| 0001727 | Drawing | Bug | public | 2014-09-01 20:05 | 2017-07-11 20:07 |
| Reporter | charlyoleg | Assigned To | yorik | ||
| Platform | linux | OS | ubuntu | OS Version | 14.04 |
| Summary | 0001727: API function Drawing.projectToDXF | ||||
| Description | The API function Drawing.projectToDXF error generates the error: "Exception: Unknown C++ exception" And the script stops on this error. This is a regression compare to FreeCAD 0.13. | ||||
| Steps To Reproduce | Run the attached script. This is a simple code that generates the bug. | ||||
| Additional Information | The attached script provides the following output: FreeCAD 0.15, Libs: 0.15R3904 (Git) Test case for the Drawing.projectToDXF() bug Traceback (most recent call last): File "bug_drawing_projectToDXF_small.py", line 33, in <module> r_dxf = Drawing.projectToDXF(l_slice, vec_z_unit) Exception: Unknown C++ exception | ||||
| Tags | DXF, OCC Bug, upstream | ||||
bug_drawing_projectToDXF_small2.py (932 bytes)
# bug_drawing_projectToDXF.py
import sys
sys.path.append("/usr/lib/freecad/lib")
try:
import FreeCAD
except:
print("ERR080: Error, the FreeCAD library can not be imported by cnc25d!")
sys.exit(2)
import Part
from FreeCAD import Base
import Drawing
print("Test case for the Drawing.projectToDXF() bug")
mybox1 = Part.makeBox(4,5,6, Base.Vector(0,0,0))
vec_z_unit = Base.Vector(0,0,1)
l_solid = mybox1.copy()
l_slice_list = mybox1.slice(vec_z_unit, 1)
l_slice = Part.makeCompound(l_slice_list)
fh_output = open(ai_output_file, 'w')
fh_output.write(r_dxf)
fh_output.close()
# log:
# FreeCAD 0.15, Libs: 0.15R3904 (Git)
# Test case for the Drawing.projectToDXF() bug
# Traceback (most recent call last):
# File "bug_drawing_projectToDXF_small.py", line 34, in <module>
# r_dxf = Drawing.projectToDXF(l_slice, vec_z_unit)
# Exception: Unknown C++ exception
The problem is not the dxf projection itself (try projecting the mybox1 object in your script) but the fact that recent OpenCasCade versions seem unable to project shapes that don't contain faces anymore, like the shape you are trying to project. This is a known OCC bug, we saw it appear many times already... I hope they fix it soon... BTW, the projectToDxf function has changed, it doesn't produce a DXF header anymore (so you can add more than one shape to a dxf file). You now need to add a header yourself, but it's not much work: dxfcode = "0\n0\nSECTION\n2\nENTITIES\n" + Drawing.projectToDXF(myshape,myvector) + "0\nENDSEC\n0\nEOF" |
Projection works with: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8758 (Git) Build type: Release Branch: master Hash: 9c49a0bab1c2610e5435d2666de05f607e1727f6 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 |
@wmayer shall we close ? |
Yes this is fixed in OCC now |
| 2014-09-01 20:05 | charlyoleg | New Issue | |
| 2014-09-01 20:05 | charlyoleg | File Added: bug_drawing_projectToDXF_small2.py | |
| 2014-09-01 21:24 | shoogen | Tag Attached: OCC Bug | |
| 2014-09-01 21:24 | shoogen | Tag Attached: DXF | |
| 2014-09-02 02:58 | yorik | Note Added: 0005056 | |
| 2014-09-02 08:19 | shoogen | Relationship added | duplicate of 0001697 |
| 2016-10-21 15:05 | wmayer | Note Added: 0007411 | |
| 2017-01-15 04:52 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-01-15 04:52 | Kunda1 | Tag Attached: upstream | |
| 2017-01-15 04:52 | Kunda1 | Note Added: 0007781 | |
| 2017-01-19 19:46 | Kunda1 | Tag Attached: #pending | |
| 2017-02-03 12:44 | yorik | Note Added: 0008190 | |
| 2017-02-03 12:44 | yorik | Status | new => closed |
| 2017-02-03 12:44 | yorik | Assigned To | => yorik |
| 2017-02-03 12:44 | yorik | Resolution | open => fixed |
| 2017-07-11 20:07 | Kunda1 | Tag Detached: #tobeclosed | |
| 2017-07-11 20:07 | Kunda1 | Tag Detached: #pending |
