:30 | Kunda1 | Note Added: 0009472 | |
| 2017-06-26 14:02 | yorik | Note Added: 0009541 | |
| 2017-06-26 19:10 | Kunda1 | Assigned To | => Kunda1 |
| 2017-06-26 19:10 | Kunda1 | Status | new => feedback |
| 2017-06-26 19:10 | Kunda1 | Note Added: 0009549 | |
| 2017-07-12 12:37 | Kunda1 | Note Added: 0009737 | |
| 2017-07-22 12:07 | Kunda1 | Assigned To | Kunda1 => |
| 2017-07-22 12:08 | Kunda1 | Additional Information Updated | |
| 2017-12-11 16:59 | Kunda1 | Note Added: 0010569 | |
| 2017-12-11 16:59 | Kunda1 | Tag Attached: OCC 7.3 | |
| 2017-12-11 16:59 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-12-11 16:59 | Kunda1 | Tag Attached: upstream | |
| 2017-12-20 17:10 | denem | Note Added: 0010622 | |
| 2017-12-20 17:10 | denem | Status | feedback => new |
| 2018-05-30 15:46 | Kunda1 | Note Added: 0011306 | |
| 2018-05-30 15:47 | Kunda1 | Status | new => feedback |
| 2018-08-01 03:02 | Kunda1 | Note Added: 0011576 | |
| 2018-10-14 11:25 | Kunda1 | Note Added: 0012024 | |
| 2018-10-17 20:30 | Kunda1 | Note Added: 0012052 | |
| 2018-10-28 02:38 | Kunda1 | Note Added: 0012104 | |
| 2019-01-05 11:48 | Kunda1 | Note Added: 0012381 | |
| 2019-04-06 19:00 | Kunda1 | Status | feedback => closed |
| 2019-04-06 19:00 | Kunda1 | Resolution | open => duplicate |
| 2019-04-06 19:00 | Kunda1 | Note Added: 0013002 |
