| 0002754 | FreeCAD | Bug | public | 2016-10-29 20:24 | 2017-07-11 20:13 |
| Reporter | jobermayr | Assigned To | |||
| Summary | 0002754: PartDesign and Drawing examples crash | ||||
| Description | Example projects -> Load a PartDesign example Example projects -> Load a Drawing extraction | ||||
| Tags | OCC Bug, upstream | ||||
When looking at the call stack you will see the crash happens in OpenCascade, not in FreeCAD. See also: http://forum.freecadweb.org/viewtopic.php?f=3&t=17583&p=138611 http://forum.freecadweb.org/viewtopic.php?f=8&t=17561&p=138497 |
@jobermayr can you confirm the solutions presented in 0002754:0007437 ? |
Upstream ticket: https://bugs.archlinux.org/task/50684 > Since this breaks freecad (see FS# 50829 ) even though I rebuilt it, I'm pulling it back out. I'm afraid you'll have to wait for opencascade 7.0.0 or patch it yourself.... Turns out this patch isn't the cause of the problem. It is actually a change in gcc that optimizes away some checks. The patch will continue to be in the package for now until it really leads to problems. Above response is from the Arch Maintainer in the upstream ticket This theoretically should be fixed already OCC 7.0 but I have not tested. Marked #tobeclosed and #pending |
I close the ticket since from our side we can't do anything. |
| 2016-10-29 20:24 | jobermayr | New Issue | |
| 2016-10-29 20:24 | jobermayr | File Added: FreeCAD_examples.log | |
| 2016-10-31 15:36 | wmayer | Note Added: 0007437 | |
| 2017-01-09 18:56 | Kunda1 | Note Added: 0007582 | |
| 2017-01-11 18:44 | Kunda1 | Status | new => feedback |
| 2017-01-22 14:44 | Kunda1 | Tag Attached: OCC Bug | |
| 2017-01-22 14:44 | Kunda1 | Tag Attached: upstream | |
| 2017-01-22 14:50 | Kunda1 | Note Added: 0007912 | |
| 2017-01-22 14:50 | Kunda1 | Tag Attached: #pending | |
| 2017-01-22 14:50 | Kunda1 | Tag Attached: #tobeclosed | |
| 2017-01-27 11:38 | wmayer | Note Added: 0008020 | |
| 2017-01-27 11:38 | wmayer | Status | feedback => closed |
| 2017-01-27 11:38 | wmayer | Resolution | open => not fixable |
| 2017-01-28 13:58 | Kunda1 | Tag Detached: #pending | |
| 2017-07-11 20:13 | Kunda1 | Tag Detached: #tobeclosed |
