| 0001421 | FreeCAD | Bug | public | 2014-02-19 09:14 | 2014-10-14 18:21 |
| Reporter | herman15 | Assigned To | shoogen | ||
| Platform | X86_64 | OS | Linux Mint | OS Version | 14 |
| Summary | 0001421: STEP import failure due to non-ASCII chars path | ||||
| Description | Importing a specific STEP (appended) file causes the following error Traceback (most recent call last): File "<string>", line 1, in <module> <type 'exceptions.Exception'>: OSD_Path::OSD_Path : Invalid dependent name This STEP file is a heatsink provided by Fischer Elektronik. Other STEP files from this distributor behave identically But this STEP file could be opened and modified by other standard CAD software (CATIA, ZW3D) | ||||
| Steps To Reproduce | Just open STEP file | ||||
('ZWCAD Software Co.'),'Version 1.0','ZW3D to STEP translator' I can't reproduce the problem in the Part Workbench. (using debian wheezy) Can you please try to open the file from a path only containing ASCII characters. |
Thanks for your fast response The problem was the non ASCII characters "äöü" in the Path name of the STEP file |
As long as OCC doesn't support unicode the change below uses the local 8-bit encoding so that depending on the region e.g. umlauts or other characters outside 7-bit ASCII is supported. https://github.com/FreeCAD/FreeCAD_sf_master/commit/040c19b1c1618043631e45c74ddd30536cf09252 |
Unicode support is scheduled for OCCT 6.8.0 |
| 2014-02-19 09:14 | herman15 | New Issue | |
| 2014-02-19 09:14 | herman15 | File Added: sk481_100.stp.zip | |
| 2014-02-19 10:20 | shoogen | Note Added: 0004239 | |
| 2014-02-19 10:32 | herman15 | Note Added: 0004240 | |
| 2014-02-19 11:33 | shoogen | Relationship added | related to 0001411 |
| 2014-02-19 11:33 | shoogen | File Deleted: sk481_100.stp.zip | |
| 2014-02-19 11:35 | shoogen | Summary | STEP import failure => STEP import failure due to non-ASCII chars path |
| 2014-03-02 14:04 | wmayer | Relationship added | child of 0000812 |
| 2014-03-07 09:36 | wmayer | Note Added: 0004390 | |
| 2014-03-07 19:03 | yorik | Changeset attached | => FreeCAD Master master 040c19b1 |
| 2014-09-24 11:33 | shoogen | Note Added: 0005150 | |
| 2014-09-24 11:35 | shoogen | Assigned To | => shoogen |
| 2014-09-24 11:35 | shoogen | Status | new => assigned |
| 2014-09-24 11:42 | shoogen | Relationship added | parent of 0001763 |
| 2014-10-14 18:21 | shoogen | Status | assigned => closed |
| 2014-10-14 18:21 | shoogen | Resolution | open => fixed |
