| 0004220 | Sketcher | Bug | public | 2019-12-10 13:02 | 2021-10-16 17:24 |
| Reporter | leoheck | Assigned To | abdullah | ||
| OS | Ubuntu | OS Version | 19.10 | ||
| Summary | 0004220: Most of the sketcher shortcuts are not working | ||||
| Description | Most of the shortcuts in Sketcher do not work. Most of the time they overlap other shortcuts. If it is a 2 letter combination like (V, C) the V is interpreted by some tool and I can't make the combo. Shortcuts are an important feature to accelerate the design process. For example (there are many others, mostly starting with C) C - Is used to create coincident constraint C, M - Is used to toggle the construction line | ||||
| Steps To Reproduce | Try to use the shortcut (C, M) to toggle the construction line | ||||
| Tags | shortcuts | ||||
| FreeCAD Information | I am using version 0.19 build Help > About FreeCAD > "Copy to clipboard" does not work on Ubuntu (since many versions from now). This is the message displayed instead. FreeCAD help files not found (/usr/share/doc/freecad-daily-doc/freecad.qhc). You might need to install the FreeCAD documentation package. | ||||
I forgot to say that I posted this here some days ago. https://forum.freecad.org/viewtopic.php?f=3&t=41272&p=353010#p353010 |
Related threads: https://forum.freecad.org/viewtopic.php?f=3&t=33901 https://forum.freecad.org/viewtopic.php?f=3&t=33805#p283072 |
git commit 0926a4148bcff11249fd4f56bc30256102ffe105 |
| 2019-12-10 13:02 | leoheck | New Issue | |
| 2019-12-10 13:03 | leoheck | Note Added: 0013895 | |
| 2019-12-10 18:19 | openBrain | Priority | high => normal |
| 2020-01-15 19:16 | Kunda1 | Tag Attached: shortcuts | |
| 2020-01-15 19:17 | Kunda1 | Note Added: 0014078 | |
| 2020-01-15 19:18 | Kunda1 | Relationship added | related to 0001756 |
| 2020-01-15 19:21 | Kunda1 | Target Version | => 0.19 |
| 2020-11-09 18:06 | abdullah | Target Version | 0.19 => 0.20 |
| 2021-08-27 13:27 | chennes | Assigned To | => chennes |
| 2021-08-27 13:27 | chennes | Status | new => assigned |
| 2021-08-27 13:36 | chennes | Relationship added | related to 0003796 |
| 2021-08-27 13:36 | chennes | Status | assigned => confirmed |
| 2021-10-16 17:23 | abdullah | Assigned To | chennes => abdullah |
| 2021-10-16 17:24 | abdullah | Status | confirmed => closed |
| 2021-10-16 17:24 | abdullah | Resolution | open => fixed |
| 2021-10-16 17:24 | abdullah | Fixed in Version | => 0.20 |
| 2021-10-16 17:24 | abdullah | Note Added: 0015991 |
