| 0002309 | PartDesign | Bug | public | 2015-10-26 09:18 | 2018-02-21 14:38 |
| Reporter | laurent.despeyroux | Assigned To | wmayer | ||
| Platform | Linux | OS | Debian | OS Version | 8.2 |
| Summary | 0002309: PartDesign Fillet fail without warning when too many faces are selected | ||||
| Description | When too many faces are selected, "PartDesign/Fillet" fail without warning. a message is visible in the console. initial object : https://www.laurent-despeyroux-conseil.fr/initial-step.FCStd (self signed certificate : your browser should rise an alarm) goal (but the fillet is created in 3 step) : https://www.laurent-despeyroux-conseil.fr/wanted-result.FCStd The Fillet object is created in the treeview but nothing is really done. The console show an error : <unknown exception traceback><type 'exceptions.SyntaxError'>: ('unexpected EOF while parsing', ('<string>', 1, 4057, 'App.activeDocument().Fillet.Base = (App.ActiveDocument.Cut003,["Edge569","Edge658","Edge232","Edge558","Edge275","Edge656","Edge230","Edge657","Edge277","Edge279","Edge654","Edge228","Edge655","Edge281","Edge652","Edge226","Edge653","Edge283","Edge650","Edge224","Edge651","Edge648","Edge222","Edge649","Edge285","Edge646","Edge220","Edge647","Edge287","Edge289","Edge644","Edge218","Edge645","Edge27","Edge216","Edge252","Edge253","Edge3","Edge31","Edge255","Edge291","Edge292","Edge328","Edge659","Edge257","Edge660","Edge661","Edge259","Edge662","Edge326","Edge663","Edge261","Edge664","Edge324","Edge322","Edge665","Edge263","Edge666","Edge320","Edge667","Edge265","Edge668","Edge318","Edge669","Edge267","Edge670","Edge671","Edge269","Edge672","Edge316","Edge673","Edge271","Edge556","Edge314","Edge688","Edge310","Edge554","Edge353","Edge686","Edge308","Edge687","Edge355","Edge357","Edge684","Edge306","Edge685","Edge359","Edge682","Edge304","Edge683","Edge361","Edge680","Edge302","Edge681","Edge678","Edge300","Edge679","Edge363","Edge676","Edge298","Edge677","Edge365","Edge367","Edge674","Edge296","Edge675","Edge35","Edge294","Edge330","Edge331","Edge23","Edge177","Edge213","Edge214","Edge250","Edge629","Edge179","Edge630","Edge631","Edge181","Edge632","Edge248","Edge633","Edge183","Edge634","Edge246","Edge244","Edge635","Edge185","Edge636","Edge242","Edge637","Edge187","Edge638","Edge240","Edge639","Edge189","Edge640","Edge641","Edge191","Edge642","Edge238","Edge643","Edge193","Edge560","Edge236","Edge628","Edge154","Edge562","Edge197","Edge626","Edge152","Edge627","Edge199","Edge201","Edge624","Edge150","Edge625","Edge203","Edge622","Edge148","Edge623","Edge205","Edge620","Edge146","Edge621","Edge618","Edge144","Edge619","Edge207","Edge616","Edge142","Edge617","Edge209","Edge211","Edge614","Edge140","Edge615","Edge19","Edge138","Edge174","Edge175","Edge613","Edge115","Edge564","Edge158","Edge611","Edge113","Edge612","Edge160","Edge162"," | ||||
| Steps To Reproduce | - download https://www.laurent-despeyroux-conseil.fr/initial-step.FCStd (self signed certificate : your browser should rise an alarm) - open it in FreeCAD - select all the squared faces and the 2 cylindrical ones - try to make a Fillet on them - look to the console and read the error! | ||||
| Additional Information | OS: Debian GNU/Linux 8.2 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5234 (Git) Build type: Release Branch: master Hash: 3241b1ece15403ef1e2576990e456d48d9551be1 Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
| Tags | OCC 7.1, OCC Bug, upstream | ||||
Shared forum link with 0002227 https://forum.freecadweb.org/viewtopic.php?f=10&t=20257 |
This may be fixed in OCC 7.1 added to https://forum.freecadweb.org/viewtopic.php?f=10&t=20264 |
