| 0002986 | FreeCAD | Bug | public | 2017-03-27 17:21 | 2019-05-09 01:08 |
| Reporter | Kunda1 | Assigned To | wmayer | ||
| Priority | high | Severity | major | Reproducibility | N/A |
| Target Version | 0.18 | ||||
| Summary | 0002986: Port from Qt4 to Qt5 (Ongoing) | ||||
| Description | Ticket to track all the work porting FreeCAD from Qt4 to Qt5 | ||||
| Tags | Qt, Qt5 | ||||
| parent of | 0002952 | closed | FreeCAD | Save Image... results in all-black image file when FreeCAD is built with Qt 5 | |
| parent of | 0001401 | closed | wmayer | FreeCAD | Problem w/ MDI windows on OSX (AKA transition from QGLWidget to QOpenGLWidget ) |
| parent of | 0002868 | closed | FreeCAD | Port QtWebKit to QtWebEngine | |
| parent of | 0002953 | closed | FreeCAD | Icons not rendered on New doc | |
| parent of | 0002942 | closed | FreeCAD | Qt5 - Osx - automatic trees selection after cancel | |
| parent of | 0001867 | closed | Drawing | Use QtWebKit (QWebView) instead of QtSvg for DW drawing area | |
| parent of | 0003130 | closed | wmayer | FreeCAD | FreeCAD 0.17 Qt5 bugs with external display |
| parent of | 0003522 | closed | chrisb | FreeCAD | Save Image creates incorrect result with transparency |
| parent of | 0003774 | closed | FreeCAD | Support of QtWebEngine as alternative to QtWebkit |
FreeCAD: master d5c074f8 2015-12-15 06:58:54 Committer: wmayer Details Diff |
QString::toAscii() is obsolete in Qt5. Replace it with toLatin1(). This change is Qt4/Qt5 neutral. |
Affected Issues 0002986 |
| mod - src/App/Branding.cpp | Diff File | ||
| mod - src/Base/Uuid.cpp | Diff File | ||
| mod - src/Gui/Action.cpp | Diff File | ||
| mod - src/Gui/CallTips.cpp | Diff File | ||
| mod - src/Gui/Command.cpp | Diff File | ||
| mod - src/Gui/CommandDoc.cpp | Diff File | ||
| mod - src/Gui/CommandStd.cpp | Diff File | ||
| mod - src/Gui/CommandView.cpp | Diff File | ||
| mod - src/Gui/DlgActionsImp.cpp | Diff File | ||
| mod - src/Gui/DlgCommandsImp.cpp | Diff File | ||
| mod - src/Gui/DlgCustomizeSpaceball.cpp | Diff File | ||
| mod - src/Gui/DlgDisplayPropertiesImp.cpp | Diff File | ||
| mod - src/Gui/DlgEditorImp.cpp | Diff File | ||
| mod - src/Gui/DlgGeneralImp.cpp | Diff File | ||
| mod - src/Gui/DlgKeyboardImp.cpp | Diff File | ||
| mod - src/Gui/DlgParameterImp.cpp | Diff File | ||
| mod - src/Gui/DlgTipOfTheDayImp.cpp | Diff File | ||
| mod - src/Gui/DlgToolbarsImp.cpp | Diff File | ||
| mod - src/Gui/DlgWorkbenchesImp.cpp | Diff File | ||
| mod - src/Gui/DockWindowManager.cpp | Diff File | ||
| mod - src/Gui/Document.cpp | Diff File | ||
| mod - src/Gui/DownloadItem.cpp | Diff File | ||
| mod - src/Gui/FileDialog.cpp | Diff File | ||
| mod - src/Gui/HelpView.cpp | Diff File | ||
| mod - src/Gui/MainWindow.cpp | Diff File | ||
| mod - src/Gui/NetworkRetriever.cpp | Diff File | ||
| mod - src/Gui/OnlineDocumentation.cpp | Diff File | ||
| mod - src/Gui/Placement.cpp | Diff File | ||
| mod - src/Gui/PythonConsole.cpp | Diff File | ||
| mod - src/Gui/PythonConsolePy.cpp | Diff File | ||
| mod - src/Gui/Quarter/KeyboardP.cpp | Diff File | ||
| mod - src/Gui/SelectionView.cpp | Diff File | ||
| mod - src/Gui/SoFCOffscreenRenderer.cpp | Diff File | ||
| mod - src/Gui/TaskView/TaskAppearance.cpp | Diff File | ||
| mod - src/Gui/ViewProviderAnnotation.cpp | Diff File | ||
| mod - src/Gui/WidgetFactory.cpp | Diff File | ||
| mod - src/Gui/Widgets.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/Command.cpp | Diff File | ||
| mod - src/Mod/Inspection/Gui/VisualInspection.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/Command.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgRegularSolidImp.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/ViewProviderCurvature.cpp | Diff File | ||
