| 0002818 | FreeCAD | Bug | public | 2016-12-16 01:48 | 2017-03-30 13:01 |
| Reporter | sdh4 | Assigned To | |||
| Platform | Linux | OS | Fedora | OS Version | 25 |
| Summary | 0002818: MEFISTO2 meshing segfaults in 0.16 on Fedora 25 | ||||
| Description | MEFISTO2 meshing consistently segfaults in 0.16 under Fedora 25 I don't think this related to Bug 0002612, as smesh < 7.0 and the fix for 0002612 doesn't look like it would make any difference. freecad-0.16-2.fc25.x86_64 smesh-6.6-1.fc25.x86_64 OCE-modeling-0.17.1-2.fc25.x86_64 OCE-ocaf-0.17.1-2.fc25.x86_64 OCE-debuginfo-0.17.1-2.fc25.x86_64 OCE-visualization-0.17.1-2.fc25.x86_64 OCE-foundation-0.17.1-2.fc25.x86_64 boost-1.60.0-9.fc25.x86_64 | ||||
| Steps To Reproduce | 1. Run FreeCAD 2. Create a cube 3. Attempt to create a MEFISTO mesh 4. Warning message about segfault | ||||
| Additional Information | From gdb: Thread 1 "FreeCAD" received signal SIGSEGV, Segmentation fault. 0x00007fff6919ba89 in qutr2d ( p1=<error reading variable: Cannot access memory at address 0xfa8041dabc8>, p2=..., p3=<error reading variable: Cannot access memory at address 0xc000004129988>, qualite=6.9533558063670365e-310) at /usr/src/debug/smesh-6.6/src/MEFISTO2/trte.f:70 70 a = sqrt( (p2(1)-p1(1))**2 + (p2(2)-p1(2))**2 ) next stack frame up: #1 0x00007fff69199495 in qualitetrte_ (mnpxyd=mnpxyd@entry=0x41d9c20, mosoar=@0x7fffffff8c08: 7, mxsoar=@0x7fffffff8c10: 63072, mnsoar=mnsoar@entry=0x44b4c50, moartr=@0x7fffffff8c20: 3, mxartr=@0x7fffffff8c28: 42048, mnartr=0x483a270, nbtria=@0x7fffffff8e18: 1, quamoy=@0x7fffffff8c58: 0, quamin=@0x7fffffff8c60: 2) at /usr/src/debug/smesh-6.6/src/MEFISTO2/aptrte.cpp:798 798 qualite ); nosotr[0] and nosotr[2] look invalid: (gdb) print nosotr[0] $1 = 717259538600 (gdb) print nosotr[1] $2 = 84 (gdb) print nosotr[2] $3 = 140737488325264 (gdb) print nt $4 = 1 | ||||
| Tags | Mesh | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19900 |
@NormandC do you mind weighing on this ? |
@sdh4 can you reproduce on 0.17 ? |
Seems to not be an issue in a self-compiled 0.17 tree off of github.... So maybe don't worry about it. |
Thanks. Marking unable to reproduce and fixed in 0.17 |
| 2016-12-16 01:48 | sdh4 | New Issue | |
| 2017-01-14 20:18 | Kunda1 | Tag Attached: Mesh | |
| 2017-01-14 20:20 | Kunda1 | Note Added: 0007769 | |
| 2017-03-28 18:57 | Kunda1 | Note Added: 0008724 | |
| 2017-03-29 18:24 | Kunda1 | Status | new => feedback |
| 2017-03-29 18:24 | Kunda1 | Note Added: 0008734 | |
| 2017-03-30 01:36 | sdh4 | Note Added: 0008736 | |
| 2017-03-30 01:36 | sdh4 | Status | feedback => new |
| 2017-03-30 13:01 | Kunda1 | Status | new => closed |
| 2017-03-30 13:01 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-03-30 13:01 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-03-30 13:01 | Kunda1 | Note Added: 0008737 |
