| 0001863 | Drawing | Feature | public | 2014-12-17 16:57 | 2018-09-16 11:33 |
| Reporter | triplus | Assigned To | |||
| Summary | 0001863: Global preference for drawing line width | ||||
| Description | Each inserted drawing view has two properties called Line Width (default 0,35) and Hidden Width (default 0,15). It would be great if user could somehow set default (custom) values for this two properties globally. In the future FreeCAD might be able to define line width automatically based on drawing template size inserted: http://www.metrication.com/drafting/lines.html http://www.en.technisches-zeichnen.net/technical-drawing/basics-01/line-width.php But for now it would be great if global method would exist instead of user each time having to select each drawing view and change values if default values are not appropriate for the project. | ||||
> - Line style/weight preference changes are planned (in TechDraw) Per @wandererfan in https://forum.freecadweb.org/viewtopic.php?f=10&t=20342#p157399 Context: Drawing is planned to be deprecated after 0.17 in favor of TechDraw Related: 0001920 & 0001921 |
@wandererfan what about this ? |
TechDraw LineGroups |
@wandererfan care to go through the remainder of the drawing WB tickets and updating/closing tickets? |
| 2014-12-17 16:57 | triplus | New Issue | |
| 2014-12-17 19:10 | shoogen | Relationship added | related to 0000606 |
| 2017-02-02 00:26 | Kunda1 | Relationship added | related to 0001921 |
| 2017-02-02 00:27 | Kunda1 | Relationship added | related to 0001920 |
| 2017-02-02 00:28 | Kunda1 | Note Added: 0008158 | |
| 2017-02-02 00:29 | Kunda1 | Note Edited: 0008158 | |
| 2017-02-02 00:34 | Kunda1 | Note Edited: 0008158 | |
| 2017-02-02 00:38 | Kunda1 | Status | new => confirmed |
| 2018-09-14 15:25 | Kunda1 | Note Added: 0011740 | |
| 2018-09-15 13:44 | wandererfan | Note Added: 0011748 | |
| 2018-09-15 16:26 | Kunda1 | Note Added: 0011749 | |
| 2018-09-16 11:33 | wandererfan | Status | confirmed => closed |
| 2018-09-16 11:33 | wandererfan | Resolution | open => won't fix |
