| 0001999 | FreeCAD | Bug | public | 2015-03-11 20:47 | 2017-07-12 11:50 |
| Reporter | sourcerer | Assigned To | wmayer | ||
| Platform | Windows | OS | Windows 7 | OS Version | 7 |
| Summary | 0001999: [STEP] Tessellation data or OpenInventor data memory leak | ||||
| Description | I tried to open the attached STEP file and wanted to convert it to a WRL file. During opening it, after about a minute it usually crashes with an Out-of-Memory error | ||||
| Steps To Reproduce | Open the file in FreeCAD Wait a minute | ||||
| Tags | memory leak, STEP | ||||
| related to | 0002480 | closed | File formats | Opening big STEP file fail (slow tessellation of shapes) |
Can you please post the complete version information of FreeCAD. You can do this under Help > FreeCAD > Copy to clipboard. I tested with the current developer version and the old 0.14 and everything works fine. OS: Windows 7 Word size: 64-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a SoQt version: 1.6.0a OCC version: 6.6.0 |
Werner perhaps you need to use a 32-bit platform ;) VmPeak: 3192948 kB Hm' my instance had leaked a lot before. Today it was just VmPeak: 2769764 kB But that is still a lot of memory. |
OS: Windows 7 Word size: 32-bit Version: 0.14.3700 (Git) Branch: releases/FreeCAD-0-14 Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1 Python version: 2.6.2 Qt version: 4.5.2 Coin version: 3.1.0 SoQt version: 1.4.1 OCC version: 6.5.1 |
If you got a 64-bit operating system you can solve this by installing the 64-bit version of FreeCAD. The 32-bit platform can't provide the amount of VIRTUAL memory needed. (> 3GB) |
Unfortunately I only have a 32-bit platform available. Is it really necessary to have more than 3GB virtual memory just to open a 2 MB file? How much memory is needed for even larger files? Also I have the feeling that there are memory leaks there, but it could be that that memory is still reuseable. |
> Unfortunately I only have a 32-bit platform available. I have tested this on a Linux 32-bit and Windows XP 32-bit inside a virtual machine and I can load the file. > Is it really necessary to have more than 3GB virtual memory just to open a 2 MB file? How much memory is needed for even larger files? It's a bit strange that the reader needs so much memory but I think this is more a problem of the complexity and less a problem of the file size. > Also I have the feeling that there are memory leaks there, but it could be that that memory is still reuseable. This all is done in OCC (the cad kernel) and it doesn't seem to be a leak there. The memory load goes down as soon as the object is loaded. |
@wmayer is this attached file a good example for finding memory leaks? Should we keep the file for tests? Also should we keep this ticket open? |
It looks like there is indeed somewhere a leak. However, I never had such an extreme peak of 3 GB. The highest load 600 MB when loading once. Here are some (roughly measured) numbers: * 120 MB after start of FreeCAD * 150 MB directly after load of the STEP and before displaying it * 500 MB after creating the tessellation mesh for the display * 600 MB after doing some user interaction * 540 MB after closing the document When loading the file again it goes up to 750 MB and down to 690 MB after closing again. For every further load & close 150 MB - 200 MB are lost. When loading the file in Python: * 120 MB after start of FreeCAD * 150 MB directly after load of the STEP and before displaying it * 160 MB when creating a very coarse mesh * 145 MB when deleting the object * 160 MB when loading it again * 230 MB when creating the tessellation mesh before displaying * 300 MB when displaying the shape * 280 MB when closing the document and deleting the shape So, it looks like the tessellation data or the OpenInventor data are not freed. Tested with: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9590 (Git) Build type: Release Branch: master Hash: a9530bc678b38902f5a68cd161ab27c0e36ff6f8 Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 |
