| 0003043 | FreeCAD | Bug | public | 2017-05-20 09:40 | 2017-06-10 11:45 |
| Reporter | federico.carminati@gmail.com | Assigned To | blacey | ||
| Platform | Mac | OS | OS X | OS Version | 10.12.5 (16F73) |
| Summary | 0003043: Cannot compile FreeCad | ||||
| Description | [/Users/fca] brew install --only-dependencies freecad ==> Installing freecad from freecad/freecad All dependencies for freecad/freecad/freecad are satisfied. [...r/local/FreeCAD/build] cd .. ; rm -rf build ; mkdir build; cd build ; cmake -DBUILD_QT5=1 -DFREECAD_USE_EXTERNAL_KDL=1 -DBUILD_FEM_NETGEN=1 -DFREECAD_CREATE_MAC_APP=1 -DCMAKE_BUILD_TYPE="Release" ../FreeCAD-git/ -- The C compiler identification is AppleClang 8.1.0.8020042 -- The CXX compiler identification is AppleClang 8.1.0.8020042 -- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -- Check for working C compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -- Check for working CXX compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- Looking for GL/gl.h -- Looking for GL/gl.h - not found -- Looking for C++ include istream -- Looking for C++ include istream - found -- Looking for C++ include ostream -- Looking for C++ include ostream - found -- Looking for C++ include fstream -- Looking for C++ include fstream - found -- Looking for C++ include sstream -- Looking for C++ include sstream - found -- Looking for C++ include ios -- Looking for C++ include ios - found -- Looking for C++ include iostream -- Looking for C++ include iostream - found -- Looking for C++ include iomanip -- Looking for C++ include iomanip - found -- Looking for C++ include iostream -- Looking for C++ include iostream - found -- Check for STD namespace -- Check for STD namespace - found -- Force BOOST_PP_VARIADICS=1 for clang -- prefix: /usr/local -- datadir: data -- docdir: doc -- includedir: include -- libdir: /usr/local/lib -- Detected Homebrew install at /usr/local -- Found PythonInterp: /usr/local/bin/python (found version "2.7.13") -- Found PythonLibs: /usr/local/opt/python/Frameworks/Python.framework/Versions/2.7/lib/libpython2.7.dylib (Required is exact version "2.7.13") -- Looking for pthread.h -- Looking for pthread.h - found -- Looking for pthread_create -- Looking for pthread_create - found -- Found Threads: TRUE -- Boost version: 1.64.0 -- Found the following Boost libraries: -- filesystem -- program_options -- regex -- signals -- system -- thread -- chrono -- date_time -- atomic -- Found Xerces-C: /usr/local/lib/libxerces-c.dylib -- Found ZLIB: /usr/lib/libz.dylib (found version "1.2.8") -- PyCXX found: -- Headers: /usr/local/FreeCAD/FreeCAD-git/src -- Sources: /usr/local/FreeCAD/FreeCAD-git/src/CXX -- Found OCC: /usr/local/include/opencascade (found version "7.1.0") -- -- Found OCE/OpenCASCADE version: 7.1.0 -- -- OCE/OpenCASCADE include directory: /usr/local/include/opencascade -- -- OCE/OpenCASCADE shared libraries directory: /usr/local/lib -- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5 -- HDF5: Using hdf5 compiler wrapper to determine C configuration -- Found HDF5: /sw/lib/libhdf5.dylib;/sw/lib/libsz.dylib;/usr/lib/libz.dylib;/usr/lib/libdl.dylib;/usr/lib/libm.dylib (found version "1.8.14") -- Check for medfile (libmed and libmedc) ... -- Found MEDFile: /usr/local/include -- Found NETGEN version 5.3, calculated: 328448 -- Found SWIG: /sw/bin/swig (found version "3.0.10") -- Found Eigen3: /sw/include/eigen3 (Required is at least version "2.91.0") CMake Warning at CMakeLists.txt:772 (find_package): By not providing "FindQt5Network.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5Network", but CMake did not find one. Could not find a package configuration file provided by "Qt5Network" with any of the following names: Qt5NetworkConfig.cmake qt5network-config.cmake Add the installation prefix of "Qt5Network" to CMAKE_PREFIX_PATH or set "Qt5Network_DIR" to a directory containing one of the above files. If "Qt5Network" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:773 (find_package): By not providing "FindQt5Xml.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5Xml", but CMake did not find one. Could not find a package configuration file provided by "Qt5Xml" with any of the following names: Qt5XmlConfig.cmake qt5xml-config.cmake Add the installation prefix of "Qt5Xml" to CMAKE_PREFIX_PATH or set "Qt5Xml_DIR" to a directory containing one of the above files. If "Qt5Xml" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:775 (find_package): By not providing "FindQt5Widgets.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5Widgets", but CMake did not find one. Could not find a package configuration file provided by "Qt5Widgets" with any of the following names: Qt5WidgetsConfig.cmake qt5widgets-config.cmake Add the installation prefix of "Qt5Widgets" to CMAKE_PREFIX_PATH or set "Qt5Widgets_DIR" to a directory containing one of the above files. If "Qt5Widgets" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:776 (find_package): By not providing "FindQt5PrintSupport.