| 0003130 | FreeCAD | Bug | public | 2017-07-17 20:56 | 2019-07-29 15:01 |
| Reporter | pablogil | Assigned To | wmayer | ||
| Platform | Apple | OS | macOS Sierra | OS Version | 10.12.5 |
| Summary | 0003130: FreeCAD 0.17 Qt5 bugs with external display | ||||
| Description | When connecting an external display (Dell U2913WM) with a macbook Pro 15'' TouchBar (with retina display) some buttons icons are rescaled incorrectly and what is more important, there is a big offset from your mouse position and where the 3D window thinks you are in "screen space". You can see both problems in the attached screenshot. Thanks | ||||
| Steps To Reproduce | Connect laptop to external display and open FreeCAD | ||||
| Tags | GUI, macOS, Qt5 | ||||
Confirmed on both accounts: Icons shown above are scaled up and draft snap has an offset from the mouse location. Tested on 1080p display using the version below. Somewhere some scale factor is not updated when moving to a different display. OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11474 (Git) Build type: Release Branch: (detached from 74e7940) Hash: 74e794002464b5230966bae86ce84409b0ee74fc Python version: 2.7.13 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.1.0 |
@f3nix partially fixes this issue in https://forum.freecad.org/viewtopic.php?f=10&t=19724&start=70#p185459 |
A solution has been added with https://github.com/FreeCAD/FreeCAD/commit/0a375d826728a55a99c6a2586780e88f2ee606a8 Can someone test if it really fixes the issue? |
I have just tried it out and, without knowing if it was a partial solution or not I can say that:
Can anyone test with a higher version of Qt5 ? |
https://github.com/FreeCAD/FreeCAD/commit/2f2d5053599785fdc8db481682746066911033b4 |
| 2017-07-17 20:56 | pablogil | New Issue | |
| 2017-07-17 20:56 | pablogil | File Added: bugs.png | |
| 2017-07-17 20:56 | pablogil | Tag Attached: GUI | |
| 2017-07-17 20:56 | pablogil | Tag Attached: MacOSX | |
| 2017-07-17 20:56 | pablogil | Tag Attached: Qt5 | |
| 2017-07-17 21:41 | peterl94 | Note Added: 0009768 | |
| 2017-07-17 21:41 | peterl94 | Note Edited: 0009768 | |
| 2017-07-17 23:20 | Kunda1 | Relationship added | child of 0002986 |
| 2017-07-18 00:46 | Kunda1 | Status | new => confirmed |
| 2017-07-18 00:47 | Kunda1 | Target Version | => 0.17 |
| 2017-08-14 14:56 | Kunda1 | Note Added: 0009933 | |
| 2017-09-20 14:02 | wmayer | Note Added: 0010138 | |
| 2017-09-21 15:34 | pablogil | Note Added: 0010148 | |
| 2017-12-03 07:16 | wmayer | Target Version | 0.17 => 0.18 |
| 2018-06-19 05:47 | chrisb | Relationship added | has duplicate 0003512 |
| 2018-10-15 07:14 | Kunda1 | Note Added: 0012027 | |
| 2019-03-14 18:29 | wmayer | Assigned To | => wmayer |
| 2019-03-14 18:29 | wmayer | Status | confirmed => closed |
| 2019-03-14 18:29 | wmayer | Resolution | open => fixed |
| 2019-03-14 18:29 | wmayer | Fixed in Version | => 0.19 |
| 2019-03-14 18:29 | wmayer | Note Added: 0012906 | |
| 2019-03-14 18:29 | wmayer | Target Version | 0.18 => 0.19 |
| 2019-07-29 15:01 | Kunda1 | Changeset attached | => FreeCAD releases/FreeCAD-0-18 64cb745d |
