| 0001756 | FreeCAD | Feature | public | 2014-09-18 20:50 | 2021-02-06 06:32 |
| Reporter | r-frank | Assigned To | wmayer | ||
| Summary | 0001756: Show all currently assigned Keyboard Shortcuts with commands as list | ||||
| Description | Having a command (perhaps in the Tools-Section ?) which displays in a two cloumn list command and currently assigned keyboard shortcut. Maybe with possiblity to copy the list to the clipboard for inserting in Calc or Writer and then print it. | ||||
| Additional Information | trimble Sketchup for example has a small ruby script that reads out this informations and writes the two column list in a HTML-File. This would be acceptable/conveniant too. Forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=23692 | ||||
| Tags | #lowhangingfruit, documentation, keyboard, shortcuts | ||||
per @triplus in https://forum.freecad.org/viewtopic.php?f=8&t=23692&p=184937#p184933
Opened issue at triplus's repo: https://github.com/triplus/ShortCuts/issues/1 |
Some good ideas here: Dropdown menu that opens a PDF file: https://youtu.be/PNZJox8pkls?t=5s Find action dialog: https://youtu.be/PNZJox8pkls?t=17s Keymap Preferences menu: https://youtu.be/PNZJox8pkls?t=45s 'Key Promoter' Plugin https://youtu.be/PNZJox8pkls?t=1m10s (prompts you everytime you use the mouse, what keyboard shortcut you could of used instead) |
This ticket has been migrated to GitHub as issue 5596. |
| 2014-09-18 20:50 | r-frank | New Issue | |
| 2017-01-10 18:48 | wmayer | Assigned To | => wmayer |
| 2017-01-10 18:48 | wmayer | Status | new => assigned |
| 2017-02-04 10:46 | Kunda1 | Tag Attached: keyboard | |
| 2017-02-04 10:46 | Kunda1 | Tag Attached: shortcuts | |
| 2017-04-29 11:29 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2017-08-02 12:28 | Kunda1 | Additional Information Updated | |
| 2017-08-02 14:21 | Kunda1 | Note Added: 0009869 | |
| 2017-08-02 16:04 | Kunda1 | Note Added: 0009870 | |
| 2018-01-27 13:51 | Kunda1 | Tag Attached: documentation | |
| 2018-03-07 21:21 | Kunda1 | Note Added: 0011018 | |
| 2019-02-24 18:30 | wmayer | Target Version | => 0.19 |
| 2020-01-15 19:18 | Kunda1 | Relationship added | related to 0004220 |
| 2021-02-06 06:32 | abdullah | Target Version | => 0.20 |
