| 0003058 | Draft | Bug | public | 2017-05-29 10:47 | 2018-02-21 14:36 |
| Reporter | easyw-fc | Assigned To | wmayer | ||
| Summary | 0003058: wrong dimension "Snap Points" in Draft WB in Imported hierarchical STEP files | ||||
| Description | this problems with snap points is raising only if the STEP model loaded has a hierarchy or is a multipart object... The new container App::Part doesn't work correctly with the Draft Snap points, but it does work fine with Part Measure tools... https://forum.freecadweb.org/viewtopic.php?f=3&t=22455#p174304 | ||||
| Steps To Reproduce | You can test simply loading this Hierarchical STEP file (as1-oc-214.stp) and try to place dimensions to the model... Everything is working fine instead if a single object STEP file is loaded (io1-cm-214.stp) https://forum.freecadweb.org/viewtopic.php?f=3&t=22455#p174304 | ||||
| Tags | App::Part, Draft, hierarchy, snap, STEP | ||||
| 2017-05-29 10:47 | easyw-fc | New Issue | |
| 2017-05-29 10:47 | easyw-fc | Tag Attached: step hierarchy App::Part draft snap | |
| 2017-05-29 10:47 | easyw-fc | Tag Detached: step hierarchy App::Part draft snap | |
| 2017-05-29 10:48 | easyw-fc | Tag Attached: App::Part | |
| 2017-05-29 10:48 | easyw-fc | Tag Attached: Draft | |
| 2017-05-29 10:48 | easyw-fc | Tag Attached: snap | |
| 2017-05-29 10:48 | easyw-fc | Tag Attached: STEP | |
| 2017-05-29 10:48 | easyw-fc | Tag Attached: hierarchy | |
| 2017-06-14 13:02 | Kunda1 | Status | new => confirmed |
| 2017-06-29 16:56 | Kunda1 | Note Added: 0009613 | |
| 2017-06-29 16:57 | Kunda1 | Tag Attached: #pending | |
| 2017-10-10 02:20 | Kunda1 | Assigned To | => vejmarie |
| 2017-10-10 02:20 | Kunda1 | Status | confirmed => assigned |
| 2017-10-10 02:20 | Kunda1 | Note Added: 0010277 | |
| 2017-12-11 19:31 | Kunda1 | Target Version | => 0.17 |
| 2018-02-18 16:52 | normandc | Relationship added | related to 0003350 |
| 2018-02-21 10:12 | wmayer | Status | assigned => closed |
| 2018-02-21 10:12 | wmayer | Resolution | open => fixed |
| 2018-02-21 10:12 | wmayer | Fixed in Version | => 0.17 |
| 2018-02-21 10:12 | wmayer | Note Added: 0010966 | |
| 2018-02-21 14:36 | Kunda1 | Assigned To | vejmarie => wmayer |
| 2018-02-21 14:36 | Kunda1 | Tag Detached: #pending |
