| 0003018 | Sketcher | Bug | public | 2017-05-01 12:11 | 2019-07-30 22:45 |
| Reporter | Patola | Assigned To | abdullah | ||
| Summary | 0003018: Sketcher Arc End Points + Rim Point fails with "NaN" | ||||
| Description | In certain situations, creating an arc from end points then rim point does not work, showing Not-a-Number. The attached file has such a situation. It occurs in FreeCAD 0.16 and latest 0.17 from PPA. The steps to reproduce tell the problem in a little more detail. | ||||
| Steps To Reproduce | 1 - Open the attached fcstd file. It has a square sketch 600x600mm padded to 20mm, then a sketch with two 60x60mm squares equidistant from the sides by 20mm and padded to 600mm, then a third sketch with corner points of the second sketch squares marked as external geometry. 2 - edit the third sketch. Make a construction line between the points and then a point in the middle of it (equidistant from the points). 3 - add a vertical construction line, 40mm in length, from this median point to below. 4 - select the arc tool - End points and rim point. 5 - select the leftmost external geometry point. Then select the rightmost external geometry point. 6 - Now instead of the cursor having the distance numbers for you to choose the third (rim) point, you have it showing -nanR for distance, -nandeg for angle. A screenshot is attached showing this. It works the same way in FreeCAD 0.16 from PPA and FreeCAD 0.17 from freecad-daily PPA. 7 - if anyway I click on the third point I want for the rim, it says the sketch is overconstrained and marks all constraints as invalid. And does not create the arc. ![]() | ||||
| Additional Information | OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=22512 | ||||
| Tags | NaN | ||||
@Patola please re-add test file and screenshot. Thx! |
@NormandC do you mind confirming this ticket? |
Why were my screenshot and freecad file removed? I fortunately had them at the time mantisbt crashed and that's the second time I open this very bug (it was opened prior to the crash, so it was not backed up) and I reused them, but I do not have the screenshot anymore. |
Found my screenshot on issue 0002997. Attaching it again |
@Patola our bugtracker was compromised and some attchments didn't survive the backup. Thx for your patience. |
@Patola FYI you're subject to getting faster response by posting to the forum first before opening a ticket. The recommendation is opening an accompanying forum thread to discuss the issue. |
The bug description mentionsThe "bug-sweep-017.fcstd" file has no such sketches. |
Sorry... I don't know what happened. You can use the file from 0002997. I am attaching it here. And sorry for not opening a topic on the forum. I think I am just too used to report in the bugtracker. That's not the first time I am warned about that. |
Okay, I rebuild a new model from scratch based on the bug description, and was able to replicate the issue. In the atached file, edit Sketch002 and start from step 4. Bug confirmed on OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11054 (Git) Build type: None Branch: master Hash: 36c60d3f8d924799e805ce56cb6e8fe6e49cf12b Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
Well I should have waited a bit it seems! Still, not related to this bug, but 0.17 reports conflicting constraints in your Sketch002. The point is not even necessary, just create a symmetric constraint between the horizontal line itself and the small vertical line upper end point. 0.16 reports no error, which seems to indicate the sketcher solver has improved in 0.17. The NaN bug only occurs if the first two selections are constrained to existing geometry points. If clicked randomly on the screen, it does not happen. |
This issue seems to be reproducible only when constraining the two first points of the arc on a horizontal line. If the line isn't horizontal, there is no bug. No bug with single points, or circle centre points, etc. Simply create a new document, new sketch, trace a horizontal line; then start the arc from 3 points tool, click on the two end points of the line for the first two selections. |
The solution given in the code is bad conditioned for this specific case, which leads to NaN results. I will work towards a solution |
https://github.com/FreeCAD/FreeCAD/pull/766 |
FreeCAD master c6e0c6aa |
https://github.com/FreeCAD/FreeCAD/commit/c6e0c6aa80ebae7ad0fd5269592d34dded872c8a https://github.com/FreeCAD/FreeCAD/pull/767 |
| 2017-05-01 12:11 | Kunda1 | New Issue | |
| 2017-05-01 12:13 | Kunda1 | Reporter | Kunda1 => Patola |
| 2017-05-01 12:13 | Kunda1 | Note Added: 0008839 | |
| 2017-05-04 10:41 | Kunda1 | Note Added: 0008883 | |
| 2017-05-05 04:56 | Patola | File Added: bug-sweep-017.fcstd | |
| 2017-05-05 04:56 | Patola | Note Added: 0008886 | |
| 2017-05-05 05:00 | Patola | File Added: arco.png | |
| 2017-05-05 05:00 | Patola | Note Added: 0008887 | |
| 2017-05-06 11:01 | Kunda1 | Note Added: 0008894 | |
| 2017-05-06 11:02 | Kunda1 | Relationship added | related to 0002997 |
| 2017-05-07 14:38 | Kunda1 | Note Added: 0008901 | |
| 2017-05-07 14:38 | Kunda1 | Status | new => feedback |
| 2017-05-14 00:44 | normandc | Note Added: 0008998 | |
| 2017-05-14 00:53 | Patola | File Added: arc-end-points-and-rim.fcstd | |
| 2017-05-14 00:53 | Patola | Note Added: 0008999 | |
| 2017-05-14 00:53 | Patola | Status | feedback => new |
| 2017-05-14 00:54 | normandc | File Added: FC017_Patola_bug3018_normandc1.fcstd | |
| 2017-05-14 00:54 | normandc | Note Added: 0009000 | |
| 2017-05-14 01:06 | normandc | Note Added: 0009001 | |
| 2017-05-14 01:13 | normandc | Note Added: 0009002 | |
| 2017-05-14 13:40 | Kunda1 | Status | new => confirmed |
| 2017-05-14 13:40 | Kunda1 | Tag Attached: NaN | |
| 2017-05-18 11:28 | Kunda1 | Additional Information Updated | |
| 2017-05-18 11:28 | Kunda1 | Note Added: 0009049 | |
| 2017-05-20 17:33 | abdullah | Note Added: 0009066 | |
| 2017-05-20 17:33 | abdullah | Assigned To | => abdullah |
| 2017-05-20 17:33 | abdullah | Status | confirmed => assigned |
| 2017-05-21 08:09 | abdullah | Note Added: 0009069 | |
| 2017-05-26 22:30 | Kunda1 | Note Added: 0009161 | |
| 2017-05-27 13:00 | wmayer | Status | assigned => closed |
| 2017-05-27 13:00 | wmayer | Resolution | open => fixed |
| 2017-05-27 13:00 | wmayer | Fixed in Version | => 0.17 |
| 2017-05-27 13:00 | wmayer | Note Added: 0009169 | |
| 2019-07-30 22:45 | Kunda1 | Changeset attached | => FreeCAD master c6e0c6aa |
