| 0002642 | PartDesign | Bug | public | 2016-07-26 10:56 | 2017-09-24 21:58 |
| Reporter | ian.rees | Assigned To | |||
| OS | MacOS | OS Version | 10.11 | ||
| Summary | 0002642: Can't open saved file (undiscovered bug/s from PDN?) | ||||
| Description | Should mention that I haven't spent much time in FreeCAD lately, so might be doing something dumb... Attached file seemed to be working OK from what I noticed, but now can't open it. Report view shows: Can't find Origin for "Body" Can't find Origin for "Body" Can't find Origin for "Body001" Can't find Origin for "Body001" Fatal Error at file GuiDocument.xml, line 872, char 30 Reading failed from embedded file: GuiDocument.xml (83898 bytes, 3209 bytes compressed) There should be two separate Bodies; the first one opens but second doesn't. That part of GuiDocument.xml seems a bit funky - Vim shows <ViewProvider name="^\<9a><8f><93>^?" expanded="0"> , but when I try to copy-and-paste in to Chrome it shows: <ViewProvider name="??" expanded="0">. | ||||
| Additional Information | OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8046 (Git) Build type: Debug Branch: master Hash: 67458d5bd2d3518adc02caf0fa89b62c06a48eb4 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 7.0.0 | ||||
| Tags | Part Design | ||||
| related to | 0002857 | closed | Placement incorrect in exported files |
The XML has some strange characters which you can actually only determine with a hex-editor. When doing so the sequence e.g. is: 0x9a 0x8f 0x93 0x7f but there are a few places more with funny characters. When looking at the Document.xml you can see that it contains 26 objects but the GuiDocument.xml has 31 view providers which cannot be correct. Now when going through the view provider names there are three with strange names and two have no name -- five invalid ones. So, my guess is that at some point you have deleted a few objects but their view providers were not removed from the document which IMO must be another undiscovered bug from the PartDesignNext branch. This would explain the funny characters. The easiest to repair your project is by deleting the GuiDocument.xml from the zip file. |
renamed for better comprehension |
@kunda1 I think this report does not allow to reproduce the issue. Yes, definitely something happened that originated those characters in the file. A solution was provided to try to recover the data. However we can not or reproduce what originated it. As such, if the people involved have nothing against it, it may be better to close it. |
There are two separate issues here - one is that the file got corrupted, the second is that FreeCAD didn't handle the corrupted file well. I'd prefer to leave the bug; even if there isn't a good way to reproduce the first part, the second would be nice to fix. |
@ian.rees Sorry Ian, I did not understand from the report that you wanted a change of behaviour in FreeCAD when opening a corrupted file. I am not sure how you would expect FreeCAD to handle the corrupted file (it did not crash, it complained about something it could not understand). The provided workaround by Werner relies on the fact that Werner as a human figures it out which ViewProviders to remove, so that they match in number. In any case, of course, if there is something that needs fixing, there is no reason to close the bug report. |
No need to apologise - the bug was just to record some weird behaviour. I think it should be fairly easy to make FreeCAD handle this type of issue better - if there's an issue opening the file due to the view stuff, just (optionally?) try opening the file without it. But, I don't have time for FreeCAD lately and likely won't for a few more weeks. |
With https://github.com/FreeCAD/FreeCAD/commit/276781fb07b1c55e69b32f8ee976ece2406e2443 the dependencies of the objects are restored. The xerces-c xml parser raises an exception when it reaches the invalid characters and thus it's not possible to read completely in GuiDocument.xml. This however only results into missing visual properties but the data are all read in -- so no loss of data. The reason of the broken xml must be bugs in an early implementation of PDN which have been fixed in the meantime. |
| 2016-07-26 10:56 | ian.rees | New Issue | |
| 2016-07-26 10:56 | ian.rees | File Added: spool pulley GT2.FCStd | |
| 2016-07-26 10:56 | ian.rees | Tag Attached: Part Design | |
| 2016-07-27 06:25 | ian.rees | Project | Assembly => PartDesign |
| 2016-07-27 19:55 | wmayer | Note Added: 0007217 | |
| 2016-07-27 19:55 | wmayer | Status | new => confirmed |
| 2017-01-12 12:28 | Kunda1 | Note Added: 0007666 | |
| 2017-01-12 12:28 | Kunda1 | Summary | Can't open saved file. => Can't open saved file (undiscovered bug/s from PDN?) |
| 2017-02-14 12:17 | kkremitzki | Target Version | => 0.17 |
| 2017-05-11 12:37 | Kunda1 | Relationship added | related to 0002857 |
| 2017-05-29 13:58 | abdullah | Note Added: 0009185 | |
| 2017-05-29 15:50 | Kunda1 | Status | confirmed => feedback |
| 2017-05-29 18:12 | ian.rees | Note Added: 0009188 | |
| 2017-05-29 18:12 | ian.rees | Status | feedback => new |
| 2017-05-29 19:33 | Kunda1 | Status | new => confirmed |
| 2017-05-29 20:21 | abdullah | Note Added: 0009189 | |
| 2017-05-29 20:32 | ian.rees | Note Added: 0009190 | |
| 2017-09-24 21:58 | wmayer | Status | confirmed => closed |
| 2017-09-24 21:58 | wmayer | Resolution | open => fixed |
| 2017-09-24 21:58 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-24 21:58 | wmayer | Note Added: 0010178 |