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5PrintSupport", but CMake did not find one. Could not find a package configuration file provided by "Qt5PrintSupport" with any of the following names: Qt5PrintSupportConfig.cmake qt5printsupport-config.cmake Add the installation prefix of "Qt5PrintSupport" to CMAKE_PREFIX_PATH or set "Qt5PrintSupport_DIR" to a directory containing one of the above files. If "Qt5PrintSupport" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:777 (find_package): By not providing "FindQt5OpenGL.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5OpenGL", but CMake did not find one. Could not find a package configuration file provided by "Qt5OpenGL" with any of the following names: Qt5OpenGLConfig.cmake qt5opengl-config.cmake Add the installation prefix of "Qt5OpenGL" to CMAKE_PREFIX_PATH or set "Qt5OpenGL_DIR" to a directory containing one of the above files. If "Qt5OpenGL" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:778 (find_package): By not providing "FindQt5Svg.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5Svg", but CMake did not find one. Could not find a package configuration file provided by "Qt5Svg" with any of the following names: Qt5SvgConfig.cmake qt5svg-config.cmake Add the installation prefix of "Qt5Svg" to CMAKE_PREFIX_PATH or set "Qt5Svg_DIR" to a directory containing one of the above files. If "Qt5Svg" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:779 (find_package): By not providing "FindQt5UiTools.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5UiTools", but CMake did not find one. Could not find a package configuration file provided by "Qt5UiTools" with any of the following names: Qt5UiToolsConfig.cmake qt5uitools-config.cmake Add the installation prefix of "Qt5UiTools" to CMAKE_PREFIX_PATH or set "Qt5UiTools_DIR" to a directory containing one of the above files. If "Qt5UiTools" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:780 (find_package): By not providing "FindQt5Network.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5Network", but CMake did not find one. Could not find a package configuration file provided by "Qt5Network" with any of the following names: Qt5NetworkConfig.cmake qt5network-config.cmake Add the installation prefix of "Qt5Network" to CMAKE_PREFIX_PATH or set "Qt5Network_DIR" to a directory containing one of the above files. If "Qt5Network" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:781 (find_package): By not providing "FindQt5Concurrent.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5Concurrent", but CMake did not find one. Could not find a package configuration file provided by "Qt5Concurrent" with any of the following names: Qt5ConcurrentConfig.cmake qt5concurrent-config.cmake Add the installation prefix of "Qt5Concurrent" to CMAKE_PREFIX_PATH or set "Qt5Concurrent_DIR" to a directory containing one of the above files. If "Qt5Concurrent" provides a separate development package or SDK, be sure it has been installed. CMake Warning at CMakeLists.txt:784 (find_package): By not providing "FindQt5WebKitWidgets.cmake" in CMAKE_MODULE_PATH this project has asked CMake to find a package configuration file provided by "Qt5WebKitWidgets", but CMake did not find one. Could not find a package configuration file provided by "Qt5WebKitWidgets" with any of the following names: Qt5WebKitWidgetsConfig.cmake qt5webkitwidgets-config.cmake Add the installation prefix of "Qt5WebKitWidgets" to CMAKE_PREFIX_PATH or set "Qt5WebKitWidgets_DIR" to a directory containing one of the above files. If "Qt5WebKitWidgets" provides a separate development package or SDK, be sure it has been installed. CMake Error at CMakeLists.txt:789 (MESSAGE): ======================== Qt5 libraries not found. ======================== -- Configuring incomplete, errors occurred! See also "/usr/local/FreeCAD/build/CMakeFiles/CMakeOutput.log". See also "/usr/local/FreeCAD/build/CMakeFiles/CMakeError.log". [...r/local/FreeCAD/build] | ||||
| Steps To Reproduce | See above, jus trying to install FreeCAD from sources | ||||
| Tags | macOS | ||||
| related to | 0003042 | closed | Path | Problem in using the Path workbench |
CMakeOutput.log (47,036 bytes)
The system is: Darwin - 16.6.0 - x86_64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc
Build flags:
Id flags:
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "a.out"
The C compiler identification is AppleClang, found in "/usr/local/FreeCAD/build/CMakeFiles/3.8.0/CompilerIdC/a.out"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Compiler: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++
Build flags:
Id flags:
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "a.out"
The CXX compiler identification is AppleClang, found in "/usr/local/FreeCAD/build/CMakeFiles/3.8.0/CompilerIdCXX/a.out"
Determining if the C compiler works passed with the following output:
Change Dir: /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp
Run Build Command:"/Users/fca/bin/gmake" "cmTC_049c6/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_049c6.dir/build.make CMakeFiles/cmTC_049c6.dir/build