| mod - src/Mod/MeshPart/Gui/Tessellation.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/Command.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/CrossSections.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgExtrusion.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgFilletEdges.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPrimitives.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgRevolution.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/Mirroring.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskCheckGeometry.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskLoft.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskShapeBuilder.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskSweep.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/FeaturePickDialog.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/CommandTrajectory.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/DrawSketchHandler.cpp | Diff File | ||
| mod - src/Mod/Test/Gui/UnitTestPy.cpp | Diff File | ||
FreeCAD: master cd2db00f 2015-12-15 07:00:20 Committer: wmayer Details Diff |
QString::fromAscii() is obsolete in Qt5. Replace it with fromLatin1(). This change is Qt4/Qt5 neutral. |
| mod - src/Base/UnitsApi.cpp | Diff File | ||
| mod - src/Gui/BitmapFactory.cpp | Diff File | ||
| mod - src/Gui/CommandTest.cpp | Diff File | ||
| mod - src/Gui/DlgMacroExecuteImp.cpp | Diff File | ||
| mod - src/Gui/DlgPreferencesImp.cpp | Diff File | ||
| mod - src/Gui/DlgProjectInformationImp.cpp | Diff File | ||
| mod - src/Gui/DlgSettings3DViewImp.cpp | Diff File | ||
| mod - src/Gui/DlgSettingsDocumentImp.cpp | Diff File | ||
| mod - src/Gui/DlgUnitsCalculatorImp.cpp | Diff File | ||
| mod - src/Gui/DownloadDialog.cpp | Diff File | ||
| mod - src/Gui/EditorView.cpp | Diff File | ||
| mod - src/Gui/ExpressionBinding.cpp | Diff File | ||
| mod - src/Gui/ExpressionCompleter.cpp | Diff File | ||
| mod - src/Gui/GraphvizView.cpp | Diff File | ||
| mod - src/Gui/InputField.cpp | Diff File | ||
| mod - src/Gui/InputVector.cpp | Diff File | ||
| mod - src/Gui/InputVector.h | Diff File | ||
| mod - src/Gui/Language/Translator.cpp | Diff File | ||
| mod - src/Gui/MDIView.cpp | Diff File | ||
| mod - src/Gui/Macro.cpp | Diff File | ||
| mod - src/Gui/MenuManager.cpp | Diff File | ||
| mod - src/Gui/NavigationStyle.cpp | Diff File | ||
| mod - src/Gui/PrefWidgets.cpp | Diff File | ||
| mod - src/Gui/ProgressBar.cpp | Diff File | ||
| mod - src/Gui/QListWidgetCustom.cpp | Diff File | ||
| mod - src/Gui/QuantitySpinBox.cpp | Diff File | ||
| mod - src/Gui/Quarter/QuarterWidget.h | Diff File | ||
| mod - src/Gui/ReportView.cpp | Diff File | ||
| mod - src/Gui/SceneInspector.cpp | Diff File | ||
| mod - src/Gui/Selection.cpp | Diff File | ||
| mod - src/Gui/SoFCSelection.cpp | Diff File | ||
| mod - src/Gui/SoFCUnifiedSelection.cpp | Diff File | ||
| mod - src/Gui/SoTextLabel.cpp | Diff File | ||
| mod - src/Gui/SpinBox.cpp | Diff File | ||
| mod - src/Gui/Splashscreen.cpp | Diff File | ||
| mod - src/Gui/SplitView3DInventor.cpp | Diff File | ||
| mod - src/Gui/TaskView/TaskSelectLinkProperty.cpp | Diff File | ||
| mod - src/Gui/TextEdit.cpp | Diff File | ||
| mod - src/Gui/TextureMapping.cpp | Diff File | ||
| mod - src/Gui/Thumbnail.cpp | Diff File | ||
| mod - src/Gui/ToolBarManager.cpp | Diff File | ||
| mod - src/Gui/ToolBoxManager.cpp | Diff File | ||
| mod - src/Gui/Tree.cpp | Diff File | ||
| mod - src/Gui/View3DInventor.cpp | Diff File | ||
| mod - src/Gui/View3DInventorViewer.cpp | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyModel.cpp | Diff File | ||
| mod - src/Main/FreeCADGuiPy.cpp | Diff File | ||
| mod - src/Main/MainGui.cpp | Diff File | ||
| mod - src/Mod/Complete/Gui/Workbench.h | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskFemConstraint.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskFemConstraintBearing.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskFemConstraintForce.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskFemConstraintGear.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskFemConstraintPressure.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskFemConstraintPulley.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/TaskObjectName.cpp | Diff File | ||
| mod - src/Mod/Image/Gui/ImageView.cpp | Diff File | ||
