| 0002449 | Arch | Bug | public | 2016-02-12 19:41 | 2017-03-14 12:01 |
| Reporter | JLB85FR | Assigned To | yorik | ||
| Platform | PC | OS | windows 32bit | OS Version | XP |
| Summary | 0002449: Adding a window when an extrude exists brings error on extrude | ||||
| Description | Already reported in bug 2403, this bug is still present in dev version. This occurs when adding a window in a wall, and if an extrude exists in the design. Executing a recompute macro can remove the error, but if we save the file then reopen it, the error comes back. Version used: dev 0.16.6415 See forum topic: Adding window breaks other extruded items in cut | ||||
| Steps To Reproduce | Create a line, make a wall from it, insert a window in the wall, create a circle anywhere else or in the wall, extrude the circle. Save, close all. Then reopen file. The design gets errors. No object linked on extrude. changing extrude length can remove the error, but save+close+open the design, error comes back. | ||||
| Additional Information | OS: Windows XP Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.16.6415 (Git) Build type: Release Branch: master Hash: 6a103493a18e5f2b0fc942e46ae11419ac90e015 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a | ||||
| 2016-02-12 19:41 | JLB85FR | New Issue | |
| 2016-02-12 19:41 | JLB85FR | File Added: wall+window+extrude.FCStd | |
| 2016-02-12 22:05 | yorik | Assigned To | => yorik |
| 2016-02-12 22:05 | yorik | Status | new => assigned |
| 2016-02-12 22:06 | yorik | Note Added: 0006828 | |
| 2016-02-12 22:21 | yorik | Changeset attached | => FreeCAD Master master a649c3ca |
| 2016-02-12 22:21 | yorik | Status | assigned => closed |
| 2016-02-12 22:21 | yorik | Resolution | open => fixed |
| 2016-02-12 22:21 | yorik | Fixed in Version | => 0.16 |
| 2017-03-14 12:01 | Kunda1 | Relationship added | related to 0002403 |
