| 0002403 | Draft | Bug | public | 2016-01-11 19:33 | 2017-06-16 12:48 |
| Reporter | JLB85FR | Assigned To | yorik | ||
| Platform | PC | OS | windows | OS Version | XP pro |
| Summary | 0002403: Problem on extrusions when inserting a window in a wall | ||||
| Description | When inserting a window into a wall, some or all the elements like extrusions present in the design are reported as having errors (No object linked, Cannot extrude empty shape (on extrude), A fatal error occurred when running boolean operation (on Cut). It can most of the time be repaired by deleting the window, but sometimes, the cut in the wall made by the window remains after window delete. Is there a way of repairing the design file ? | ||||
| Steps To Reproduce | see attachment. | ||||
Another hint message obtained on a facebinder present in the design: Facebinder : Local variable 'Part' referenced before assignment. On a wall already containing a subtracted extruded circle for instance, when trying to insert a window in the wall, the cut is not made in the wall at the place of the window. |
Hi and welcome This is more appropriate for the Help forum this is a link for future reference to the topic you created there http://forum.freecadweb.org/viewtopic.php?f=3&t=13867&p=110819#p110819 If you want to work with Arch, please upgrade to the latest FreeCAD you can get for your O/S, the dev version is currently very close to release 0.16. It has currently over 1500 bug fix and feature updates beyond 0.15. Release version do not usually get bugs fixed, any bugs found are fixed in the dev branch, so it is important to determine if any bug found in the release version (0.15 at this time) also also exist in the dev branch (0.16 currently), the Help forum is the best place to do this to save the same bug being reported many times over. I will close this ticket now, but feel free to create a new ticket if you distil this into a specific bug after first discussing it on the Help forum. Jim |
advised to discuss this first in the Help forums |
Errors were not present in release 0.16.6420 after a fix, but now on current one (0.16.6651), they still are there. when you open the project, no error is shown, but after just executing the 'recompute' macro, errors are agin on 2 'cuts'. I have kept the binary of 6420 and on this version recompute does not produce errors. I would like to attach a design file, how can I do this ? or should I open a new ticket ? I found it to attach a file ! new one is now attached. error seems not to hapen on the initial attached file. |
errors on 'cut' children of Wall_localtech. I would also ask for another thing on this same design: cannot move it properly (door is not properly shown after, because its parent wall does not move), but I have got no replies on the forum. OS: Windows XP Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.16.6651 (Git) Build type: Release Branch: master Hash: a69ee20f0c2acf146c935633ff43f933a8b14316 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
in design 'maison.FCstd', there are several components with undefined errors: 'Cut_porche' 'Cut_roof_localtech_west' 'Cut_roof_localtech_east' 'Cut_Ouest' 'Cut_roof_garage' |
Yorik, I have assigned this to you since it is your area, I think it is another example of the current cyclic dependency limitations, so I will leave it to you to decide what to do with this ticket etc. :-) Jim |
I don't know what to do with this report... Is there any bug? If yes please give me a step-by-step instruction to see the bug? Thanks. |
@JLB85FR please respond to 0002403:0007451 |
@JLB85FR last ping before I resolve this ticket. |
@jmaustpc please advise |
Closing ticket as unable to reproduce due to lack of response from OP. |
| 2016-01-11 19:33 | JLB85FR | New Issue | |
| 2016-01-11 19:33 | JLB85FR | File Added: test crash window A.zip | |
| 2016-01-12 19:59 | JLB85FR | Note Added: 0006712 | |
| 2016-01-16 06:03 | jmaustpc | Note Added: 0006720 | |
| 2016-01-16 06:04 | jmaustpc | Note Added: 0006721 | |
| 2016-01-16 06:04 | jmaustpc | Status | new => closed |
| 2016-01-16 06:04 | jmaustpc | Assigned To | => jmaustpc |
| 2016-01-16 06:04 | jmaustpc | Resolution | open => no change required |
| 2016-03-24 12:26 | JLB85FR | Note Added: 0006931 | |
| 2016-03-24 12:26 | JLB85FR | Status | closed => feedback |
| 2016-03-24 12:26 | JLB85FR | Resolution | no change required => reopened |
| 2016-03-24 12:30 | JLB85FR | File Added: move_building.FCStd | |
| 2016-03-24 12:32 | JLB85FR | Note Added: 0006932 | |
| 2016-03-24 12:32 | JLB85FR | Status | feedback => assigned |
| 2016-03-24 12:35 | JLB85FR | Note Edited: 0006931 | |
| 2016-03-25 13:30 | JLB85FR | File Added: maison.FCStd | |
| 2016-03-25 13:34 | JLB85FR | Note Added: 0006933 | |
| 2016-07-14 17:18 | jmaustpc | Assigned To | jmaustpc => yorik |
| 2016-07-14 17:20 | jmaustpc | Note Added: 0007190 | |
| 2016-11-12 19:12 | yorik | Note Added: 0007451 | |
| 2016-11-12 19:13 | yorik | Status | assigned => feedback |
| 2017-01-16 08:15 | Kunda1 | Note Added: 0007809 | |
| 2017-01-29 15:02 | Kunda1 | Note Added: 0008075 | |
| 2017-03-14 12:01 | Kunda1 | Relationship added | related to 0002449 |
| 2017-05-10 11:58 | Kunda1 | Note Added: 0008933 | |
| 2017-06-16 12:47 | Kunda1 | Status | feedback => resolved |
| 2017-06-16 12:47 | Kunda1 | Resolution | reopened => unable to reproduce |
| 2017-06-16 12:47 | Kunda1 | Fixed in Version | 0.16 => |
| 2017-06-16 12:47 | Kunda1 | Note Added: 0009410 | |
| 2017-06-16 12:48 | Kunda1 | Status | resolved => closed |