gmake[1]: Entering directory '/usr/local/FreeCAD/build/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_049c6.dir/testCCompiler.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_049c6.dir/testCCompiler.c.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/testCCompiler.c
Linking C executable cmTC_049c6
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_049c6.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_049c6.dir/testCCompiler.c.o -o cmTC_049c6
gmake[1]: Leaving directory '/usr/local/FreeCAD/build/CMakeFiles/CMakeTmp'
Detecting C compiler ABI info compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_2be91/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_2be91.dir/build.make CMakeFiles/cmTC_2be91.dir/build
Building C object CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o -c /sw/share/cmake-3.8/Modules/CMakeCCompilerABI.c
Linking C executable cmTC_2be91
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2be91.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names -v -Wl,-v CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o -o cmTC_2be91
Apple LLVM version 8.1.0 (clang-802.0.42)
Target: x86_64-apple-darwin16.6.0
Thread model: posix
InstalledDir: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin
"/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -lto_library /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/libLTO.dylib -dynamic -arch x86_64 -macosx_version_min 10.12.0 -o cmTC_2be91 -search_paths_first -headerpad_max_install_names -v CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a
@(#)PROGRAM:ld PROJECT:ld64-278.4
configured to support archs: armv6 armv7 armv7s arm64 i386 x86_64 x86_64h armv6m armv7k armv7m armv7em (tvOS)
Library search paths:
/usr/lib
/usr/local/lib
Framework search paths:
/Library/Frameworks/
/System/Library/Frameworks/
Parsed C implicit link information from above output:
link line regex: [^( *|.*[/\])(ld|([^/\]+-)?ld|collect2)[^/\]*( |$)]
ignore line: [Change Dir: /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp]
ignore line: []
ignore line: [Run Build Command:"/Users/fca/bin/gmake" "cmTC_2be91/fast"]
ignore line: [/Users/fca/bin/gmake -f CMakeFiles/cmTC_2be91.dir/build.make CMakeFiles/cmTC_2be91.dir/build]
ignore line: [gmake[1]: Entering directory '/usr/local/FreeCAD/build/CMakeFiles/CMakeTmp']
ignore line: [Building C object CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o]
ignore line: [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o -c /sw/share/cmake-3.8/Modules/CMakeCCompilerABI.c]
ignore line: [Linking C executable cmTC_2be91]
ignore line: [/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2be91.dir/link.txt --verbose=1]
ignore line: [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names -v -Wl,-v CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o -o cmTC_2be91 ]
ignore line: [Apple LLVM version 8.1.0 (clang-802.0.42)]
ignore line: [Target: x86_64-apple-darwin16.6.0]
ignore line: [Thread model: posix]
ignore line: [InstalledDir: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin]
link line: [ "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -lto_library /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/libLTO.dylib -dynamic -arch x86_64 -macosx_version_min 10.12.0 -o cmTC_2be91 -search_paths_first -headerpad_max_install_names -v CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a]
arg [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld] ==> ignore
arg [-demangle] ==> ignore
arg [-lto_library] ==> ignore, skip following value
arg [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/libLTO.dylib] ==> skip value of -lto_library
arg [-dynamic] ==> ignore
arg [-arch] ==> ignore
arg [x86_64] ==> ignore
arg [-macosx_version_min] ==> ignore
arg [10.12.0] ==> ignore
arg [-o] ==> ignore
arg [cmTC_2be91] ==> ignore
arg [-search_paths_first] ==> ignore
arg [-headerpad_max_install_names] ==> ignore
arg [-v] ==> ignore
arg [CMakeFiles/cmTC_2be91.dir/CMakeCCompilerABI.c.o] ==> ignore
arg [-lSystem] ==> lib [System]
arg [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a] ==> lib [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a]
Library search paths: [;/usr/lib;/usr/local/lib]
Framework search paths: [;/Library/Frameworks/;/System/Library/Frameworks/]
remove lib [System]
remove lib [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a]
collapse library dir [/usr/lib] ==> [/usr/lib]
collapse library dir [/usr/local/lib] ==> [/usr/local/lib]
collapse framework dir [/Library/Frameworks/] ==> [/Library/Frameworks]
collapse framework dir [/System/Library/Frameworks/] ==> [/System/Library/Frameworks]
implicit libs: []
implicit dirs: [/usr/lib;/usr/local/lib]
implicit fwks: [/Library/Frameworks;/System/Library/Frameworks]
Detecting C [-std=c11] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_fcc78/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_fcc78.dir/build.make CMakeFiles/cmTC_fcc78.dir/build