Tagged as 'memory leak' downgraded to 'major' Also renamed ticket for better comprehension |
Forum thread: https://forum.freecad.org/viewtopic.php?f=10&t=20059 |
A leak in the OpenInventor structure can be excluded as it destroys all the shape nodes. |
renamed topic for better precision |
It turned out that when a shape was selected its reference counter was increased but never decreased later which causes the whole sub-graph not to be freed. git show 6630bcf now reduces the leak but there must be still somewhere another leak. |
The below commits fix this issue, right @wmayer? c:FreeCAD:a289538e034cac5f8f312b2945c41dc9fcd3e1c8: c:FreeCAD:add9bf910bbb37c35738b01d38c7fe28b75fb8e3: Bugtracker notes: if commits are not recognized by source-integration plugin then wait till they are then attach them to ticket and close. |
Source integration still doesn't see: https://github.com/FreeCAD/FreeCAD/commit/a289538e034cac5f8f312b2945c41dc9fcd3e1c8 https://github.com/FreeCAD/FreeCAD/commit/add9bf910bbb37c35738b01d38c7fe28b75fb8e3 Closing anyway. (CC @kkremitzki ) |
FreeCAD: master 6630bcf9 2017-02-20 09:08:18 Details Diff |
issue 0001999: [STEP] Tessellation data or OpenInventor data memory leak |
Affected Issues 0001999 |
| mod - src/Gui/SoFCUnifiedSelection.cpp | Diff File | ||
FreeCAD: releases/FreeCAD-0-16 f8eca0f9 2017-04-30 17:39:31 Details Diff |
fixes 1999: Tessellation data or OpenInventor data memory leak |
| mod - src/Mod/Import/App/AppImportPy.cpp | Diff File | ||
| mod - src/Mod/Import/Gui/AppImportGuiPy.cpp | Diff File | ||
| 2015-03-11 20:47 | sourcerer | New Issue | |
| 2015-03-11 20:47 | sourcerer | File Added: FreeCadProblem.step | |
| 2015-03-11 21:15 | wmayer | Note Added: 0005858 | |
| 2015-03-12 00:07 | shoogen | Note Added: 0005860 | |
| 2015-03-12 07:15 | sourcerer | Note Added: 0005861 | |
| 2015-03-12 09:43 | shoogen | Note Added: 0005862 | |
| 2015-03-12 09:54 | shoogen | Note Edited: 0005862 | |
| 2015-03-12 10:13 | shoogen | Note Edited: 0005860 | |
| 2015-03-13 22:54 | sourcerer | Note Added: 0005870 | |
| 2015-03-22 14:45 | wmayer | Note Added: 0005911 | |
| 2017-01-11 12:13 | Kunda1 | Tag Attached: STEP | |
| 2017-01-11 12:14 | Kunda1 | Note Added: 0007623 | |
| 2017-01-11 16:48 | wmayer | Note Added: 0007634 | |
| 2017-01-13 22:44 | Kunda1 | Tag Attached: memory leak | |
| 2017-01-13 22:45 | Kunda1 | Note Added: 0007740 | |
| 2017-01-13 22:46 | Kunda1 | Severity | crash => major |
| 2017-01-13 22:46 | Kunda1 | Summary | Opening a certain step file crashes FreeCAD => [STEP] Tessellation data or OpenInventor data memory leak |
| 2017-01-13 22:47 | Kunda1 | Note Edited: 0007740 | |
| 2017-01-19 19:29 | Kunda1 | Note Added: 0007885 | |
| 2017-02-18 13:19 | wmayer | Assigned To | => wmayer |
| 2017-02-18 13:19 | wmayer | Status | new => assigned |
| 2017-02-18 14:55 | wmayer | Note Added: 0008350 | |
| 2017-02-18 22:49 | Kunda1 | Summary |
[STEP] Tessellation data or OpenInventor data memory leak => [STEP] Tessellation data |
| 2017-02-18 22:49 | Kunda1 | Note Added: 0008353 | |
| 2017-02-20 09:06 | wmayer | Summary |
| 2017-02-20 09:08 | wmayer | Changeset attached | => FreeCAD master 6630bcf9 |
| 2017-02-20 09:09 | wmayer | Note Added: 0008382 | |
| 2017-03-02 16:47 | Kunda1 | Relationship added | related to 0002480 |
| 2017-04-25 11:56 | Kunda1 | Status | assigned => resolved |
| 2017-04-25 11:56 | Kunda1 | Resolution | open => fixed |
| 2017-04-25 11:56 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-04-25 11:56 | Kunda1 | Note Added: 0008751 | |
| 2017-04-25 11:57 | Kunda1 | Note Edited: 0008751 | |
| 2017-07-12 11:43 | Kunda1 | Changeset attached | => FreeCAD releases/FreeCAD-0-16 f8eca0f9 |
| 2017-07-12 11:50 | Kunda1 | Status | resolved => closed |
| 2017-07-12 11:50 | Kunda1 | Note Added: 0009732 |