The error I'm getting in current master is not identical to 0002227. There may be multiple issues here. The original poster says to select all square faces. Problem is that a row of them is split by the cylindrical surface seam. When PartDesign Fillet/Chamfer takes a face selection, it attempts to proceed on all the edges extracted from the selected face, which creates an error with the seam edge. If I select all the faces as per the OP's instructions, after some recompute time I get an error dialog that says the resulting shape is invalid. There is no output in Python console nor Report view. If I remove the square faces split by the seam edge from the selection, then the Fillet succeeds. So, if we consider there are two issues here: 1) Operation fails without a warning: this is fixed in current master. A dialog window appears. 2) Operation fails because too many faces are selected: this is invalid, the real issue is an improper selection by the user. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9822 (Git) Build type: None Branch: master Hash: 0df4af4ba5e6edce825af6ecf6d024c704292633 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
I made a simple copy of the object (stripping it of its history) and saved in a new file to reduce its filesize and attach it here. |
There is still an issue: when trying to fillet the square faces split by the seam by selecting their edges rather than the face itself, it should succeed, but an error "Resulting shape is invalid" is thrown out. IMO this an upstream issue related to OCC. |
@normandc when you have a moment can you test on 7.1? |
@wmayer can you test on OCC 7.1 or higher ? |
@wmayer ping |
The issue with too many edges was fixed a long time ago with: https://github.com/FreeCAD/FreeCAD/commit/3c269f4ccd5680867246c63ea415ccf327182e96#diff-0c786c62e4e06db5627463b64786060e The problem was that the internal command string had a limit of 4024 characters. When a command had more the string was truncated and thus left an incorrect Python expression. In 0.17 there is no such limit any more. The issue that the fillet operation fails doesn't seem to exist in OCCT 7.0 any more. |
| 2015-10-26 09:18 | laurent.despeyroux | New Issue | |
| 2017-01-27 14:37 | Kunda1 | Tag Attached: duplicate | |
| 2017-01-28 10:59 | Kunda1 | Relationship added | related to 0002227 |
| 2017-01-28 11:01 | Kunda1 | Note Added: 0008040 | |
| 2017-01-28 11:02 | Kunda1 | Tag Detached: duplicate | |
| 2017-01-29 18:57 | Kunda1 | Tag Attached: OCC 7.1 | |
| 2017-01-29 18:57 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-01-29 18:57 | Kunda1 | Tag Attached: upstream | |
| 2017-01-29 18:58 | Kunda1 | Note Added: 0008088 | |
| 2017-01-29 19:28 | normandc | Note Added: 0008089 | |
| 2017-01-29 19:31 | normandc | File Added: initial-step_simple.FCStd | |
| 2017-01-29 19:32 | normandc | Note Added: 0008090 | |
| 2017-01-29 19:33 | normandc | Note Edited: 0008089 | |
| 2017-01-29 19:38 | normandc | Note Added: 0008091 | |
| 2017-01-29 20:07 | normandc | Note Edited: 0008089 | |
| 2017-03-16 12:20 | Kunda1 | Note Added: 0008640 | |
| 2017-12-01 00:59 | Kunda1 | Note Added: 0010504 | |
| 2018-01-18 13:28 | Kunda1 | Note Added: 0010785 | |
| 2018-01-18 14:35 | Kunda1 | Target Version | => 0.17 |
| 2018-01-30 16:34 | wmayer | Assigned To | => wmayer |
| 2018-01-30 16:34 | wmayer | Status | new => closed |
| 2018-01-30 16:34 | wmayer | Resolution | open => fixed |
| 2018-01-30 16:34 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-30 16:34 | wmayer | Note Added: 0010900 | |
| 2018-01-30 16:34 | wmayer | Note Edited: 0010900 | |
| 2018-01-30 16:35 | wmayer | Note Edited: 0010900 | |
| 2018-02-21 14:38 | Kunda1 | Relationship replaced | has duplicate 0002227 |
