| 0002857 | PartDesign | Bug | public | 2017-01-14 10:32 | 2018-01-13 16:32 |
| Reporter | tille | Assigned To | |||
| Platform | Kernel Linux 3.19.0-32-generic x | OS | Linux Mint | OS Version | 17.3 Rosa 64-bit |
| Summary | 0002857: Placement incorrect in exported files | ||||
| Description | I tried to export an assembly consisting of several bodys, each one containing a box. each body was placed using the Placement option. When exporting (tested with .step and .brep imported in FreeCAD and Salome), the boxes all still were in their initial position, except for rotated boxes. So, Placement x/y/z doesn't work, but rotation about axes worked. | ||||
| Steps To Reproduce | go to Part Design --> create new body --> create additive primitive --> change placement of primitive --> export primitive as .step/.brep file --> import file in FreeCAD --> check placement of imported file. | ||||
| Additional Information | OS: Linux Mint 17.3 Rosa Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9613 (Git) Build type: None Branch: master Hash: 0c34f1b749fbb116058caa54754961c6dcb4f92a Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| related to | 0002642 | closed | Can't open saved file (undiscovered bug/s from PDN?) |
re-jigged summary for better comprehension Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20048 |
Confirmed on : OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9787 (Git) Build type: Release Branch: (detached from 417f074) Hash: 417f074aff779e4c3c3fce7ef755dc3a38691d63 Python version: 2.7.13 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 7.0.0 terminal output : Can't find Origin for "Body001" this for each Body |
Is this related to 0002642 ? |
Has been fixed in recent months. FYI, for export you must select the body and not the primitive because the body stores the placement information. |
| 2017-01-14 10:32 | tille | New Issue | |
| 2017-01-14 10:32 | tille | File Added: viga.fcstd | |
| 2017-01-19 12:17 | Kunda1 | Note Added: 0007872 | |
| 2017-01-19 12:17 | Kunda1 | Summary | Placement doesn't in exported files => Placement incorrect in exported files |
| 2017-01-19 12:31 | Kunda1 | Note Edited: 0007872 | |
| 2017-01-23 20:52 | nemesis | Note Added: 0007923 | |
| 2017-01-23 20:52 | nemesis | Note Edited: 0007923 | |
| 2017-05-11 12:37 | Kunda1 | Relationship added | related to 0002642 |
| 2017-05-11 12:38 | Kunda1 | Note Added: 0008954 | |
| 2017-09-15 20:23 | wmayer | Target Version | => 0.17 |
| 2018-01-13 16:32 | wmayer | Status | new => closed |
| 2018-01-13 16:32 | wmayer | Resolution | open => fixed |
| 2018-01-13 16:32 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-13 16:32 | wmayer | Note Added: 0010755 |