Building C object CMakeFiles/cmTC_fcc78.dir/feature_tests.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -std=c11 -o CMakeFiles/cmTC_fcc78.dir/feature_tests.c.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.c
Linking C executable cmTC_fcc78
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_fcc78.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_fcc78.dir/feature_tests.c.o -o cmTC_fcc78
Feature record: C_FEATURE:1c_function_prototypes
Feature record: C_FEATURE:1c_restrict
Feature record: C_FEATURE:1c_static_assert
Feature record: C_FEATURE:1c_variadic_macros
Detecting C [-std=c99] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_81a75/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_81a75.dir/build.make CMakeFiles/cmTC_81a75.dir/build
Building C object CMakeFiles/cmTC_81a75.dir/feature_tests.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -std=c99 -o CMakeFiles/cmTC_81a75.dir/feature_tests.c.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.c
Linking C executable cmTC_81a75
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_81a75.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_81a75.dir/feature_tests.c.o -o cmTC_81a75
Feature record: C_FEATURE:0c_static_assert
Detecting C [-std=c90] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_0bb03/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_0bb03.dir/build.make CMakeFiles/cmTC_0bb03.dir/build
Building C object CMakeFiles/cmTC_0bb03.dir/feature_tests.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -std=c90 -o CMakeFiles/cmTC_0bb03.dir/feature_tests.c.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.c
Linking C executable cmTC_0bb03
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_0bb03.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_0bb03.dir/feature_tests.c.o -o cmTC_0bb03
Feature record: C_FEATURE:0c_restrict
Feature record: C_FEATURE:0c_variadic_macros
Determining if the CXX compiler works passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_aca8f/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_aca8f.dir/build.make CMakeFiles/cmTC_aca8f.dir/build
Building CXX object CMakeFiles/cmTC_aca8f.dir/testCXXCompiler.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_aca8f.dir/testCXXCompiler.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
Linking CXX executable cmTC_aca8f
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_aca8f.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_aca8f.dir/testCXXCompiler.cxx.o -o cmTC_aca8f
Detecting CXX compiler ABI info compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_216ce/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_216ce.dir/build.make CMakeFiles/cmTC_216ce.dir/build
Building CXX object CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o -c /sw/share/cmake-3.8/Modules/CMakeCXXCompilerABI.cpp
Linking CXX executable cmTC_216ce
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_216ce.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names -v -Wl,-v CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_216ce
Thread model: posix
"/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -lto_library /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/libLTO.dylib -dynamic -arch x86_64 -macosx_version_min 10.12.0 -o cmTC_216ce -search_paths_first -headerpad_max_install_names -v CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o -lc++ -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a
/usr/lib
/usr/local/lib
Parsed CXX implicit link information from above output:
ignore line: []
ignore line: [Run Build Command:"/Users/fca/bin/gmake" "cmTC_216ce/fast"]
ignore line: [/Users/fca/bin/gmake -f CMakeFiles/cmTC_216ce.dir/build.make CMakeFiles/cmTC_216ce.dir/build]
ignore line: [Building CXX object CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o]
ignore line: [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o -c /sw/share/cmake-3.8/Modules/CMakeCXXCompilerABI.cpp]
ignore line: [Linking CXX executable cmTC_216ce]
ignore line: [/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_216ce.dir/link.txt --verbose=1]
ignore line: [/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names -v -Wl,-v CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o -o cmTC_216ce ]
link line: [ "/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld" -demangle -lto_library /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/libLTO.dylib -dynamic -arch x86_64 -macosx_version_min 10.12.0 -o cmTC_216ce -search_paths_first -headerpad_max_install_names -v CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o -lc++ -lSystem /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/8.1.0/lib/darwin/libclang_rt.osx.a]
arg [-o] ==> ignore
arg [cmTC_216ce] ==> ignore
arg [-v] ==> ignore
arg [CMakeFiles/cmTC_216ce.dir/CMakeCXXCompilerABI.cpp.o] ==> ignore
arg [-lc++] ==> lib [c++]
remove lib [System]
implicit libs: [c++]
Detecting CXX [-std=c++1z] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_6ce8d/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_6ce8d.dir/build.make CMakeFiles/cmTC_6ce8d.dir/build
