| 0002501 | PartDesign | Bug | public | 2016-04-14 06:42 | 2017-03-20 09:45 |
| Reporter | ickby | Assigned To | ickby | ||
| Summary | 0002501: Mirror feature don't accept datum plane | ||||
| Description | The mirror feature currently does not work with datum planes, they can not be choosen in the dialog or be selected in the 3d view. This also holds for Multitransform including mirror features. | ||||
| Steps To Reproduce | 1. Create a datum plane 2. Create an additive or subtractive feature which can be mirrored in respect to the datum plane 3. Mirror the feature via Mirror pattern tool 4. Select datum plane as mirror plane | ||||
| related to | 0002862 | closed | wmayer | Check for shape type before using selection as base feature |
| related to | 0002941 | closed | DeepSOIC | Part Design NEXT Polar array does not allow to select a datum line as reference |
| related to | 0002863 | assigned | ickby | Add Mirror body feature to PartDesign |
| related to | 0002859 | closed | DeepSOIC | unable to use datum plane as external reference |
| 2016-04-14 06:42 | ickby | New Issue | |
| 2016-04-14 06:42 | ickby | Status | new => assigned |
| 2016-04-14 06:42 | ickby | Assigned To | => ickby |
| 2017-03-02 18:17 | Kunda1 | Relationship added | related to 0002863 |
| 2017-03-17 18:46 | Kunda1 | Relationship added | related to 0002859 |
| 2017-03-17 18:47 | Kunda1 | Relationship added | related to 0002862 |
| 2017-03-17 18:47 | Kunda1 | Relationship added | related to 0002941 |
| 2017-03-20 09:43 | wmayer | Changeset attached | => FreeCAD master 0d81472f |
| 2017-03-20 09:45 | wmayer | Status | assigned => closed |
| 2017-03-20 09:45 | wmayer | Resolution | open => fixed |
| 2017-03-20 09:45 | wmayer | Fixed in Version | => 0.17 |
