| 0002092 | FreeCAD | Bug | public | 2015-05-08 02:58 | 2017-01-24 12:24 |
| Reporter | xibinke | Assigned To | |||
| Platform | Ubuntu 14.04LTS | ||||
| Summary | 0002092: shape formed from makeCircle + makeOffset cannot be used to a solid by "makeLoft " | ||||
| Description | When use the shape of "makeCircle" as one end of "makeLoft", and "makeOffset" this shape as the other end, the created object is only two separated faces instead of a solid. While the shape from "makePlane" or "makeLine" can get correct result. | ||||
| Steps To Reproduce | 1. coding:
2. You can see "solid1" is abnormal. | ||||
| Tags | OCC Bug, upstream | ||||
Please retest on 0.16 Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20171 |
It was related to the used OCC version. While it failed with 6.8 it works with 7.0 |
| 2015-05-08 02:58 | xibinke | New Issue | |
| 2017-01-24 00:00 | Kunda1 | Note Added: 0007938 | |
| 2017-01-24 00:00 | Kunda1 | Status | new => feedback |
| 2017-01-24 00:00 | Kunda1 | Tag Attached: #pending | |
| 2017-01-24 00:01 | Kunda1 | Steps to Reproduce Updated | |
| 2017-01-24 09:07 | wmayer | Note Added: 0007947 | |
| 2017-01-24 09:07 | wmayer | Status | feedback => closed |
| 2017-01-24 09:07 | wmayer | Resolution | open => no change required |
| 2017-01-24 12:24 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-01-24 12:24 | Kunda1 | Tag Attached: upstream | |
| 2017-01-24 12:24 | Kunda1 | Tag Detached: #pending |