Building CXX object CMakeFiles/cmTC_6ce8d.dir/feature_tests.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -std=c++1z -o CMakeFiles/cmTC_6ce8d.dir/feature_tests.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_6ce8d
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_6ce8d.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_6ce8d.dir/feature_tests.cxx.o -o cmTC_6ce8d
Feature record: CXX_FEATURE:1cxx_aggregate_default_initializers
Feature record: CXX_FEATURE:1cxx_alias_templates
Feature record: CXX_FEATURE:1cxx_alignas
Feature record: CXX_FEATURE:1cxx_alignof
Feature record: CXX_FEATURE:1cxx_attributes
Feature record: CXX_FEATURE:1cxx_attribute_deprecated
Feature record: CXX_FEATURE:1cxx_auto_type
Feature record: CXX_FEATURE:1cxx_binary_literals
Feature record: CXX_FEATURE:1cxx_constexpr
Feature record: CXX_FEATURE:1cxx_contextual_conversions
Feature record: CXX_FEATURE:1cxx_decltype
Feature record: CXX_FEATURE:1cxx_decltype_auto
Feature record: CXX_FEATURE:1cxx_decltype_incomplete_return_types
Feature record: CXX_FEATURE:1cxx_default_function_template_args
Feature record: CXX_FEATURE:1cxx_defaulted_functions
Feature record: CXX_FEATURE:1cxx_defaulted_move_initializers
Feature record: CXX_FEATURE:1cxx_delegating_constructors
Feature record: CXX_FEATURE:1cxx_deleted_functions
Feature record: CXX_FEATURE:1cxx_digit_separators
Feature record: CXX_FEATURE:1cxx_enum_forward_declarations
Feature record: CXX_FEATURE:1cxx_explicit_conversions
Feature record: CXX_FEATURE:1cxx_extended_friend_declarations
Feature record: CXX_FEATURE:1cxx_extern_templates
Feature record: CXX_FEATURE:1cxx_final
Feature record: CXX_FEATURE:1cxx_func_identifier
Feature record: CXX_FEATURE:1cxx_generalized_initializers
Feature record: CXX_FEATURE:1cxx_generic_lambdas
Feature record: CXX_FEATURE:1cxx_inheriting_constructors
Feature record: CXX_FEATURE:1cxx_inline_namespaces
Feature record: CXX_FEATURE:1cxx_lambdas
Feature record: CXX_FEATURE:1cxx_lambda_init_captures
Feature record: CXX_FEATURE:1cxx_local_type_template_args
Feature record: CXX_FEATURE:1cxx_long_long_type
Feature record: CXX_FEATURE:1cxx_noexcept
Feature record: CXX_FEATURE:1cxx_nonstatic_member_init
Feature record: CXX_FEATURE:1cxx_nullptr
Feature record: CXX_FEATURE:1cxx_override
Feature record: CXX_FEATURE:1cxx_range_for
Feature record: CXX_FEATURE:1cxx_raw_string_literals
Feature record: CXX_FEATURE:1cxx_reference_qualified_functions
Feature record: CXX_FEATURE:1cxx_relaxed_constexpr
Feature record: CXX_FEATURE:1cxx_return_type_deduction
Feature record: CXX_FEATURE:1cxx_right_angle_brackets
Feature record: CXX_FEATURE:1cxx_rvalue_references
Feature record: CXX_FEATURE:1cxx_sizeof_member
Feature record: CXX_FEATURE:1cxx_static_assert
Feature record: CXX_FEATURE:1cxx_strong_enums
Feature record: CXX_FEATURE:1cxx_template_template_parameters
Feature record: CXX_FEATURE:1cxx_thread_local
Feature record: CXX_FEATURE:1cxx_trailing_return_types
Feature record: CXX_FEATURE:1cxx_unicode_literals
Feature record: CXX_FEATURE:1cxx_uniform_initialization
Feature record: CXX_FEATURE:1cxx_unrestricted_unions
Feature record: CXX_FEATURE:1cxx_user_literals
Feature record: CXX_FEATURE:1cxx_variable_templates
Feature record: CXX_FEATURE:1cxx_variadic_macros
Feature record: CXX_FEATURE:1cxx_variadic_templates
Detecting CXX [-std=c++14] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_95cd3/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_95cd3.dir/build.make CMakeFiles/cmTC_95cd3.dir/build
Building CXX object CMakeFiles/cmTC_95cd3.dir/feature_tests.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -std=c++14 -o CMakeFiles/cmTC_95cd3.dir/feature_tests.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_95cd3
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_95cd3.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_95cd3.dir/feature_tests.cxx.o -o cmTC_95cd3
Detecting CXX [-std=c++11] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_5a1ed/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_5a1ed.dir/build.make CMakeFiles/cmTC_5a1ed.dir/build
Building CXX object CMakeFiles/cmTC_5a1ed.dir/feature_tests.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -std=c++11 -o CMakeFiles/cmTC_5a1ed.dir/feature_tests.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_5a1ed
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_5a1ed.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_5a1ed.dir/feature_tests.cxx.o -o cmTC_5a1ed
Feature record: CXX_FEATURE:0cxx_aggregate_default_initializers
Feature record: CXX_FEATURE:0cxx_attribute_deprecated
Feature record: CXX_FEATURE:0cxx_binary_literals
Feature record: CXX_FEATURE:0cxx_contextual_conversions
Feature record: CXX_FEATURE:0cxx_decltype_auto
Feature record: CXX_FEATURE:0cxx_digit_separators
Feature record: CXX_FEATURE:0cxx_generic_lambdas
Feature record: CXX_FEATURE:0cxx_lambda_init_captures
Feature record: CXX_FEATURE:0cxx_relaxed_constexpr
Feature record: CXX_FEATURE:0cxx_return_type_deduction
