| 0002859 | PartDesign | Bug | public | 2017-01-15 14:01 | 2017-03-20 09:44 |
| Reporter | nemesis | Assigned To | DeepSOIC | ||
| Platform | x64 | OS | OSX | OS Version | OSX 10.11.6 |
| Summary | 0002859: unable to use datum plane as external reference | ||||
| Description | it's impossible to use a Datum plane as external reference within a sketch until the document has been closed and re-opened | ||||
| Steps To Reproduce | 1 - Create a new doc 2 - create a datum plane (// to YZ for example) 3 - Create a sketch on XY 4 - try to use datum plane as external reference, it is impossible to click it. 5 - save the file 6 - Close the file 7 - re-open the file 8 - open the sketch. 9 - now you can use the datum plane as external reference. 10 - now you are in bug 0002682 | ||||
| Tags | Part Design, planes, sketcher | ||||
| related to | 0002682 | closed | jnxd | constraint to external datum plane disappear after saving a file, or re-opening a sketch |
| related to | 0002501 | closed | ickby | Mirror feature don't accept datum plane |
| related to | 0002941 | closed | DeepSOIC | Part Design NEXT Polar array does not allow to select a datum line as reference |
OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9641 (Git) Build type: Release Branch: (detached from d8afbe5) Hash: d8afbe563e52281daac5fa63b12ef2e9efc61e9e Python version: 2.7.13 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 7.0.0 I also notice that I'm unable to select datum in the 3D view until the document has been saved and re-opened |
Forum thread: http://forum.freecad.org/viewtopic.php?f=3&t=17126&p=153532#p153532 |
indee. you can use the plane a sketch base before saving, but you need to select it in the tree. then draw a sketch close the sketch try to select the sketch in the 3D view: you have message in the status bar sayin "selecting this will cause a circular dependency" OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9841 (Git) Build type: Release Branch: master Hash: fa4b5d29b52b576335897d8b3436f8a847191b2e Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.0.0 |
@nemesis you'll generate more discussion by adding your note to the thread :) |
| 2017-01-15 14:01 | nemesis | New Issue | |
| 2017-01-15 14:02 | nemesis | Note Added: 0007789 | |
| 2017-01-15 14:04 | nemesis | Note Edited: 0007789 | |
| 2017-01-15 14:17 | Kunda1 | Steps to Reproduce Updated | |
| 2017-01-15 14:17 | Kunda1 | Relationship added | related to 0002682 |
| 2017-01-15 14:18 | Kunda1 | Note Added: 0007791 | |
| 2017-02-02 21:40 | nemesis | Note Added: 0008181 | |
| 2017-02-02 21:40 | nemesis | Note Edited: 0008181 | |
| 2017-02-02 21:41 | nemesis | Tag Attached: Part Design | |
| 2017-02-02 21:42 | nemesis | Tag Attached: planes | |
| 2017-02-02 21:42 | nemesis | Tag Attached: sketcher | |
| 2017-02-02 21:55 | Kunda1 | Note Added: 0008182 | |
| 2017-02-15 05:51 | kkremitzki | Target Version | => 0.17 |
| 2017-03-17 18:45 | Kunda1 | Relationship added | related to 0002941 |
| 2017-03-17 18:46 | Kunda1 | Relationship added | related to 0002501 |
| 2017-03-20 09:42 | wmayer | Changeset attached | => FreeCAD master 0d81472f |
| 2017-03-20 09:44 | wmayer | Assigned To | => DeepSOIC |
| 2017-03-20 09:44 | wmayer | Status | new => closed |
| 2017-03-20 09:44 | wmayer | Resolution | open => fixed |
| 2017-03-20 09:44 | wmayer | Fixed in Version | => 0.17 |