| mod - src/Mod/Import/Gui/AppImportGuiPy.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgEvaluateMeshImp.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/Workbench.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/CommandParametric.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgBooleanOperation.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskFaceColors.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskOffset.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskThickness.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskDraftParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskGrooveParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskLinearPatternParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskMirroredParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskMultiTransformParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPadParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPocketParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPolarPatternParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskRevolutionParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskScaledParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskTransformedParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ViewProviderTransformed.cpp | Diff File | ||
| mod - src/Mod/Path/Gui/AppPathGuiPy.cpp | Diff File | ||
| mod - src/Mod/Path/Gui/TaskDlgPathCompound.cpp | Diff File | ||
| mod - src/Mod/Raytracing/Gui/Command.cpp | Diff File | ||
| mod - src/Mod/Raytracing/Gui/ViewProvider.cpp | Diff File | ||
| mod - src/Mod/ReverseEngineering/Gui/FitBSplineSurface.cpp | Diff File | ||
| mod - src/Mod/ReverseEngineering/Gui/Poisson.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/TaskEdge2TracParameter.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/TaskRobot6Axis.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/TaskTrajectory.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/TaskTrajectoryDressUpParameter.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/TrajectorySimulate.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/Workbench.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CommandSketcherTools.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/SoDatumLabel.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherConstrains.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/TaskSketcherElements.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SpreadsheetView.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/ViewProviderSpreadsheet.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/Workbench.cpp | Diff File | ||
| mod - src/Mod/Test/Gui/UnitTestImp.cpp | Diff File | ||
| mod - src/Mod/Web/Gui/AppWebGuiPy.cpp | Diff File | ||
| mod - src/Mod/Web/Gui/BrowserView.h | Diff File | ||
FreeCAD: master 3b463f21 2015-12-15 07:01:09 Committer: wmayer Details Diff |
Qt::WFlags is obsolete in Qt5. Replace it with Qt::WindowFlags. This change is Qt4/Qt5 neutral. |
| mod - src/Gui/DemoMode.cpp | Diff File | ||
| mod - src/Gui/DemoMode.h | Diff File | ||
| mod - src/Gui/DlgActivateWindowImp.cpp | Diff File | ||
| mod - src/Gui/DlgActivateWindowImp.h | Diff File | ||
| mod - src/Gui/DlgCustomizeImp.cpp | Diff File | ||
| mod - src/Gui/DlgCustomizeImp.h | Diff File | ||
| mod - src/Gui/DlgDisplayPropertiesImp.h | Diff File | ||
| mod - src/Gui/DlgEditFileIncludeProptertyExternal.cpp | Diff File | ||
| mod - src/Gui/DlgEditFileIncludeProptertyExternal.h | Diff File | ||
| mod - src/Gui/DlgMacroExecuteImp.h | Diff File | ||
| mod - src/Gui/DlgMacroRecordImp.cpp | Diff File | ||
| mod - src/Gui/DlgMacroRecordImp.h | Diff File | ||
| mod - src/Gui/DlgMaterialPropertiesImp.cpp | Diff File | ||
| mod - src/Gui/DlgMaterialPropertiesImp.h | Diff File | ||
| mod - src/Gui/DlgParameterImp.h | Diff File | ||
| mod - src/Gui/DlgPreferencesImp.h | Diff File | ||
| mod - src/Gui/DlgProjectInformationImp.h | Diff File | ||
| mod - src/Gui/DlgProjectUtility.cpp | Diff File | ||
| mod - src/Gui/DlgProjectUtility.h | Diff File | ||
| mod - src/Gui/DlgPropertyLink.cpp | Diff File | ||
| mod - src/Gui/DlgPropertyLink.h | Diff File | ||
| mod - src/Gui/DlgRunExternal.cpp | Diff File | ||
| mod - src/Gui/DlgRunExternal.h | Diff File | ||
| mod - src/Gui/DlgSettingsColorGradientImp.cpp | Diff File | ||
| mod - src/Gui/DlgSettingsColorGradientImp.h | Diff File | ||
| mod - src/Gui/DlgTipOfTheDayImp.h | Diff File | ||
| mod - src/Gui/DlgUnitsCalculatorImp.h | Diff File | ||