Feature record: CXX_FEATURE:0cxx_variable_templates
Detecting CXX [-std=c++98] compiler features compiled with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_01199/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_01199.dir/build.make CMakeFiles/cmTC_01199.dir/build
Building CXX object CMakeFiles/cmTC_01199.dir/feature_tests.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -std=c++98 -o CMakeFiles/cmTC_01199.dir/feature_tests.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/feature_tests.cxx
Linking CXX executable cmTC_01199
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_01199.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_01199.dir/feature_tests.cxx.o -o cmTC_01199
Feature record: CXX_FEATURE:0cxx_alias_templates
Feature record: CXX_FEATURE:0cxx_alignas
Feature record: CXX_FEATURE:0cxx_alignof
Feature record: CXX_FEATURE:0cxx_attributes
Feature record: CXX_FEATURE:0cxx_auto_type
Feature record: CXX_FEATURE:0cxx_constexpr
Feature record: CXX_FEATURE:0cxx_decltype_incomplete_return_types
Feature record: CXX_FEATURE:0cxx_default_function_template_args
Feature record: CXX_FEATURE:0cxx_defaulted_functions
Feature record: CXX_FEATURE:0cxx_defaulted_move_initializers
Feature record: CXX_FEATURE:0cxx_delegating_constructors
Feature record: CXX_FEATURE:0cxx_deleted_functions
Feature record: CXX_FEATURE:0cxx_enum_forward_declarations
Feature record: CXX_FEATURE:0cxx_explicit_conversions
Feature record: CXX_FEATURE:0cxx_extended_friend_declarations
Feature record: CXX_FEATURE:0cxx_extern_templates
Feature record: CXX_FEATURE:0cxx_final
Feature record: CXX_FEATURE:0cxx_func_identifier
Feature record: CXX_FEATURE:0cxx_generalized_initializers
Feature record: CXX_FEATURE:0cxx_inheriting_constructors
Feature record: CXX_FEATURE:0cxx_inline_namespaces
Feature record: CXX_FEATURE:0cxx_lambdas
Feature record: CXX_FEATURE:0cxx_local_type_template_args
Feature record: CXX_FEATURE:0cxx_long_long_type
Feature record: CXX_FEATURE:0cxx_noexcept
Feature record: CXX_FEATURE:0cxx_nonstatic_member_init
Feature record: CXX_FEATURE:0cxx_nullptr
Feature record: CXX_FEATURE:0cxx_override
Feature record: CXX_FEATURE:0cxx_range_for
Feature record: CXX_FEATURE:0cxx_raw_string_literals
Feature record: CXX_FEATURE:0cxx_reference_qualified_functions
Feature record: CXX_FEATURE:0cxx_right_angle_brackets
Feature record: CXX_FEATURE:0cxx_rvalue_references
Feature record: CXX_FEATURE:0cxx_sizeof_member
Feature record: CXX_FEATURE:0cxx_static_assert
Feature record: CXX_FEATURE:0cxx_strong_enums
Feature record: CXX_FEATURE:0cxx_thread_local
Feature record: CXX_FEATURE:0cxx_trailing_return_types
Feature record: CXX_FEATURE:0cxx_unicode_literals
Feature record: CXX_FEATURE:0cxx_uniform_initialization
Feature record: CXX_FEATURE:0cxx_unrestricted_unions
Feature record: CXX_FEATURE:0cxx_user_literals
Feature record: CXX_FEATURE:0cxx_variadic_macros
Feature record: CXX_FEATURE:0cxx_variadic_templates
Determining if the include file istream exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_06580/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_06580.dir/build.make CMakeFiles/cmTC_06580.dir/build
Building CXX object CMakeFiles/cmTC_06580.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_06580.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_06580
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_06580.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_06580.dir/CheckIncludeFile.cxx.o -o cmTC_06580
Determining if the include file ostream exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_12340/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_12340.dir/build.make CMakeFiles/cmTC_12340.dir/build
Building CXX object CMakeFiles/cmTC_12340.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_12340.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_12340
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_12340.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_12340.dir/CheckIncludeFile.cxx.o -o cmTC_12340
Determining if the include file fstream exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_e5aa6/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_e5aa6.dir/build.make CMakeFiles/cmTC_e5aa6.dir/build
Building CXX object CMakeFiles/cmTC_e5aa6.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_e5aa6.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_e5aa6
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_e5aa6.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_e5aa6.dir/CheckIncludeFile.cxx.o -o cmTC_e5aa6
Determining if the include file sstream exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_01676/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_01676.dir/build.make CMakeFiles/cmTC_01676.dir/build
Building CXX object CMakeFiles/cmTC_01676.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_01676.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_01676
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_01676.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_01676.dir/CheckIncludeFile.cxx.o -o cmTC_01676
