0002018FreeCADBugpublic2017-03-22 15:39
Reporterpfirszt Assigned Towmayer
Status closedResolutionfixed
Platformx86_64OSLinux FedoraOS Version21
Fixed in Version0.17
Summary0002018: Running Freecad with specific locale causes freeze
DescriptionRunning Freecad with specific locale causes freeze and very high CPU usage.
Console shows series of warnings:
Coin warning in SbRotation::setValue(): Quarternion has zero length => undefined rotation.
Steps To ReproduceRun:
LC_ALL=pl_PL FreeCAD
or
LC_ALL=es_ES FreeCAD
Open attached file
Additional InformationOS: Linux
Version: 0.15.4651 (Git)
Hash: 95ed26715000f90b18be5afe5db21e2e5baf925f
Python version: 2.7.8
Qt version: 4.8.6
Coin version: 3.1.3
Tagslocale
Relationships
related to 0001852 closedshoogen The python interpreter does not recognize the posix locale settings
pfirszt
2015-03-21 21:19
developer
occ_base_empty.fcstd (Attachment missing)
shoogen
2015-03-21 22:26
developer   ~0005900
I raised the priority. We might not want to fix this immediately. But we need to assess whether we hold the 0.15 release.
1. I can reproduce the behavior.
2. How/why did you set LC_ALL? Is the the usual way to set the locale in Fedora Linux 21? Most linux distributions seem to set all the different independent setting and leave LC_ALL unset. (I suppose this is how it slipped through testing)
shoogen
2015-03-21 22:44
developer   ~0005901
I got an idea. I'm compiling the intended bugfix.
pfirszt
2015-03-21 23:02
developer   ~0005902
I tried to get FreeCAD in Polish language (asked about it on the forum) and that's for me the normal way. I have my system locale set as below:
$ locale
LANG=pl_PL.utf8
LC_CTYPE="pl_PL.utf8"
LC_NUMERIC=en_IE.utf8
LC_TIME=en_IE.utf8
LC_COLLATE="pl_PL.utf8"
LC_MONETARY=en_IE.utf8
LC_MESSAGES="pl_PL.utf8"
LC_PAPER="pl_PL.utf8"
LC_NAME="pl_PL.utf8"
LC_ADDRESS="pl_PL.utf8"
LC_TELEPHONE="pl_PL.utf8"
LC_MEASUREMENT=en_IE.utf8
LC_IDENTIFICATION="pl_PL.utf8"
LC_ALL=
so when I want to use English (i.e. for producing understandable error report) I use:
LC_ALL=en_GB eog (eog is Eye of Gnome)
or
LC_ALL=C eog
The same method produced an unexpected behaviour with FreeCAD.
shoogen
2015-03-21 23:08
developer   ~0005903
There are two aspects: the decimal seperator and the filesystem encoding. I'll try to fix the former before the 0.15 release. This means to ignore LC_ALL. But respecting the file system locale from LC_ALL would be even more difficult.
shoogen
2015-03-21 23:28
developer   ~0005904
BTW: https://github.com/python-git/python/blob/master/Python/pythonrun.c#L272
You should set LC_MESSAGES to get English messages. But leave LC_CTYPE intact to convey your file system encoding to the python interpreter.
pfirszt
2015-03-22 09:18
developer   ~0005906
Just in case this is related - no matter what I do FreeCAD ignores Polish decimal mark , (comma) in input fields
shoogen
2015-03-22 10:13
developer   ~0005907
with LC_ALL or LANG set?
