| 0003042 | Path | Bug | public | 2017-05-19 13:07 | 2017-05-29 13:20 |
| Reporter | federico.carminati@gmail.com | Assigned To | |||
| Platform | Mac | OS | OS X Sierra | OS Version | 10.12.5 (16F73) |
| Summary | 0003042: Problem in using the Path workbench | ||||
| Description | If I select the Path workbench, some of the icons do not appear. In particular the Face Profile icon is not present in the task bar and the functionality can only be accessed via Path->Partial Commands->Face Profile. But even selecting this I have the following error Running the Python command 'Path_FaceProfile' failed: Traceback (most recent call last): File "/Applications/FreeCAD.old.app/Contents/Mod/Path/PathScripts/PathFaceProfile.py", line 156, in Activated FreeCADGui.doCommand('PathScripts.PathUtils.addToJob(obj)') File "<string>", line 1, in <module> File "/Applications/FreeCAD.old.app/Contents/Mod/Path/PathScripts/PathUtils.py", line 604, in addToJob g = job.Group 'NoneType' object has no attribute 'Group' | ||||
| Steps To Reproduce | 1. Start FreeCAD 2. Activate Path workbench | ||||
| Additional Information | OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.8750 (Git) Build type: Release Branch: (detached from 6b1866c) Hash: 6b1866ccaf72e2c745a68614f7b2d3c5890141e0 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 7.0.0 | ||||
Please update to the latest 0.17 revision |
Not very good. I downloaded both https://github.com/FreeCAD/FreeCAD/releases/download/0.17_pre/FreeCAD_0.17-11114.8da4563-OSX-x86_64-Qt4.dmg and https://github.com/FreeCAD/FreeCAD/releases/download/0.17_pre/FreeCAD_0.17-11114.8da4563-OSX-x86_64-Qt5.dmg The QT4 version fails with the message below. The QT5 version seems to work but I am not able to add workbenches. If, for instance, I add Assembly2 to /Applications/FreeCAD.app/Contents/Mod I do not see it in the workbench menu ------------------------ Crash report from 0.17 QT4 Process: FreeCAD [6252] Path: /Applications/FreeCAD.app/Contents/MacOS/FreeCAD Identifier: FreeCAD Version: ??? (0.17.10000) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: FreeCAD [6252] User ID: 1001 Date/Time: 2017-05-20 09:33:50.697 +0200 OS Version: Mac OS X 10.12.5 (16F73) Report Version: 12 Anonymous UUID: A425884F-A3AD-6FD2-C5FE-7939ABEA2AFF Sleep/Wake UUID: D2AACE68-4142-441E-BE96-2C2E48479B9F Time Awake Since Boot: 9600 seconds Time Since Wake: 190 seconds System Integrity Protection: enabled Crashed Thread: 0 Exception Type: EXC_CRASH (SIGABRT) Exception Codes: 0x0000000000000000, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: DYLD, [0x1] Library missing Application Specific Information: dyld: launch, loading dependent libraries Dyld Error Message: Library not loaded: @rpath/libFreeCADGui.dylib Referenced from: /Applications/FreeCAD.app/Contents/MacOS/FreeCAD Reason: image not found Binary Images: 0x10ef83000 - 0x10ef8fff7 + (??? - 0.17.10000) <6601A1B0-558D-3FC2-91FA-B84EAF5E1263> /Applications/FreeCAD.app/Contents/MacOS/FreeCAD 0x11ea7b000 - 0x11eab8dc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld |
OP, have you successfully built latest dev revision of 0.17 from source? ( https://forum.freecadweb.org/viewtopic.php?f=4&t=22565&hilit=federico#p174924 ) If so can you retest this bug report? Linking to https://github.com/FreeCAD/homebrew-freecad/issues/47 |
These problems disappeared once I have compiled my own version. You can close this bug report. Best |
Thx. Closing |
| 2017-05-19 13:07 | federico.carminati@gmail.com | New Issue | |
| 2017-05-19 22:09 | Kunda1 | Note Added: 0009060 | |
| 2017-05-20 07:40 | federico.carminati@gmail.com | Note Added: 0009062 | |
| 2017-05-20 07:42 | federico.carminati@gmail.com | Note Edited: 0009062 | |
| 2017-05-24 22:00 | Kunda1 | Severity | major => minor |
| 2017-05-26 13:25 | Kunda1 | Status | new => feedback |
| 2017-05-26 13:25 | Kunda1 | Note Added: 0009149 | |
| 2017-05-26 13:25 | Kunda1 | Project | FreeCAD => Path |
| 2017-05-26 13:26 | Kunda1 | Priority | high => normal |
| 2017-05-26 13:27 | Kunda1 | Relationship added | related to 0003043 |
| 2017-05-26 13:30 | Kunda1 | Note Edited: 0009149 | |
| 2017-05-29 08:17 | federico.carminati@gmail.com | Note Added: 0009181 | |
| 2017-05-29 08:17 | federico.carminati@gmail.com | Status | feedback => new |
| 2017-05-29 13:20 | Kunda1 | Status | new => closed |
| 2017-05-29 13:20 | Kunda1 | Resolution | open => no change required |
| 2017-05-29 13:20 | Kunda1 | Note Added: 0009183 |
