| 0002564 | FreeCAD | Bug | public | 2016-05-28 20:26 | 2017-08-28 19:41 |
| Reporter | KarenRei | Assigned To | |||
| Platform | Fedora 22 | ||||
| Summary | 0002564: Crash in refine shape | ||||
| Description | FreeCAD crashes when doing Refine Shape on this model: https://drive.google.com/open?id=0B6KWLyPRYMb0Z2F4YXR0N0JacW8 GDB trace: Program received signal SIGSEGV, Segmentation fault. BRepTools_ReShape::Replace (this=0xfefdfefdfefd0000, ashape=..., anewshape=..., oriented=oriented@entry=false) at /usr/src/debug/oce-OCE-0.16.1/src/BRepTools/BRepTools_ReShape.cxx:146 146 if (myConsiderLocation) { (gdb) bt #0 0x00007fff6aca88d9 in BRepTools_ReShape::Replace(TopoDS_Shape const&, TopoDS_Shape const&, bool) (this=0xfefdfefdfefd0000, ashape=..., anewshape=..., oriented=oriented@entry=false) at /usr/src/debug/oce-OCE-0.16.1/src/BRepTools/BRepTools_ReShape.cxx:146 #1 0x00007fff6c221b22 in ShapeFix_Face::FixSplitFace(TopTools_DataMapOfShapeListOfShape const&) (this=this@entry=0x7fffffff9f90, MapWires=...) at /usr/src/debug/oce-OCE-0.16.1/src/ShapeFix/ShapeFix_Face.cxx:2264 0000002 0x00007fff6c229973 in ShapeFix_Face::Perform() (this=this@entry=0x7fffffff9f90) at /usr/src/debug/oce-OCE-0.16.1/src/ShapeFix/ShapeFix_Face.cxx:655 0000003 0x00007fff81373bf4 in ModelRefine::FaceUniter::process() (this=this@entry=0x7fffffffa460) at /usr/src/debug/freecad/src/Mod/Part/App/modelRefine.cpp:1098 0000004 0x00007fff813654ee in Part::TopoShape::removeSplitter() const (this= 0x8a64bb0) at /usr/src/debug/freecad/src/Mod/Part/App/TopoShape.cpp:2360 0000005 0x00007fff812c7fec in Part::TopoShapePy::removeSplitter(_object*) (this=0x82aa5e0, args=<optimized out>) at /usr/src/debug/freecad/src/Mod/Part/App/TopoShapePyImp.cpp:1636 0000006 0x00007fff812c81bc in Part::TopoShapePy::staticCallback_removeSplitter(_object*, _object*) (self=<optimized out>, args=<optimized out>) at /usr/src/debug/freecad/build/src/Mod/Part/App/TopoShapePy.cpp:4750 0000007 0x00007ffff65e68be in PyEval_EvalFrameEx (oparg=<optimized out>, pp_stack=0x7fffffffa6d0) at /usr/src/debug/Python-2.7.10/Python/ceval.c:4112 0000008 0x00007ffff65e68be in PyEval_EvalFrameEx (f=f@entry= Frame 0x7fffcc708ad0, for file <string>, line 1, in <module> (), throwflag=throwflag@entry=0) at /usr/src/debug/Python-2.7.10/Python/ceval.c:2755 0000009 0x00007ffff65e76b4 in PyEval_EvalCodeEx (co=co@entry=0x7fffccd968b0, globals=globals@entry= The model is an imported OBJ from Blender; the original is seamless/waterproof and shouldn't have anything wrong with it. All I did was import and then "Create shape from mesh". | ||||
| Steps To Reproduce | 1. Load file. 2. Do refine shape. 3. Wait. Or, from the .obj: 1. Open it. 2. Shape from mesh 3. Refine shape 4. Wait | ||||
| Additional Information | OS: "Fedora release 22 (Twenty Two)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7680 (Git) Build type: Unknown Branch: master Hash: 966ce79207da593db8a7848e23c82f4d3baad27c Python version: 2.7.10 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.7.1.oce-0.16 | ||||
| related to | 0002565 | closed | Infinite (?) loop in "Create shape from mesh" |
Okay, there seems to be a problem on top of a problem. One, the crash shouldn't occur. Two, it seems to be corrupting the .obj. It loads just fine in blender, but when I zoom in in FreeCAD I can see holes in the model. |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19919 |
Loading the gh2.fcstd file, the Report view lists two errors: >The mesh data structure has some defects >Cannot compute Inventor representation for the shape of gh001. The last one explains why gh001 is not visible in the 3D view. After importing the original gh.obj mesh in FreeCAD, the Analyze --> Evaluate & Repair mesh tool from the Mesh Design workbench reports more than 10,000 issues of non-manifolds, folds on surfaces and other errors. I don't know how to evaluate a mesh in Blender, but it looks fine. So it seems the OBJ seems to get corrupted when imported into FreeCAD. From that point, FreeCAD cannot be expected to produce a valid shape, nor produce a refined shape. But it should not make FreeCAD crash. |
@KarenRei please continue the discussion in the forum thread. Thanks |
@wmayer do you mind weighing in on why FreeCAD crashes here? |
@yorik when you get a moment do you mind weighing in on this crash bug? |
@chrisb do you mind weighing in? |
chrisb can't reproduce crash or an issues per https://forum.freecadweb.org/viewtopic.php?p=187604#p187604
Resolving ticket for now. |
No response from @KarenRei Closing. |
| 2016-05-28 20:26 | KarenRei | New Issue | |
| 2016-05-28 20:26 | KarenRei | File Added: gh.obj | |
| 2016-05-28 20:51 | KarenRei | Note Added: 0007121 | |
| 2017-01-15 14:22 | Kunda1 | Note Added: 0007792 | |
| 2017-01-15 22:33 | normandc | Note Added: 0007801 | |
| 2017-01-16 02:36 | Kunda1 | Status | new => confirmed |
| 2017-01-17 05:02 | Kunda1 | Relationship added | related to 0002565 |
| 2017-02-18 12:06 | Kunda1 | Note Added: 0008344 | |
| 2017-02-18 12:07 | Kunda1 | Target Version | => 0.17 |
| 2017-03-14 11:58 | Kunda1 | Note Added: 0008627 | |
| 2017-03-21 12:35 | Kunda1 | Note Added: 0008676 | |
| 2017-08-21 10:59 | Kunda1 | Note Added: 0009973 | |
| 2017-08-21 19:59 | Kunda1 | Status | confirmed => resolved |
| 2017-08-21 19:59 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-08-21 19:59 | Kunda1 | Note Added: 0009983 | |
| 2017-08-21 20:00 | Kunda1 | Note Edited: 0009983 | |
| 2017-08-28 19:41 | Kunda1 | Note Added: 0010035 | |
| 2017-08-28 19:41 | Kunda1 | Status | resolved => closed |
