| 0001920 | Drawing | Feature | public | 2015-01-16 10:14 | 2018-09-16 11:45 |
| Reporter | triplus | Assigned To | |||
| Summary | 0001920: Drawing scale and stroke-dasharray | ||||
| Description | I could not provide feedback to closed report therefore i opened a new report: 0001773 SVG linestyles are now configurable in Draft WB preferences and that is great! I would expect this setting to be available in Drawing WB preferences but nonetheless it is now possible to set desired stroke-dasharray under FreeCAD preferences and that is nice addition. From the original report: "I'm not sure if/how it is possible to have scale-independent dashes in SVG, but I'll have a look." This part still is not implemented therefore settings in preferences will still scale stroke-dasharray based on the drawing view scale used. The most elegant solution would be to use vector-effect="non-scaling-stroke": http://www.w3.org/TR/SVGTiny12/painting.html#NonScalingStroke And it actually works quite good in QtSvg and Firefox but ATM it is not supported in for example Inkscape or default Ubuntu image viewer. Lack of support in Inkscape is in my opinion to big drawback to use this attribute ATM. Best cross-software solution therefore for the time being would be to take scale into consideration and set stroke-dasharray based on that. The same behaviour as the current situation with stroke-width. Example rectangle scale 1: <?xml version="1.0" encoding="UTF-8"?> <svg xmlns="http://www.w3.org/2000/svg" version="1.1" width="420mm" height="297mm" viewBox="0 0 420 297"> <!-- Working space 0 0 420 297 --> <g id="ViewRectangle" transform="rotate(0.0,100.0,200.0) translate(100.0,200.0) scale(1.0,-1.0)"><path id="Rectangle_w0000" d="M 0.0 0.0 L 100.0 0.0 L 100.0 100.0 L 0.0 100.0 L 0.0 0.0 " stroke="#000000" stroke-width="0.35 px" style="stroke-width:0.35;stroke-miterlimit:4;stroke-dasharray:0.09,0.05;fill:none;fill-rule: evenodd "/> </g> </svg> Example rectangle scale 100: <?xml version="1.0" encoding="UTF-8"?> <svg xmlns="http://www.w3.org/2000/svg" version="1.1" width="420mm" height="297mm" viewBox="0 0 420 297"> <!-- Working space 0 0 420 297 --> <g id="ViewRectangle" transform="rotate(0.0,100.0,200.0) translate(100.0,200.0) scale(100.0,-100.0)"><path id="Rectangle_w0000" d="M 0.0 0.0 L 100.0 0.0 L 100.0 100.0 L 0.0 100.0 L 0.0 0.0 " stroke="#000000" stroke-width="0.0035 px" style="stroke-width:0.0035;stroke-miterlimit:4;stroke-dasharray:0.09,0.05;fill:none;fill-rule: evenodd "/> </g> </svg> Observe the stroke-width and stroke-dasharray attribute: Scale 1 stroke-width:0.35 stroke-dasharray:0.09,0.05 Scale 100 stroke-width:0.0035 stroke-dasharray:0.09,0.05 At scale 100 stroke-dasharray:0.09,0.05 would need to be set like this stroke-dasharray:0.0009,0.0005. More sane default values should be used and Scale 1 should be the default target under preferences. Something like stroke-dasharray:9,5 for example. | ||||
"I would expect this setting to be available in Drawing WB preferences but nonetheless it is now possible to set desired stroke-dasharray under FreeCAD preferences and that is nice addition." Not true. This is about Draft object "projected" on drawing page and therefore it makes sense to control them in Draft preferences. |
See related tickets 0001921 & 0001863 |
Line widths & styles are controlled by Draft module, not Drawing module. |
| 2015-01-16 10:14 | triplus | New Issue | |
| 2015-01-16 11:38 | triplus | Note Added: 0005659 | |
| 2017-01-14 01:16 | Kunda1 | Relationship added | related to 0001921 |
| 2017-02-02 00:27 | Kunda1 | Relationship added | related to 0001863 |
| 2017-02-02 00:35 | Kunda1 | Note Added: 0008161 | |
| 2017-02-02 00:36 | Kunda1 | Description Updated | |
| 2017-02-02 00:38 | Kunda1 | Status | new => confirmed |
| 2018-09-16 11:45 | wandererfan | Status | confirmed => closed |
| 2018-09-16 11:45 | wandererfan | Resolution | open => won't fix |
| 2018-09-16 11:45 | wandererfan | Note Added: 0011755 |