| mod - src/Gui/FileDialog.h | Diff File | ||
| mod - src/Gui/MDIView.h | Diff File | ||
| mod - src/Gui/MainWindow.h | Diff File | ||
| mod - src/Gui/ManualAlignment.cpp | Diff File | ||
| mod - src/Gui/Placement.h | Diff File | ||
| mod - src/Gui/SceneInspector.h | Diff File | ||
| mod - src/Gui/Splashscreen.h | Diff File | ||
| mod - src/Gui/SplitView3DInventor.h | Diff File | ||
| mod - src/Gui/TextureMapping.h | Diff File | ||
| mod - src/Gui/Transform.cpp | Diff File | ||
| mod - src/Gui/Transform.h | Diff File | ||
| mod - src/Gui/View3DInventor.h | Diff File | ||
| mod - src/Gui/Widgets.h | Diff File | ||
| mod - src/Mod/Image/Gui/GLImageBox.cpp | Diff File | ||
| mod - src/Mod/Image/Gui/GLImageBox.h | Diff File | ||
| mod - src/Mod/Inspection/Gui/VisualInspection.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgEvaluateMeshImp.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgRegularSolidImp.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgSmoothing.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/DlgSmoothing.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/RemoveComponents.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/RemoveComponents.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/Segmentation.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/Segmentation.h | Diff File | ||
| mod - src/Mod/Part/Gui/CrossSections.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgExtrusion.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgFilletEdges.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartBoxImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartBoxImp.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartCylinderImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartCylinderImp.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartImportIgesImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartImportIgesImp.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartImportStepImp.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/DlgPartImportStepImp.h | Diff File | ||
| mod - src/Mod/Part/Gui/DlgRevolution.h | Diff File | ||
| mod - src/Mod/Points/Gui/DlgPointsReadImp.cpp | Diff File | ||
| mod - src/Mod/Points/Gui/DlgPointsReadImp.h | Diff File | ||
| mod - src/Mod/Test/Gui/UnitTestImp.h | Diff File | ||
FreeCAD: master f7b8135d 2015-12-20 11:06:56 Details Diff |
Add missing forward declaration of QPrinter to MDIView.h. This change is Qt4/Qt5 neutral. |
FreeCAD: master 4d85f0e4 2015-12-20 18:47:15 Committer: wmayer Details Diff |
QWidget::setShown() is obsolete in Qt4. Replace it with setVisible(). This change is Qt4/Qt5 neutral. |
| mod - src/Gui/CommandWindow.cpp | Diff File | ||
FreeCAD: master d3d01db9 2015-12-20 20:08:36 Committer: wmayer Details Diff |
QFileDialg::setFilters() is obsolete in Qt4. Replace it with setNameFilters(). This change is Qt4/Qt5 neutral. |
| mod - src/Mod/Drawing/Gui/DrawingView.cpp | Diff File | ||
FreeCAD: master e6379ea6 2015-12-20 20:12:26 Committer: wmayer Details Diff |
QFileDialg::selectedFilter() is obsolete in Qt4. Replace it with selectedNameFilter(). This change is Qt4/Qt5 neutral. |
FreeCAD: master 7d0e892d 2015-12-21 06:15:07 Committer: wmayer Details Diff |
Qt4's qglobal.h defined TRUE and FALSE. Qt5 does not do it anymore. Replace it with true and false. https://qt.gitorious.org/qt/qtbase/commit/158f39ec7870c54ff3a15f72fe151062d6daa172 This change is Qt4/Qt5 neutral. |
| mod - src/Base/FileInfo.h | Diff File | ||
| mod - src/Base/Tools2D.cpp | Diff File | ||
| mod - src/Gui/BlenderNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/CADNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/DlgInputDialogImp.cpp | Diff File | ||
| mod - src/Gui/DlgInputDialogImp.h | Diff File | ||
| mod - src/Gui/DlgOnlineHelpImp.cpp | Diff File | ||
| mod - src/Gui/DlgReportViewImp.cpp | Diff File | ||
| mod - src/Gui/GestureNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/InventorNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/MayaGestureNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/MouseSelection.cpp | Diff File | ||
| mod - src/Gui/OpenCascadeNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/Quarter/ImageReader.cpp | Diff File | ||
