| 0003271 | Expressions | General | public | 2017-11-27 01:15 | 2020-03-22 17:36 |
| Reporter | bgoodr | Assigned To | realthunder | ||
| Summary | 0003271: Relative file references give 'Document not found' unless that file is opened first | ||||
| Description | Version info: OS: Ubuntu 17.04 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12643 (Git) Build type: None Branch: master Hash: 868d9cc6c215ce3a2ab20d454378ec00e1b9ed26 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) Apparently, spreadsheets have to be opened before they can be used. Not sure if it is due to their being relative file paths, but it should not matter. If I reference an alias in a spreadsheet from the value of a constraint in a sketch, the application should know how to read that alias value and use it, and not say "document not found". A full GIF of the error is shown in the attached screencapture-gif-0012.gif file (also includes another issue with failing to parse an error that I will file a separate bug after I finish filing this one). EDIT: See 0003272 | ||||
| Steps To Reproduce |
| Tags | expressions, sketcher, spreadsheet | ||||
| related to | 0002477 | assigned | realthunder | Copy of sub objects with expression pointing to a spreadsheet shall not create a new spreadsheet |
| related to | 0003272 | new | Failed to parse expression occurs when referencing an alias in an external spreadsheet document |
There is some precedence for this already. See https://forum.freecad.org/viewtopic.php?f=3&t=15231&p=168146&hilit=Failed+to+parse+expression.#p168146 |
@eivindkvedalen care to weigh in ? |
Forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=25796 |
Changed from bug -> feature
With this commit in upstream, the expression (PropertyExpressionEngine/PropertySheet to be exactly) gained the ability to automatically load the linked external document. For existing document authored in previous version of FreeCAD, manually load all the files in newer version FreeCAD, and save all of them to enable auto loading. |
FreeCAD master 93e60caa |
Fixed and closed. Thanks realthunder! |
FreeCAD: master 93e60caa 2019-06-29 09:30:51 Zheng, Lei Committer: wmayer Details Diff |
PropertyExpressionEngine: convert to link type property PropertyExpressionEngine is changed to derived from a new class PropertyExpressionContainer, which is in turn derives from PropertyXLinkContainer. This makes PropertyExpressionEngine a link type property that is capable of external linking. It now uses the unified link property APIs for dependency management and tracking of object life time, re-labeling, etc. ObjectIdentifier is modified to support sub-object reference, but is not exposed to end-user, because expression syntax is kept mostly unchanged, which will be submitted in future PR. There is, however, one small change in expression syntax (ExpressionParser.y) to introduce local property reference to avoid ambiguity mentioned in FreeCAD/FreeCAD#1619 Modified Expression/ExpressionModifier interface to support various link property API for link modification. |
Affected Issues 0003271 |
| mod - src/App/Document.cpp | Diff File | ||
| mod - src/App/DocumentObject.cpp | Diff File | ||
| mod - src/App/DocumentObject.h | Diff File | ||
| mod - src/App/DocumentObjectPy.xml | Diff File | ||
| mod - src/App/DocumentObjectPyImp.cpp | Diff File | ||
| mod - src/App/Expression.cpp | Diff File | ||
| mod - src/App/Expression.h | Diff File | ||
| mod - src/App/ExpressionParser.tab.c | Diff File | ||
| mod - src/App/ExpressionParser.y | Diff File | ||
| mod - src/App/ExpressionVisitors.h | Diff File | ||
| mod - src/App/ObjectIdentifier.cpp | Diff File | ||
| mod - src/App/ObjectIdentifier.h | Diff File | ||
| mod - src/App/Property.h | Diff File | ||
| mod - src/App/PropertyExpressionEngine.cpp | Diff File | ||
| mod - src/App/PropertyExpressionEngine.h | Diff File | ||
| mod - src/App/PropertyGeo.cpp | Diff File | ||
| mod - src/App/PropertyGeo.h | Diff File | ||
| mod - src/App/PropertyUnits.cpp | Diff File | ||
| mod - src/App/Range.cpp | Diff File | ||
| mod - src/App/Range.h | Diff File | ||
| mod - src/Mod/Sketcher/App/PropertyConstraintList.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/PropertyConstraintList.h | Diff File | ||
| 2017-11-27 01:15 | bgoodr | New Issue | |
| 2017-11-27 01:15 | bgoodr | File Added: UpsideDownMonitorMount.tar.gz | |
| 2017-11-27 01:15 | bgoodr | File Added: screencapture-gif-0012.gif | |
| 2017-11-27 01:15 | bgoodr | Tag Attached: expressions | |
| 2017-11-27 01:15 | bgoodr | Tag Attached: sketcher | |
| 2017-11-27 01:15 | bgoodr | Tag Attached: spreadsheet | |
| 2017-11-27 01:17 | bgoodr | Note Added: 0010476 | |
| 2017-11-27 01:17 | bgoodr | Note Edited: 0010476 | |
| 2017-11-27 02:58 | Kunda1 | Note Added: 0010477 | |
| 2017-11-27 03:00 | Kunda1 | Relationship added | related to 0003272 |
| 2017-11-27 03:01 | Kunda1 | Description Updated | |
| 2017-12-09 12:22 | Kunda1 | Note Added: 0010553 | |
| 2017-12-09 12:44 | Kunda1 | Category | Bug => Feature |
| 2017-12-09 12:44 | Kunda1 | Note Added: 0010557 | |
| 2017-12-09 12:44 | Kunda1 | Summary | Relative file references give Document not found unless that file is opened first => Relative file references give 'Document not found' unless that file is opened first |
| 2017-12-09 12:45 | Kunda1 | Note Edited: 0010557 | |
| 2017-12-09 12:55 | Kunda1 | Relationship added | related to 0002477 |
| 2017-12-13 15:27 | Kunda1 | Project | Sketcher => Expressions |
| 2017-12-13 15:27 | Kunda1 | Category | Feature => General |
| 2020-02-27 06:06 | realthunder | Note Added: 0014188 | |
| 2020-02-27 18:10 | Kunda1 | Assigned To | => realthunder |
| 2020-02-27 18:10 | Kunda1 | Status | new => assigned |
| 2020-03-22 17:22 | Kunda1 | Note Added: 0014257 | |
| 2020-03-22 17:22 | Kunda1 | Changeset attached | => FreeCAD master 93e60caa |
| 2020-03-22 17:36 | Kunda1 | Status | assigned => closed |
| 2020-03-22 17:36 | Kunda1 | Resolution | open => fixed |
| 2020-03-22 17:36 | Kunda1 | Fixed in Version | => 0.19 |
| 2020-03-22 17:36 | Kunda1 | Note Added: 0014258 |
