| 0002997 | Sketcher | Bug | public | 2017-04-25 19:13 | 2017-12-07 11:21 |
| Reporter | Patola | Assigned To | abdullah | ||
| Platform | Linux | OS | Ubuntu | OS Version | 16.04 64 bits |
| Summary | 0002997: External geometry points make arc ends become NaN | ||||
| Description | When I try to make an arc with end points and rim selecting external geometry points, the sketcher stops recognizing the points after I select the second one, saying the distance and angle are Not-a-Number. It is better understood with the step-by-step below. Works the same in both 0.16 and latest 0.17 from daily PPA. | ||||
| Steps To Reproduce | 1 - create new file. 2 - create a sketch on the XY plane with Z offset 600, plot a 600x600 square, close sketch. 3 - create new sketch on upper face of this sketch 4 - create two squares with 60x60mm. Assign external geometry to the sides of the previous 600x600 rectangle. Make both squares 20 X and 20 Y distant from the bigger square extremities. 5 - close sketch. Pad to 600 mm. 6 - make new sketch on the same face. Select the inner points of the previous sketch rectangles as external geometry. trace a construction line between these points. 7 - try to make an arc with end points and rim. Select the first end point as the leftmost external geometry point. After you select the second the second end point as the rightmost external geometry point, it does not allow you to complete the arc, saying the angle and distance are Not-a-Number. A screenshot is attached. A file with these object is also attached. | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | arc, external geometry, NaN, sketcher | ||||
Attached screenshot of operation (in 0.16, but it works the same in 0.17) and file from 0.16 |
@NormandC do you mind testing this ticket in 0.17 as well? |
This: https://github.com/FreeCAD/FreeCAD/pull/766 should fix it. |
@kunda1 Should this ticket be open? |
This ticket closed with 0003018 simultaneously via https://github.com/FreeCAD/FreeCAD/pull/766 FreeCAD master c6e0c6aa |
| 2017-04-25 19:13 | Patola | New Issue | |
| 2017-04-25 19:13 | Patola | Tag Attached: sketcher | |
| 2017-04-25 19:13 | Patola | Tag Attached: arc | |
| 2017-04-25 19:13 | Patola | Tag Attached: end points and rim | |
| 2017-04-25 19:13 | Patola | Tag Attached: external geometry | |
| 2017-04-25 19:14 | Patola | File Added: arco.png | |
| 2017-04-25 19:14 | Patola | File Added: arc-end-points-and-rim.fcstd | |
| 2017-04-25 19:14 | Patola | Note Added: 0008758 | |
| 2017-05-06 11:02 | Kunda1 | Relationship added | related to 0003018 |
| 2017-05-14 14:27 | Kunda1 | Tag Attached: NaN | |
| 2017-05-18 11:30 | Kunda1 | Note Added: 0009050 | |
| 2017-05-21 08:12 | abdullah | Assigned To | => abdullah |
| 2017-05-21 08:12 | abdullah | Status | new => assigned |
| 2017-05-21 08:13 | abdullah | Note Added: 0009070 | |
| 2017-05-30 10:18 | Kunda1 | Tag Detached: end points and rim | |
| 2017-12-07 06:01 | abdullah | Note Added: 0010532 | |
| 2017-12-07 11:21 | Kunda1 | Status | assigned => closed |
| 2017-12-07 11:21 | Kunda1 | Resolution | open => fixed |
| 2017-12-07 11:21 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-12-07 11:21 | Kunda1 | Note Added: 0010540 |
