| Reporter | normandc | Assigned To | wmayer | |
| Status | closed | Resolution | fixed | |
| Product Version | 0.17 | |
| Fixed in Version | 0.17 | |
| Summary | 0003350: Draft Snapping does not recognize App::Part container |
| Description | Draft Snaps are non-functional with Part containers (App::Part). As this is a general purpose container available in all workbenches from the Structure toolbar, being able to use Draft editing tools along with Draft Snapping on Part containers is very much desirable. |
| Steps To Reproduce |
- Open attached FC017_simple_Part_container.fcstd
- Switch to Draft workbench
- Select Part container in the Model tree
- Click on Draft Move command
- Set end point snap mode active
- Try to select any of the cube's vertices.
| Tags | snap |
| FreeCAD Information | |