LC_ALL is now completely ignored for the 0.15 release, (as it was in the 0.14 release). I thought about copying the value from LC_ALL to LANG and LC_CTYPE, but this might have unexpected side affects, so I would not recommend to touch this by a last time fix.
shoogen
2015-03-22 10:17
developer   ~0005908
And once again. If you remove the trailing ".UTF8" from the LC_CTYPE (or overide ist by setting LC_ALL) you change the sys.filesystemencoding in python. You won't be able to access paths with non-ascii characters (from python). This includes FreeCAD modules that use the open function from the python environment.
pfirszt
2015-03-22 10:26
developer   ~0005909
A few tests of Part Design wb, dimensioning a sketch:
with LANG=pl_PL.utf8, LC_ALL=pl_PL and LANG=pl_PL. I.e. 15,8mm is interpreted as 158mm
with LC_ALL=pl_PL.utf8 throws an error after selecting sketch orientation:
  File "<string>", line 1, in <module>
<type 'exceptions.TypeError'>: Either three floats, tuple or Vector expected
with LC_NUMERIC=pl_PL.utf8 works as expected
with LC_NUMERIC=pl_PL also works as expected
shoogen
2015-03-22 12:04
developer   ~0005910
BTW: The actual hang occurs in the meshing with a deflection 0.0. This happens when the decimal separator screws up the value of the deviation property.
shoogen
2015-04-07 11:35
developer   ~0005973
Dear pfirszt,
could you please test if
git://github.com/5263/FreeCAD bugfix2018-master
improves the behavior?
pfirszt
2015-04-07 12:25
developer   ~0005974
Hi shoogen,
Yes, proposed changes fix the problem. The crash is gone and Polish decimal separator (comma ,) behaves as expected. 15,5 mm is 15 and-a-half mm, not 155 mm as previously.
2015-04-11 15:39
administrator   ~0005998
Sebastian, is this branch ready for merging?
shoogen
2015-04-11 19:22
developer   ~0006002
Hello Werner,
It could be merged, but it won't solve the whole problem.
The same fix needs to be applied to MainCmd as well.
There are two things that I'm not sure about:
1. should this setting up of the locales be moved to a function to be called by MainGui and MainCmd
2. I haven't yet understood how loading FreeCAD as module works and if the bug applies there as well.
shoogen
2015-04-12 09:10
developer   ~0006006
setting LANG for MainCmd still creates problems.
I haven't found a reliable way to test this for FreeCAD as a python module, as it deems that the locale in FreeCAD does not influence set external interpretor.
2015-08-23 08:47
administrator   ~0006298
Related forum link:
http://forum.freecad.org/viewtopic.php?f=8&t=11796
2015-03-21 21:19 pfirszt New Issue
2015-03-21 21:19 pfirszt File Added: occ_base_empty.fcstd
2015-03-21 22:21 shoogen Priority low => immediate
2015-03-21 22:26 shoogen Note Added: 0005900
2015-03-21 22:44 shoogen Note Added: 0005901
2015-03-21 23:02 pfirszt Note Added: 0005902
2015-03-21 23:08 shoogen Note Added: 0005903
2015-03-21 23:28 shoogen Note Added: 0005904
2015-03-21 23:29 shoogen Note Edited: 0005904
2015-03-21 23:37 shoogen Priority immediate => normal
2015-03-21 23:44 shoogen Note Edited: 0005903
2015-03-21 23:50 shoogen Relationship added related to 0001852
2015-03-22 09:18 pfirszt Note Added: 0005906
2015-03-22 10:13 shoogen Note Added: 0005907
2015-03-22 10:13 shoogen Note Edited: 0005907
2015-03-22 10:17 shoogen Note Added: 0005908
2015-03-22 10:18 shoogen Note Edited: 0005908
2015-03-22 10:26 pfirszt Note Added: 0005909
2015-03-22 12:04 shoogen Note Added: 0005910
2015-04-07 11:35 shoogen Note Added: 0005973
2015-04-07 12:25 pfirszt Note Added: 0005974
2015-04-11 15:39 wmayer Note Added: 0005998
2015-04-11 19:22 shoogen Note Added: 0006002
2015-04-12 09:10 shoogen Note Added: 0006006
2015-08-23 08:47 wmayer Note Added: 0006298
2017-01-16 09:59 Kunda1 Tag Attached: locale
2017-02-10 10:19 wmayer Assigned To => wmayer
2017-02-10 10:19 wmayer Status new => assigned
2017-03-22 15:39 wmayer Status assigned => closed
2017-03-22 15:39 wmayer Resolution open => fixed
2017-03-22 15:39 wmayer Fixed in Version => 0.17
