| 0002812 | Path | Feature | public | 2016-12-05 21:47 | 2020-12-01 11:25 |
| Summary | 0002812: Dressup to remap gcode based on probe data. | ||||
| Description | A touchprobe can be used to scan a surface and generate a series of points corresponding to the Z depth. An existing path can then be re-processed with a dressup to map the gcode to the approximated surface. Two pieces need to be written: Capture probe data: ============== A FreeCAD feature should be written to generate the probe file. It would take as input: 1) A selected path. From this it would get the boundbox and determine the XY limits. 2) #points in X 3) #points in Y. 4) distance to probe in Z. 5) name for the probe results file. From this, a gcode file would be generated to probe the grid and write results to a file. Reprocess a path using probe data =========================== A dressup should be written to take as input a probe file and then map the path to the probed surface data by adjusting the Z depth of each move appropriately using bilinear interpolation. | ||||
| Additional Information | http://www.linuxcnc.org/docs/2.4/html/gcode_main.html#sub:Probe-Logging This feature is implemented in gcode ripper. http://www.scorchworks.com/Blog/auto-probing-with-g-code-ripper/ https://en.wikipedia.org/wiki/Bilinear_interpolation | ||||
moving feature request to 0.18 target |
This was implemented as the z depth correction dressup and probe supplemental command. |
commits associated with fix? |
https://github.com/FreeCAD/FreeCAD/pull/3126 |
FreeCAD master 2b52285e |
Associated commit with ticket in mantis. Closing ticket. |
FreeCAD: master 2b52285e 2020-03-27 15:20:29 Committer: GitHub Details Diff |
Merge pull request 0003126 from sliptonic/feature/dressupZCorrect Path: Feature/dressup z correct |
Affected Issues 0002812 |
| mod - src/Mod/Path/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Path/Gui/Resources/Path.qrc | Diff File | ||
| add - src/Mod/Path/Gui/Resources/icons/Path-Probe.svg | Diff File | ||
| add - src/Mod/Path/Gui/Resources/panels/PageOpProbeEdit.ui | Diff File | ||
| add - src/Mod/Path/Gui/Resources/panels/ZCorrectEdit.ui | Diff File | ||
| mod - src/Mod/Path/InitGui.py | Diff File | ||
| add - src/Mod/Path/PathScripts/PathDressupZCorrect.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathGeom.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathGuiInit.py | Diff File | ||
| add - src/Mod/Path/PathScripts/PathProbe.py | Diff File | ||
| add - src/Mod/Path/PathScripts/PathProbeGui.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathSelection.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathSetupSheetOpPrototypeGui.py | Diff File | ||
| 2016-12-05 21:47 | sliptonic | New Issue | |
| 2017-11-28 00:39 | sliptonic | Product Version | 0.17 => |
| 2017-11-28 00:39 | sliptonic | Target Version | 0.17 => 0.18 |
| 2017-11-28 00:39 | sliptonic | Note Added: 0010484 | |
| 2017-11-28 00:40 | sliptonic | Severity | minor => feature |
| 2019-01-22 05:21 | sliptonic | Assigned To | => sliptonic |
| 2019-01-22 05:21 | sliptonic | Status | new => assigned |
| 2019-01-22 05:21 | sliptonic | Product Version | => 0.19 |
| 2019-01-22 05:21 | sliptonic | Target Version | 0.18 => 0.19 |
| 2020-10-06 22:40 | sliptonic | Status | assigned => resolved |
| 2020-10-06 22:40 | sliptonic | Resolution | open => fixed |
| 2020-10-06 22:40 | sliptonic | Note Added: 0014779 | |
| 2020-10-17 10:24 | Kunda1 | Note Added: 0014899 | |
| 2020-10-17 16:26 | sliptonic | Note Added: 0014903 | |
| 2020-12-01 11:24 | Kunda1 | Note Added: 0015033 | |
| 2020-12-01 11:24 | Kunda1 | Changeset attached | => FreeCAD master 2b52285e |
| 2020-12-01 11:25 | Kunda1 | Status | resolved => closed |
| 2020-12-01 11:25 | Kunda1 | Fixed in Version | => 0.19 |
| 2020-12-01 11:25 | Kunda1 | Note Added: 0015034 |