Determining if the include file ios exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_238df/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_238df.dir/build.make CMakeFiles/cmTC_238df.dir/build
Building CXX object CMakeFiles/cmTC_238df.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_238df.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_238df
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_238df.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_238df.dir/CheckIncludeFile.cxx.o -o cmTC_238df
Determining if the include file iostream exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_74c9c/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_74c9c.dir/build.make CMakeFiles/cmTC_74c9c.dir/build
Building CXX object CMakeFiles/cmTC_74c9c.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_74c9c.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_74c9c
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_74c9c.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_74c9c.dir/CheckIncludeFile.cxx.o -o cmTC_74c9c
Determining if the include file iomanip exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_14a82/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_14a82.dir/build.make CMakeFiles/cmTC_14a82.dir/build
Building CXX object CMakeFiles/cmTC_14a82.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_14a82.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_14a82
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_14a82.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_14a82.dir/CheckIncludeFile.cxx.o -o cmTC_14a82
Run Build Command:"/Users/fca/bin/gmake" "cmTC_d976b/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_d976b.dir/build.make CMakeFiles/cmTC_d976b.dir/build
Building CXX object CMakeFiles/cmTC_d976b.dir/CheckIncludeFile.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_d976b.dir/CheckIncludeFile.cxx.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.cxx
Linking CXX executable cmTC_d976b
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_d976b.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_d976b.dir/CheckIncludeFile.cxx.o -o cmTC_d976b
Determining if the CXX compiler has std namespace passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_bc168/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_bc168.dir/build.make CMakeFiles/cmTC_bc168.dir/build
Building CXX object CMakeFiles/cmTC_bc168.dir/TestForSTDNamespace.cxx.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -o CMakeFiles/cmTC_bc168.dir/TestForSTDNamespace.cxx.o -c /sw/share/cmake-3.8/Modules/TestForSTDNamespace.cxx
Linking CXX executable cmTC_bc168
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_bc168.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/c++ -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_bc168.dir/TestForSTDNamespace.cxx.o -o cmTC_bc168
Determining if the include file pthread.h exists passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_7b68a/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_7b68a.dir/build.make CMakeFiles/cmTC_7b68a.dir/build
Building C object CMakeFiles/cmTC_7b68a.dir/CheckIncludeFile.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_7b68a.dir/CheckIncludeFile.c.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c
Linking C executable cmTC_7b68a
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_7b68a.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_7b68a.dir/CheckIncludeFile.c.o -o cmTC_7b68a
Determining if the pthread_create exist passed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_2bd3f/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_2bd3f.dir/build.make CMakeFiles/cmTC_2bd3f.dir/build
Building C object CMakeFiles/cmTC_2bd3f.dir/CheckSymbolExists.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_2bd3f.dir/CheckSymbolExists.c.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c
Linking C executable cmTC_2bd3f
/sw/bin/cmake -E cmake_link_script CMakeFiles/cmTC_2bd3f.dir/link.txt --verbose=1
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -Wl,-search_paths_first -Wl,-headerpad_max_install_names CMakeFiles/cmTC_2bd3f.dir/CheckSymbolExists.c.o -o cmTC_2bd3f
File /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <pthread.h>
int main(int argc, char** argv)
(void)argv;
#ifndef pthread_create
return ((int*)(&pthread_create))[argc];
#else
(void)argc;
return 0;
#endif
CMakeError.log (1,041 bytes)
Determining if the include file GL/gl.h exists failed with the following output:
Run Build Command:"/Users/fca/bin/gmake" "cmTC_d8c6e/fast"
/Users/fca/bin/gmake -f CMakeFiles/cmTC_d8c6e.dir/build.make CMakeFiles/cmTC_d8c6e.dir/build
Building C object CMakeFiles/cmTC_d8c6e.dir/CheckIncludeFile.c.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/cc -o CMakeFiles/cmTC_d8c6e.dir/CheckIncludeFile.c.o -c /usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c
/usr/local/FreeCAD/build/CMakeFiles/CMakeTmp/CheckIncludeFile.c:1:10: fatal error: 'GL/gl.h' file not found
#include <GL/gl.h>
1 error generated.
