| 0002226 | FreeCAD | Bug | public | 2015-08-23 13:28 | 2017-03-10 20:30 |
| Reporter | InnerBushman | Assigned To | kkremitzki | ||
| Platform | Linux | OS | Debian | OS Version | 8.0 Jessie |
| Summary | 0002226: Pocket operation fails to open some holes. | ||||
| Description | When doing pocket operation some holes are not open. The hole is there but the face in which the pocket was made is not open (Example 1). Same thing happens if you use polar pattern on previously made pockets (Example 2). Moving the holes or changing their radius makes the open again. | ||||
| Steps To Reproduce | Open attached file. | ||||
| Additional Information | OS: Debian GNU/Linux 8.0 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5356 (Git) Build type: None Branch: master Hash: 70550739b66c1f9395f5cf0258413eb4851cbb3c Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | OCC 7.1, OCC Bug, upstream | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20064 |
@InnerBushman please test on a more current version of 0.16 Also please report your findings in the forum thread I created for you ^ |
@Kunda1 no changes. |
It could be an issue with opencascade. I see all pockets. See attached image. Ulrich OS: Debian GNU/Linux 8.7 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10284 (Git) Build type: Release Branch: Rueck6 Hash: f262eb68042ac8ad23ec4910a45af9026fcbcfef Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 |
@ultrich1a thanks. do you mind notating the forum thread as well ? |
@ulrich1a ^ |
For clarity here's my screenshot. Notice the lower left quadrants of both objects (each created in different way) |
@InnerBushman have you tested with a build that is using OCC 7.1 ? |
@Kunda1 nope. The one you see in version info in the forum post is the one i'm using right now. It's the latest version for my distro. |
Ok so lets recap: according to ulrich1a's comment this is an upstream OpenCascade issue that is fixed in the most recent OCC version (7.1.0). So your options are to find out if you can either: * build FreeCAD from source using the latest OCC version * see if there is a PPA that supports the version of OCC needed Please discuss this on the forum thread and/or open a new thread in regards to running FC with the latest version of OCC. I'm resolving this ticket for now since this issue is not reproducible. Thanks for the report. |
| 2015-08-23 13:28 | InnerBushman | New Issue | |
| 2015-08-23 13:28 | InnerBushman | File Added: issue1.fcstd | |
| 2017-01-19 20:26 | Kunda1 | Note Added: 0007890 | |
| 2017-02-09 22:35 | Kunda1 | Summary | Pocket oper. fails to open some holes. => Pocket operation fails to open some holes. |
| 2017-02-09 22:36 | Kunda1 | Note Added: 0008257 | |
| 2017-02-09 22:36 | Kunda1 | Status | new => feedback |
| 2017-02-26 13:18 | InnerBushman | Note Added: 0008443 | |
| 2017-02-26 13:18 | InnerBushman | Status | feedback => new |
| 2017-02-26 13:38 | ulrich1a | File Added: Pocket_issue_2226.png | |
| 2017-02-26 13:38 | ulrich1a | Note Added: 0008444 | |
| 2017-02-26 14:07 | Kunda1 | Note Added: 0008445 | |
| 2017-02-26 14:08 | Kunda1 | Note Added: 0008446 | |
| 2017-02-26 14:20 | InnerBushman | File Added: issue.png | |
| 2017-02-26 14:20 | InnerBushman | Note Added: 0008447 | |
| 2017-02-27 15:13 | Kunda1 | Note Added: 0008467 | |
| 2017-02-27 18:00 | InnerBushman | Note Added: 0008468 | |
| 2017-02-27 21:05 | Kunda1 | Status | new => resolved |
| 2017-02-27 21:05 | Kunda1 | Resolution | open => no change required |
| 2017-02-27 21:05 | Kunda1 | Note Added: 0008469 | |
| 2017-02-27 21:05 | Kunda1 | Tag Attached: OCC 7.1 | |
| 2017-02-27 21:05 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-02-27 21:05 | Kunda1 | Tag Attached: upstream | |
| 2017-03-10 20:30 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-10 20:30 | kkremitzki | Status | resolved => closed |
| 2017-03-10 20:30 | kkremitzki | Resolution | no change required => unable to reproduce |
