| 0001936 | PartDesign | Bug | public | 2015-01-27 06:10 | 2017-04-28 19:33 |
| Reporter | quick61 | Assigned To | |||
| Summary | 0001936: Part Design Pad Fails with Circle In Square When Circle Is Close To Edge Of Square. | ||||
| Description | In Part Design, when creating a square and including a circle that has a radius close to the edges of the square, Pad fails and produces an invalid solid. This is occurring in both Release and Master versions as reported on the FreeCAD forum. | ||||
| Steps To Reproduce | Create a sketch consisting of a 40 mm square and an 18.5 mm radius circle centered in the square. Pad the Sketch. See attached file. | ||||
| Additional Information | FreeCAD forum threads - http://forum.freecad.org/viewtopic.php?f=3&t=9494 http://forum.freecad.org/viewtopic.php?f=3&t=9262 OS: Kubuntu 14.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4530 (Git) Branch: master Hash: 2ef086a02837670c21de65e8d33fa17fe1d8ef59 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17-dev and OS: Kubuntu 14.04.1 LTS Word size: 64-bit Version: 0.14.3705 (Git) Branch: releases/FreeCAD-0-14 Hash: f25e6e4716fb63ef3ac618ce9e552761bbc1b4b1 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.7.1 | ||||
| Tags | OCC 7.1, OCC Bug, upstream | ||||
After doing some testing, it seems that any circle that has a radius equal to or greater than 96.19% of the edge length of the square will fail to produce a valid Pad. http://forum.freecad.org/viewtopic.php?f=3&t=9494#p77032 |
@NormandC wrote: This is no longer an issue in current master based on OCCT 7.1.0, but still is with OCCT 6.8.0. I sketched a 40x40mm square with a R19.999mm circle inside it, the Pad works and produces a valid solid with the latest OCCT version. If someone else confirms we can set this report as fixed. To quickly check:
OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10807 (Git) Build type: None Branch: master Hash: b32e9806e1b075c745c0c9692e81aea1dcab81e4 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
@chrisb replied: The error exists in 0.16.6707. The error is gone in 0.17 if the sketch is created and padded within a body. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10887 (Git) Build type: None Branch: master Hash: 67fc70dadae471cb3d77dcf5562b4a86ec79f95d Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 |
Thanks guys. Resolving ticket. |
| 2015-01-27 06:10 | quick61 | New Issue | |
| 2015-01-27 06:10 | quick61 | File Added: Pad_Fail.fcstd | |
| 2015-01-27 21:45 | quick61 | Note Added: 0005743 | |
| 2017-01-16 10:14 | Kunda1 | Project | FreeCAD => PartDesign |
| 2017-04-26 11:09 | Kunda1 | Note Added: 0008769 | |
| 2017-04-26 11:11 | Kunda1 | Note Added: 0008770 | |
| 2017-04-26 11:12 | Kunda1 | Status | new => resolved |
| 2017-04-26 11:12 | Kunda1 | Product Version | => 0.14 |
| 2017-04-26 11:12 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-04-26 11:12 | Kunda1 | Note Added: 0008771 | |
| 2017-04-26 11:13 | Kunda1 | Tag Attached: OCC 7.1 | |
| 2017-04-26 11:13 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-04-26 11:14 | Kunda1 | Tag Attached: upstream | |
| 2017-04-28 19:33 | Kunda1 | Status | resolved => closed |
| 2017-04-28 19:33 | Kunda1 | Resolution | open => fixed |
