| 0002591 | Draft | Bug | public | 2016-06-15 20:26 | 2017-04-26 19:04 |
| Reporter | mickele | Assigned To | |||
| Platform | Linux | OS | ArchLinux | OS Version | Current |
| Summary | 0002591: Wrong view of a compound of cylinders | ||||
| Description | I created a compound of three cylinders perpendicular to each other. In draft module, view on XY plane is wrong containing lines that shouldn't be visible. | ||||
| Steps To Reproduce | Create three cylinders with following data: Cylinder 1 - radius: 10 - height: 100 - axis 0,1,0 - angle 90° - position 0,0,0 Cylinder 2 - radius: 10 - height: 100 - axis 0,1,0 - angle 90° - position 0,50,50 Cylinder 2 - radius: 8 - height: 70 - axis -1,0,0 - angle 45° - position 50,0,0 Fuse the cylinders. In draft module, create a shape2DView of the fusion object. View contains segments that shouldn't be visible. | ||||
| Tags | OCC 7.1, OCC Bug, upstream | ||||
I had the same behaviour on Debian and Windows. |
@mickele please post Help > About FreeCAD > 'Copy to clipboard' for all systems you confirmed this on. Also in the future please open a forum thread first before opening a ticket. Nevertheless, thanks for the report. Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20310 |
IMO this bug is dependent on upstream OCC's hidden line algorithm, thus it is essential to know what OCC version the bug appears in. OCC 7.1.0 brings relevant fixes, this needs to be tested with FreeCAD compiled with OCC 7.1.0. To check the file in a different version of FreeCAD/OCC, a force recompute is necessary. In python console: import FreeCAD for obj in FreeCAD.ActiveDocument.Objects: obj.touch() FreeCAD.ActiveDocument.recompute() Attached "bug2591-test-cylinder-original.png" shows how Shape2DView object appears in the original file. Attached "bug2591-test-cylinder-OCC6.8.0.png" shows how it appears after a force recompute on the following FreeCAD version. Better, but still not perfect. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
@normandc since you've successfully compiled FC with OCC7.1.0 do you mind testing this again? |
@NormandC wrote: The bug appears to be fixed in OCCT 7.1.0. Even with Hidden Lines parameter set to "True", all lines show properly (with the addition of cylinder seam lines, but that is to be expected). OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10792 (Git) Build type: None Branch: master Hash: 3b50a786f351339dd0c791b4e0e0e403f86033f0 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Note: NormandC attached 2 images showing bugs were not reproducible but said images did not survive the backup. |
Per NormandC's feedback, resolving this ticket as Fixed Upstream OCC v7.1.0. |
| 2016-06-15 20:26 | mickele | New Issue | |
| 2016-06-15 20:26 | mickele | File Added: test-cylinder.FCStd | |
| 2016-06-15 20:27 | mickele | Note Added: 0007150 | |
| 2017-01-28 12:53 | Kunda1 | Note Added: 0008051 | |
| 2017-01-28 12:53 | Kunda1 | Status | new => feedback |
| 2017-01-28 19:25 | normandc | Note Added: 0008062 | |
| 2017-01-28 19:26 | normandc | File Added: bug2591-test-cylinder-original.png | |
| 2017-01-28 19:26 | normandc | File Added: bug2591-test-cylinder-OCC6.8.0.png | |
| 2017-01-28 19:30 | Kunda1 | Tag Attached: OCC 7.1 | |
| 2017-01-28 19:30 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-01-28 19:30 | Kunda1 | Tag Attached: upstream | |
| 2017-03-06 23:36 | Kunda1 | Note Added: 0008555 | |
| 2017-04-26 18:59 | Kunda1 | Note Added: 0008780 | |
| 2017-04-26 19:02 | Kunda1 | Status | feedback => closed |
| 2017-04-26 19:02 | Kunda1 | Resolution | open => fixed |
| 2017-04-26 19:02 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-04-26 19:02 | Kunda1 | Note Added: 0008781 | |
| 2017-04-26 19:04 | Kunda1 | Summary | Wrong view of a compund of cylinders => Wrong view of a compound of cylinders |
