| 0001714 | FreeCAD | Bug | public | 2014-08-27 13:44 | 2019-07-29 15:11 |
| Reporter | emh203 | Assigned To | wmayer | ||
| Platform | Windows 7 | ||||
| Summary | 0001714: FreeCAD 0.14 Stable crashes when importing a step model | ||||
| Description | I have a step model for a Molex CAT 5 connector that will cause FreeCAD 0.14 to crash on import. I used the model from here (it is also attached) http://www.digikey.com/product-detail/en/0855085001/WM4590-ND/1851210 | ||||
| Steps To Reproduce | Start FreeCAD. File->Import and then select 855085001.stp | ||||
| Tags | STEP | ||||
It is not crashing for me. Actually I can open the step file just fine. Could you please provide your FULL FreeCAD info as explained in this forum topic: http://forum.freecad.org/viewtopic.php?f=3&t=2264 My FreeCAD info: OS: Ubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3702 (Git) Branch: releases/FreeCAD-0-14 Hash: b3368125c63289ec8ce9faec2b2ae4c78d436406 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.0 |
I deleted the Zip file provided since we have no way of knowing if it can be distributed freely. The direct download link from the manufacturer is here: http://www.molex.com/pdm_docs/stp/85508-5001_stp.zip |
Here it is. Also, I created a fresh VM with Windows 7 and grabbed the latest stable release with the same result. My Main Machine: OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a The Windows 7 VM: OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a |
Also, if it helps, I can make a video capture of the issue |
FYI, you have forgotten to switch to the Part workbench before copying to the clipboard (as was explained on the link). As a result your FreeCAD info is missing the OCC version. But I know that the 64-Bit version you are using was provided with OCC 6.6.0. I wonder if it's why you are getting a crash, and I'm not. OCC is the geometric modeling kernel and STEP import relies on it. I don't think a video capture would provide helpful info. A crash log would but I do not know how to get one on Windows. Hopefully a "real" developer will provide more assistance. Checking if any other STEP file crashes FreeCAD may be useful. |
Does the path to the STEP file on your PC contain non-ASCII characters? I wonder if it would be related to 0001421 (but a workaround was committed before the current stable was published). |
I just loaded the 32-bit version and it imports correctly without a crash. The 64-Bit version still crashed even if the file has all ascii characters. Also, I tried another STEP file and it worked ok (90272A106 from McMaster Carr). There is something about that STEP file and the 64-bit version. |
Also... You were correct on the OCC version: OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.6.0 |
OS: Windows 7 Here is the data on the 32-bit windows version that worked: Word size: 32-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 |
Happens with object labels with only digits in it |
Will this be fixed? That seems to be a limitation that is frustrating to a new user. |
It IS fixed now. A new 0.14 version will be uploaded soon. |
FreeCAD: master e5a54d07 2014-09-01 19:11:46 Details Diff |
+ fixes 0001714: FreeCAD 0.14 Stable crashes when importing a step model |
Affected Issues 0001714 |
FreeCAD: releases f25e6e47 2014-09-02 11:43:51 wmayer Details Diff |
| 2014-08-27 13:44 | emh203 | New Issue | |
| 2014-08-27 13:44 | emh203 | File Added: 855085001.stp | |
| 2014-08-31 19:15 | normandc | Note Added: 0005039 | |
| 2014-08-31 19:15 | normandc | File Deleted: 855085001.stp | |
| 2014-08-31 19:16 | normandc | Note Added: 0005040 | |
| 2014-08-31 23:36 | emh203 | Note Added: 0005041 | |
| 2014-08-31 23:38 | emh203 | Note Added: 0005042 | |
| 2014-09-01 00:36 | normandc | Note Added: 0005043 | |
| 2014-09-01 00:42 | normandc | Note Added: 0005044 | |
| 2014-09-01 00:43 | normandc | Note Edited: 0005044 | |
| 2014-09-01 03:10 | emh203 | Note Added: 0005047 | |
| 2014-09-01 03:12 | emh203 | Note Added: 0005048 | |
| 2014-09-01 03:13 | emh203 | Note Added: 0005049 | |
| 2014-09-01 17:13 | wmayer | Note Added: 0005054 | |
| 2014-09-01 17:13 | wmayer | Assigned To | => wmayer |
| 2014-09-01 17:13 | wmayer | Status | new => confirmed |
| 2014-09-01 17:39 | wmayer | Changeset attached | => FreeCAD Master master e5a54d07 |
| 2014-09-01 17:39 | wmayer | Status | confirmed => closed |
| 2014-09-01 17:39 | wmayer | Resolution | open => fixed |
| 2014-09-03 12:55 | emh203 | Note Added: 0005060 | |
| 2014-09-03 12:55 | emh203 | Status | closed => feedback |
| 2014-09-03 12:55 | emh203 | Resolution | fixed => reopened |
| 2014-09-03 13:04 | wmayer | Note Added: 0005062 | |
| 2014-09-03 13:04 | wmayer | Status | feedback => closed |
| 2014-09-03 13:04 | wmayer | Resolution | reopened => fixed |
| 2014-09-03 13:04 | wmayer | Fixed in Version | => 0.15 |
| 2014-09-16 07:46 | wmayer | Relationship added | has duplicate 0001748 |
| 2014-10-05 19:14 | shoogen | Tag Attached: STEP | |
| 2014-10-05 19:18 | shoogen | Relationship added | has duplicate 0001777 |
| 2014-12-09 10:54 | shoogen | Relationship added | has duplicate 0001853 |
| 2019-07-29 15:11 | Kunda1 | Changeset attached | => FreeCAD releases f25e6e47 |
