| 0002806 | FreeCAD | Bug | public | 2016-12-02 13:54 | 2017-02-10 23:54 |
| Reporter | easyw-fc | Assigned To | yorik | ||
| Summary | 0002806: Loading a boolean objects Transparency get lost | ||||
| Description | Hi, in FC 0.17 (9088 64b on win10 64b) when I save a part that is a result of a simple cut boolean operation, the transparency works and it is saved on the file, but get lost in visualization when the file is reloaded. This behavior is not present on FC 0.16 (6706 64b on win10 64b) and also reloading the file transparency appearance is fine. This seems to happen only on boolean operation between colored parts Please note that in FC 0.17 the Transparency value is fine, and the part get the right appearance if I just modify the value with the gui FC 0.17 7745 64b behaves correctly | ||||
| Steps To Reproduce | example files and steps here http://forum.freecad.org/viewtopic.php?f=8&t=18814#p146649 | ||||
| Tags | Part, transparency | ||||
FreeCAD: master d7ed8c43 2017-02-10 23:53:57 Details Diff |
Part: Set per-face transparency in boolean ops - fixes 0001029,0002806 |
Affected Issues 0001029, 0002806 |
| mod - src/Mod/Part/Gui/ViewProvider.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProvider.h | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderBoolean.cpp | Diff File | ||
| 2016-12-02 13:54 | easyw-fc | New Issue | |
| 2016-12-05 14:12 | easyw-fc | Tag Attached: Part | |
| 2017-01-28 12:20 | Kunda1 | File Added: transparency-prob-fc-0.17.PNG | |
| 2017-01-28 12:20 | Kunda1 | File Added: transparency-fine-fc-0.16.PNG | |
| 2017-01-28 12:22 | Kunda1 | Note Added: 0008050 | |
| 2017-01-28 12:22 | Kunda1 | Status | new => confirmed |
| 2017-02-10 04:59 | Kunda1 | Tag Attached: transparency | |
| 2017-02-10 05:06 | Kunda1 | Relationship added | related to 0001029 |
| 2017-02-10 05:06 | Kunda1 | Relationship added | related to 0000848 |
| 2017-02-10 05:09 | Kunda1 | Relationship added | related to 0001626 |
| 2017-02-10 23:08 | yorik | Relationship replaced | duplicate of 0001029 |
| 2017-02-10 23:54 | yorik | Changeset attached | => FreeCAD Master master d7ed8c43 |
| 2017-02-10 23:54 | yorik | Assigned To | => yorik |
| 2017-02-10 23:54 | yorik | Status | confirmed => closed |
| 2017-02-10 23:54 | yorik | Resolution | open => fixed |