gmake[1]: *** [CMakeFiles/cmTC_d8c6e.dir/build.make:66: CMakeFiles/cmTC_d8c6e.dir/CheckIncludeFile.c.o] Error 1
gmake: *** [Makefile:126: cmTC_d8c6e/fast] Error 2
Please post to the forum first before opening ticket. |
OP did you make a forum thread yet? If so please link to it. Thanks |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=4&t=22565 Seems OP found a solution in https://forum.freecadweb.org/viewtopic.php?f=4&t=22565&hilit=federico#p174924 But is reporting that the docs are obsolete and misleading CC @blacey Linking to: https://github.com/FreeCAD/homebrew-freecad/issues/47 |
For completeness I am reporting here the solution found. FreeCAD needs to be configured with cmake -DBUILD_QT5=1 -DFREECAD_USE_EXTERNAL_KDL=1 -DBUILD_FEM_NETGEN=1 -DFREECAD_CREATE_MAC_APP=1 -DCMAKE_BUILD_TYPE="Release" -DCMAKE_PREFIX_PATH=/usr/local/Cellar/qt\@5.6/5.6.2/ -DCMAKE_INSTALL_PREFIX=/Applications -DBUILD_JTREADER=ON -DBUILD_SANDBOX=ON -DBUILD_TEMPLATE=ON -DFREECAD_USE_FREETYPE=OFF ../FreeCAD-git/ |
Thanks for the feedback and while I agree it could the "simpler" or more automatic, specifying the prefix is required because Home-brew supports multiple Qt5 versions. Here is how we build on Travis (database of record): Qt5 cmake args Eigen cmake args This is not a bug. |
Closing as 'No change required' Thanks blacey. |
| 2017-05-20 09:40 | federico.carminati@gmail.com | New Issue | |
| 2017-05-20 09:40 | federico.carminati@gmail.com | File Added: CMakeOutput.log | |
| 2017-05-20 09:40 | federico.carminati@gmail.com | File Added: CMakeError.log | |
| 2017-05-20 19:03 | Kunda1 | Note Added: 0009067 | |
| 2017-05-24 22:00 | Kunda1 | Severity | major => minor |
| 2017-05-24 22:02 | Kunda1 | Note Added: 0009118 | |
| 2017-05-26 13:19 | Kunda1 | Note Added: 0009148 | |
| 2017-05-26 13:20 | Kunda1 | Assigned To | => blacey |
| 2017-05-26 13:20 | Kunda1 | Status | new => assigned |
| 2017-05-26 13:20 | Kunda1 | Tag Attached: MacOSX | |
| 2017-05-26 13:21 | Kunda1 | Priority | high => normal |
| 2017-05-26 13:27 | Kunda1 | Relationship added | related to 0003042 |
| 2017-05-26 13:31 | Kunda1 | Note Edited: 0009148 | |
| 2017-05-29 08:21 | federico.carminati@gmail.com | Note Added: 0009182 | |
| 2017-06-03 19:19 | blacey | Note Added: 0009279 | |
| 2017-06-10 11:45 | Kunda1 | Status | assigned => closed |
| 2017-06-10 11:45 | Kunda1 | Resolution | open => no change required |
| 2017-06-10 11:45 | Kunda1 | Note Added: 0009332 | |
