| 0001950 | Draft | Bug | public | 2015-02-04 15:00 | 2017-06-14 18:15 |
| Reporter | ctjctj | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 14.10 |
| Summary | 0001950: If draft grid space is set to zero then drafting draw tools fail. | ||||
| Description | Clean install of 0.15 daily as of 2015/02/02 In draft workbench If the grid spacing is set to 0.00 which seems to be a default on clean/new install when a user attempts to draw anything it generates a divide by zero exception when the mouse enters the drawing window. Since snap to grid appears to be the default to a new user it looks like the draft workbench is broken. Work around is to set the grid spacing to non-zero. | ||||
| Steps To Reproduce | clear all preferences and do a clean install. start freecad. Go to draft workbench. Make new drawing. Click on line, click in drawing window. If report view is showing there will be an error message. If the report view is not showing then there is no error. OR Can also be reproduced by going to preferences->draft workbench->snap settings and set spacing to 0. | ||||
| Additional Information | Real issue is in the UI. If the default was non-zero AND the UI did not allow grid spacing to be set to zero then the error would not occur. | ||||
| Tags | snap | ||||
The default value for this setting is 1. Did you have freecad installed before? The setting files are keept between installations, maybe the wrong value was created in an older FreeCAD version. |
I started with apt-get install freecad freecad-doc I then added the PPA for the dailies of freecad and have been using that since. So it could well have been a zero that came forward. |
The reporter uses an imperial unit scheme, could this have screwed with things? A workaround could be to set the minimum grid spacing to something small but positive, like a nanometer. Is the default value set in the userprefs-snap.ui file, or is there some other place that I missed? |
It looks like the Tracker-concept needs to be rewritten a bit. Each tracker, like "GridTracker" should be able to decide for itself whether it is allowed to be turned on or not. like: def on: start() return self.started() Also, the naming could be improved, e.g. turnOn(), turnOff() Also # 2, it looks like "reset" is called continuously when the mouse is being moved. is this intentional? |
@NormandC do you mind weighing in? |
Forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=22938 |
Issue is solved. The default grid width is set to 1mm. Tested versions: see forum thread. |
Fixed on both 0.16 and 0.17 per @chrisb Labeled fix as 0.17 since 0.16 not available as tag anymore. Closing |
| 2015-02-04 15:00 | ctjctj | New Issue | |
| 2015-02-04 15:33 | ickby | Note Added: 0005765 | |
| 2015-02-04 19:50 | ctjctj | Note Added: 0005766 | |
| 2015-02-05 09:27 | jreinhardt | Note Added: 0005767 | |
| 2015-02-07 12:05 | JanneK | Note Added: 0005769 | |
| 2017-01-16 10:16 | Kunda1 | Project | FreeCAD => Draft |
| 2017-02-02 12:17 | Kunda1 | Note Edited: 0005769 | |
| 2017-02-02 12:19 | Kunda1 | Steps to Reproduce Updated | |
| 2017-05-06 11:25 | Kunda1 | Tag Attached: snap | |
| 2017-05-06 11:26 | Kunda1 | Product Version | => 0.15 |
| 2017-05-06 11:27 | Kunda1 | Relationship added | related to 0001951 |
| 2017-06-02 00:01 | Kunda1 | Note Added: 0009248 | |
| 2017-06-14 12:59 | Kunda1 | Note Added: 0009368 | |
| 2017-06-14 16:17 | chrisb | Note Added: 0009369 | |
| 2017-06-14 18:15 | Kunda1 | Status | new => closed |
| 2017-06-14 18:15 | Kunda1 | Resolution | open => fixed |
| 2017-06-14 18:15 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-06-14 18:15 | Kunda1 | Note Added: 0009373 |
