| 0002463 | Sketcher | Bug | public | 2016-03-05 15:47 | 2018-12-20 13:00 |
| Reporter | flyhard | Assigned To | abdullah | ||
| Summary | 0002463: Trim tool ignore tangent constraint to arch on circle | ||||
| Description | If I have an arch end connected to a circle, and also in tangent to that circle, the Trim tool ignores that connection with the arch. Trying to trim away a circle segment between the arch and a line. It trims till next valid point, like a line connected. (see attached picture of sequence) | ||||
| Steps To Reproduce | 1. Draw a circle 2. Draw an arch with one end tangent to the circle 3. Draw two lines connected to, or through the circle (just as a break for the trim operation below) 4. Try to trim the circle segment between the arch and one of the lines ->The trim operation ignores the arch connection. 5. Use a line as a "tool", connected to where the arch connects to the circle, to stop the trim operation | ||||
| Additional Information | Im running FreeCAD version 0.16. In my attached picture, the arch is the one connected to the circle at 10 o'clock | ||||
| Tags | constraints, OCC 7.4, OCC Bug, Solver, trim, upstream | ||||
| related to | 0001576 | closed | Slow performance using trim tool ( |
Added Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20154 Replaced attached png with smaller sized jpg in order for better display |
@NormandC wrote: Confirmed. The Report view shows this error:
But this issue has been known for a long time, and there may be existing tickets about it.OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10893 (Git) Build type: None Branch: master Hash: a75a98ef279e9e067abf5cef3a6de6f09fba2c94 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
Confirming ticket based on NormandC's feedback. |
Since this is a long standing bug I'm assigning to release 0.17 roadmap. If not practical can be bumped to release after that. |
The problem is that the underlying intersection routines are not detecting the intersection between the line and the circunference WHEN it is tangent. Dragging the farthest away point so as not to make it tangent leads to it being detected. I have rewritten the intersection routine in my branch to use another OCCT function (Extrema algorithm). However, it also fails only with the tangent line. Either it is that: i. We are using OCCT wrongly (which is strange as for non-tangent it works nicely) ii. These algorithms were not designed for the tangency case (which is strange as the documentation says it detects tangencies at least as segments, NbSegments). iii. There is a bug in the OCCT routines. Here some further investigation: https://forum.freecadweb.org/viewtopic.php?f=10&t=31371#p260542 |
Bug filed against OCCT 7.3: https://tracker.dev.opencascade.org/view.php?id=30217 |
Changed target to 0.19, as it appears to depend on OCCT. |
tagged the ticket as well to keep track of upstream OCC bugs |
Work-around PR: https://github.com/FreeCAD/FreeCAD/pull/1755 |
https://github.com/FreeCAD/FreeCAD/commit/e10068a648b2f783a2a295f132b8e36d1717fa4e |
Removed ticket from 0.19 roadmap and added to 0.18 instead |
| 2016-03-05 15:47 | flyhard | New Issue | |
| 2016-03-05 15:47 | flyhard | File Added: Graphic summary.png | |
| 2017-01-23 18:36 | Kunda1 | Relationship added | related to 0001576 |
| 2017-01-23 18:41 | Kunda1 | File Added: Graphic summary.jpg | |
| 2017-01-23 18:41 | Kunda1 | File Deleted: Graphic summary.png | |
| 2017-01-23 18:43 | Kunda1 | Note Added: 0007920 | |
| 2017-04-26 02:43 | Kunda1 | Note Added: 0008766 | |
| 2017-04-26 02:44 | Kunda1 | Status | new => confirmed |
| 2017-04-26 02:44 | Kunda1 | Note Added: 0008767 | |
| 2017-04-26 02:44 | Kunda1 | Priority | high => normal |
| 2017-04-26 02:44 | Kunda1 | Product Version | => 0.16 |
| 2017-05-12 12:19 | Kunda1 | Tag Attached: Solver | |
| 2017-05-12 12:19 | Kunda1 | Tag Attached: trim | |
| 2017-06-28 22:35 | Kunda1 | Tag Attached: constraints | |
| 2017-06-28 22:53 | Kunda1 | Target Version | => 0.17 |
| 2017-06-28 22:53 | Kunda1 | Note Added: 0009590 | |
| 2018-04-27 10:04 | abdullah | Project | GCS => Sketcher |
| 2018-06-07 19:11 | Kunda1 | Target Version | 0.17 => 0.18 |
| 2018-10-06 05:45 | abdullah | Note Added: 0011939 | |
| 2018-10-08 14:00 | abdullah | Note Added: 0011966 | |
| 2018-10-08 14:02 | abdullah | Target Version | 0.18 => 0.19 |
| 2018-10-08 14:03 | abdullah | Note Added: 0011967 | |
| 2018-10-08 14:04 | Kunda1 | Tag Attached: OCC Bug | |
| 2018-10-08 14:04 | Kunda1 | Tag Attached: upstream | |
| 2018-10-08 14:04 | Kunda1 | Tag Attached: OCC 7.4 | |
| 2018-10-08 14:05 | Kunda1 | Note Added: 0011968 | |
| 2018-10-08 14:05 | Kunda1 | Note Edited: 0011968 | |
| 2018-10-28 18:32 | abdullah | Note Added: 0012110 | |
| 2018-10-30 12:49 | wmayer | Assigned To | => abdullah |
| 2018-10-30 12:49 | wmayer | Status | confirmed => closed |
| 2018-10-30 12:49 | wmayer | Resolution | open => fixed |
| 2018-10-30 12:49 | wmayer | Fixed in Version | => 0.18 |
| 2018-10-30 12:49 | wmayer | Note Added: 0012117 | |
| 2018-12-20 13:00 | Kunda1 | Target Version | 0.19 => 0.18 |
| 2018-12-20 13:00 | Kunda1 | Note Added: 0012329 |
