0002715 | FreeCAD | Feature | public | 2016-09-30 05:29 | 2022-01-24 19:16 |
Reporter | caijulong | Assigned To | |||
Priority | normal | Severity | minor | Reproducibility | always |
Status | new | Resolution | open | ||
Product Version | 0.16 | ||||
Target Version | 0.20 | ||||
Summary | 0002715: The result for fillet of the union of cube and sphere is wrong | ||||
Description | I made an union of cube and sphere, and then made a fillet on one edge(closed to sphere) of the union.The result is not right. | ||||
Steps To Reproduce | Use the attached project | ||||
Tags | #ready-for-migration, OCC Bug, upstream | ||||
FreeCAD Information | |||||
I can reproduce on OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6703 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 To devs: am I right in believing this is an OCC issue FreeCAD has no control on? Or would it be a FreeCAD issue somewhat? If the former, then this would need to be reported upstream to the OCCT bug tracker by someone with an account and knowledge of DRAWEXE. |
That being said caijulong, you should have first reported this in the FreeCAD forum, as explained in the "Please read first before reporting" link. That link is just over the "Report issue" link in the Issues menu. You couldn't have missed it... It is very simple to work around this bug. Simply apply the fillet on the cube *before* fusing to the sphere. |
I've seen @shoogen report upstream OCC bugs. @normandc please advise how to proceed with this ticket? |
In OCC 6.8 the result is always broken when doing a fillet on an edge (there are three of them) that hits the seam edge of the sphere. In 7.2 the result is even worse. For two of the edges (where the sphere intersects the box) the output shape is completely empty (BRep_API: command not done) and for the third edge several faces are missing. When using one of the other edges that intersect the sphere the CPU load goes to 100% and doesn't end in a reasonable time (in case it even does since I stopped the process after a minute). So compared to older occ versions this is a great regression! |
@caijulong could you possibly re-upload Fillet.7z ? |
@caijulong ping |
@Kunda1,sorry about the late reply. I can't find the old file. Just reproduce one. |
Thanks for providing a new file. For future reference to rebuild the example file:
There is another workaround than creating the fillet before the fuse: just rotate the sphere so that its seam does not intersect the edge to be filleted. Set sphere's axis to (1, 0, 0) and set angle to 90ยบ. This repairs the model. See attached. |
The actual problems seems to be related to older OCCT versions. At some point the tolerances of the model are broken leading to huge values like 363.5 (instead of 1e-7). This makes then the fillet to fail. With OCCT 7.0 or later the tolerances are not broken any more and thus no error occurs. But one needs to start from scratch because the broken tolerance values are saved into the BRep files. |
@wmayer how to proceed with this ticket then? |
What we need are some shape healing functions and therefore the file can be used for testing purposes. I changed the category from bug to feature request. |
This ticket has been migrated to GitHub as issue 5665. |
2016-09-30 05:29 | caijulong | New Issue | |
2016-09-30 05:29 | caijulong | File Added: Fillet.7z | |
2016-09-30 05:30 | caijulong | Tag Attached: Part | |
2016-10-15 20:44 | normandc | Note Added: 0007375 | |
2016-10-15 20:46 | normandc | Note Added: 0007376 | |
2016-10-15 20:47 | normandc | Priority | high => normal |
2016-10-15 20:47 | normandc | Severity | major => minor |
2016-10-15 20:48 | normandc | Tag Attached: OCC Bug | |
2017-01-15 02:11 | Kunda1 | Tag Attached: OCC 7.2 | |
2017-01-15 02:12 | Kunda1 | Tag Detached: Part | |
2017-01-15 02:14 | Kunda1 | Note Added: 0007776 | |
2017-01-15 02:15 | Kunda1 | Tag Attached: upstream | |
2017-01-27 01:36 | Kunda1 | Tag Detached: OCC 7.2 | |
2017-09-02 12:25 | wmayer | Note Added: 0010061 | |
2018-01-18 14:27 | Kunda1 | Status | new => feedback |
2018-01-18 14:27 | Kunda1 | Note Added: 0010790 | |
2018-02-18 12:46 | Kunda1 | Note Added: 0010964 | |
2018-02-22 04:04 | caijulong | File Added: Fillet.FCStd | |
2018-02-22 04:04 | caijulong | Note Added: 0010969 | |
2018-02-22 04:04 | caijulong | Status | feedback => new |
2018-02-22 04:22 | normandc | File Added: Fillet_normandc1.FCStd | |
2018-02-22 04:22 | normandc | Note Added: 0010970 | |
2018-10-03 17:59 | wmayer | Note Added: 0011903 | |
2018-10-03 20:06 | Kunda1 | Note Added: 0011906 | |
2018-10-03 21:37 | wmayer | Category | Bug => Feature |
2018-10-03 21:37 | wmayer | Note Added: 0011909 | |
2021-02-06 06:50 | abdullah | Target Version | => 0.20 |
2022-01-24 19:16 | Kunda1 | Tag Attached: #ready-for-migration |
