| 0002477 | Expressions | Bug | public | 2016-03-15 17:40 | 2021-02-06 06:30 |
| Reporter | Hastux | Assigned To | realthunder | ||
| Platform | Linux | OS | Ubuntu | OS Version | 15.10 |
| Summary | 0002477: Copy of sub objects with expression pointing to a spreadsheet shall not create a new spreadsheet | ||||
| Description | Version: 0.16 Revision: 6621 (Git) System: Ubuntu with ppa/daily When copying an object with expression linked to a spreadsheet (containing alias as variables), the dialog box ask to copy or not linked objects. When we answer yes, it copies the objects, and also create a new spreadsheet. The original object is pointing to the new spreadsheet and the new one to the original spreadsheet. It is not clearly a bug, because all is copied as asked, but it is really annoying to change all expression to point to a single spreadsheet. Proposition: ask to not copy or not the spreadsheet when a link between an expression and a spreadsheet is detected PS: A great thanks to all of you, working in the shadow, this software is better and better | ||||
| Steps To Reproduce | -Create a spreadsheet ('var') with an alias ('x') pointing to a value -Create an object an set and expression pointing to this alias (length = var.x) -Create an array of this object -Copy the array and answer yes to copy dependencies | ||||
| Tags | expressions, spreadsheet | ||||
| related to | 0003271 | closed | realthunder | Relative file references give 'Document not found' unless that file is opened first |
| related to | 0003272 | new | Failed to parse expression occurs when referencing an alias in an external spreadsheet document |
I'm not able to recreate this problem in 0.16r6706. I get the objects duplicated, but no dependencies are created to the new spreadsheet, so this can easily be removed afterwards. |
@eivindkvedalen FYI, the latest stable 0.16 is revision 6712 |
@eivindkvedalen can this issue be closed ? |
No, I see room for improvement on this one, so we shouldn't close it. |
I confirm this issue as described is present on 0.18.15316_x64_dev_win. Let me know if you need a detailed scenario or project. |
After this commit in upstream, a dialog will popup when the user copies any object with dependency. User has full control on which dependencies to copy. The commit is huge as it is done during the big merge. The object selection is done with DlgObjectSelection. Just search the source tree for usage of this class. In addition, with this commit (inside a pending PR), the expression can auto change its reference to/from internal/external reference depending on whether the referenced object is copied to the external document or not. For example, assuming there is a spreadsheet referencing a sketch in the same document (DocA) as 'Sketch.Constraints.myConstraint'. And now if the spreadsheet is copied into an external document, but the referenced sketch object is not copied together. The expression will be auto changed to 'DocA#Sketch.Constraints.myConstraint'. |
This ticket has been migrated to GitHub as issue 5647. |
| 2016-03-15 17:40 | Hastux | New Issue | |
| 2017-01-06 16:30 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2017-01-06 16:30 | eivindkvedalen | Status | new => assigned |
| 2017-01-19 14:25 | Kunda1 | Tag Attached: spreadsheet | |
| 2017-05-07 15:01 | Kunda1 | Tag Attached: expressions | |
| 2017-07-26 09:52 | eivindkvedalen | Note Added: 0009824 | |
| 2017-07-26 10:59 | Kunda1 | Note Added: 0009826 | |
| 2017-11-10 16:57 | Kunda1 | Note Added: 0010408 | |
| 2017-11-11 09:12 | eivindkvedalen | Note Added: 0010409 | |
| 2017-12-09 12:55 | Kunda1 | Relationship added | related to 0003271 |
| 2017-12-09 13:03 | Kunda1 | Relationship added | related to 0003272 |
| 2017-12-13 15:27 | Kunda1 | Project | FreeCAD => Expressions |
| 2018-12-04 00:15 | Sergei Kulik | Note Added: 0012236 | |
| 2020-02-27 08:59 | realthunder | Note Added: 0014189 | |
| 2020-02-27 18:11 | Kunda1 | Assigned To | eivindkvedalen => realthunder |
