| 0002810 | Draft | Bug | public | 2016-12-05 00:25 | 2017-07-15 11:19 |
| Reporter | ruchg | Assigned To | yorik | ||
| Summary | 0002810: Keyboard shortcut in Draft | ||||
| Description | Working thru the manual: https://yorikvanhavre.gitbooks.io/a-freecad-manual/content/working_with_freecad/traditional_2d_drafting.html The manual states: "Note that most of the Draft commands can be fully performed from the keyboard, without touching the mouse, using their two-letter shortcut. Our first 2x2m rectangle can be done like this: re 0 Enter 0 Enter 0 Enter 2m Enter 2m Enter 0 Enter." I'm not able to get the rectangle formed using the shortcut. I have both Report and Python consoles open and I notice that the numbers are changing the isometric view. When I type re the task tab opens up with the Rectangle data entry fields. The Report View shows Pick first point: However when I type numbers the Python console shows changes: Gui.activeDocument().activeView().viewAxonometric() or Gui.activeDocument().activeView().viewTop() I suspect either a bug is sending the keyboard data to the wrong place or I need to do something extra to keep the keyboard data going to the correct area. OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.Unknown Build type: Unknown Python version: 2.7.11 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | bejant reports seeing the same issue and provides additional hints. Postby bejant ยป Sun Dec 04, 2016 2:49 pm I see the problem now. Typing "re" (without the quotes) opens the Draw A Rectangle tool, but if the cursor is not in the 3D window, or is in the 3D window and does not move, keying in the numerals 0 to 6 changes the view instead of the spinbox values (and keying the numerals 7 - 9 has no effect). Even though the number in the "Global X" spinbox is highlighted, the cursor has to move in the 3D view, changing the spinbox values, before the keyboard can be used to enter the coordinates. The first time I tried to reproduce your problem I must have moved the cursor in the 3D view by mistake, so I got different results. The problem happened in both versions (my 0.17 version is dated 2016-11-29 which is a few weeks after the issue 0002756 fix): OS: Ubuntu 16.04.1 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 OS: Ubuntu 16.04.1 LTS Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.9088 (Git) Build type: None Branch: master Hash: 537cfb2d48ee915b11ef1987880a5229255e4047 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Additional Information | discussed in the forum: http://forum.freecadweb.org/viewtopic.php?f=3&t=18869 | ||||
| Tags | keyboard, shortcuts | ||||
This is a know old problem... Never been able to find a good solution |
Fixed by yorik in c:FreeCAD:fcae6ef45189b88530dc419582f3727ebd3c8a25: And c:FreeCAD:ff9b027d: |
Bugtracker note: Close ticket only after commit is attached |
https://github.com/FreeCAD/FreeCAD/commit/fcae6ef45189b88530dc419582f3727ebd3c8a25 |
| 2016-12-05 00:25 | ruchg | New Issue | |
| 2016-12-18 17:33 | wmayer | Project | FreeCAD => Draft |
| 2016-12-29 18:07 | yorik | Note Added: 0007557 | |
| 2016-12-29 18:08 | yorik | Assigned To | => yorik |
| 2016-12-29 18:08 | yorik | Status | new => assigned |
| 2017-02-17 17:16 | Kunda1 | Tag Attached: keyboard | |
| 2017-02-17 17:16 | Kunda1 | Tag Attached: shortcuts | |
| 2017-04-25 12:33 | Kunda1 | Note Added: 0008753 | |
| 2017-04-25 12:35 | Kunda1 | Status | assigned => resolved |
| 2017-04-25 12:35 | Kunda1 | Resolution | open => fixed |
| 2017-04-25 12:35 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-04-25 12:35 | Kunda1 | Note Added: 0008754 | |
| 2017-04-28 12:03 | Kunda1 | Note Edited: 0008753 | |
| 2017-07-15 11:19 | Kunda1 | Status | resolved => closed |
| 2017-07-15 11:19 | Kunda1 | Note Added: 0009762 |