| mod - src/Gui/Quarter/QuarterWidget.cpp | Diff File | ||
| mod - src/Gui/Quarter/SensorManager.cpp | Diff File | ||
| mod - src/Gui/Quarter/SoQTQuarterAdaptor.cpp | Diff File | ||
| mod - src/Gui/SoAxisCrossKit.cpp | Diff File | ||
| mod - src/Gui/SoAxisCrossKit.h | Diff File | ||
| mod - src/Gui/SoFCBoundingBox.cpp | Diff File | ||
| mod - src/Gui/SoFCDB.cpp | Diff File | ||
| mod - src/Gui/SoFCInteractiveElement.cpp | Diff File | ||
| mod - src/Gui/SoFCSelectionAction.cpp | Diff File | ||
| mod - src/Gui/SoFCSelectionAction.h | Diff File | ||
| mod - src/Gui/SoNavigationDragger.cpp | Diff File | ||
| mod - src/Gui/SoNavigationDragger.h | Diff File | ||
| mod - src/Gui/ToolBox.cpp | Diff File | ||
| mod - src/Gui/TouchpadNavigationStyle.cpp | Diff File | ||
| mod - src/Gui/View3DInventorExamples.cpp | Diff File | ||
| mod - src/Gui/View3DInventorViewer.h | Diff File | ||
| mod - src/Gui/ViewProvider.cpp | Diff File | ||
| mod - src/Gui/ViewProviderGeometryObject.cpp | Diff File | ||
| mod - src/Main/MainPy.cpp | Diff File | ||
| mod - src/Mod/Inspection/Gui/ViewProviderInspection.cpp | Diff File | ||
| mod - src/Mod/Mesh/App/Core/Grid.h | Diff File | ||
| mod - src/Mod/Mesh/App/Core/Helpers.h | Diff File | ||
| mod - src/Mod/Mesh/App/Core/MeshIO.cpp | Diff File | ||
| mod - src/Mod/Mesh/App/Core/tritritest.h | Diff File | ||
| mod - src/Mod/Mesh/App/WildMagic4/Wm4LinearSystem.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/SoFCIndexedFaceSet.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/SoFCMeshObject.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/SoPolygon.cpp | Diff File | ||
| mod - src/Mod/MeshPart/App/MeshAlgos.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/SoBrepEdgeSet.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/SoBrepFaceSet.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/SoBrepPointSet.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/SoFCShapeObject.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/TaskDimension.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderCurveNet.cpp | Diff File | ||
| mod - src/Mod/Part/Gui/ViewProviderMirror.cpp | Diff File | ||
| mod - src/Mod/Path/libarea/kurve/Finite.cpp | Diff File | ||
| mod - src/Mod/Robot/Gui/ViewProviderRobotObject.cpp | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CommandCreateGeo.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/qtcolorpicker.cpp | Diff File | ||
FreeCAD: master 99ca18f5 2015-12-21 19:17:19 Committer: wmayer Details Diff |
QInputDialog::getInteger() is obsolete in Qt4. Replace it with getInt(). This change is Qt4/Qt5 neutral. |
FreeCAD: master 9beb7d21 2015-12-23 20:51:01 Committer: wmayer Details Diff |
QKeySequence::operator QString() is obsolete in Qt5. Use toString(QKeySequence::NativeText) instead. This change is Qt4/Qt5 neutral. |
| mod - src/Gui/Workbench.cpp | Diff File | ||
FreeCAD: master c2a31fe0 2015-12-23 23:54:02 Details Diff |
qVariantValue() is obsolete in Qt4. Replace it with equivalent QVariant::value<T>(value). This change is Qt4/Qt5 neutral. |
FreeCAD: master 9aa3cfb4 2015-12-24 06:32:23 Committer: wmayer Details Diff |
Add missing QMimeData.h includes. This change is Qt4/Qt5 neutral. |
FreeCAD: master ab262717 2015-12-24 07:12:45 Committer: wmayer Details Diff |
QAbstractItemModel::reset() is obsolete in Qt5. Use beginResetModel() and endResetModel() instead. This change is Qt4/Qt5 neutral. |
FreeCAD: master 0aa944a1 2015-12-24 07:32:29 Committer: wmayer Details Diff |
Change includes in Quarter to be compatible with Qt5. This change is Qt4/Qt5 neutral. |
| mod - src/Gui/Quarter/ContextMenu.cpp | Diff File | ||
| mod - src/Gui/Quarter/DragDropHandler.cpp | Diff File | ||
| mod - src/Gui/Quarter/QuarterWidgetP.cpp | Diff File | ||
| mod - src/Gui/Quarter/SpaceNavigatorDevice.cpp | Diff File | ||
FreeCAD: master 62ccb845 2015-12-24 07:41:10 Details Diff |
QFileDialog::selectFilter() is obsolete in Qt4. Replace it with selectNameFilter(). This change is Qt4/Qt5 neutral. |
FreeCAD: master 5be29861 2015-12-24 07:43:21 Details Diff |
QFileDialog::filters() is obsolete in Qt4. Replace it with nameFilters(). This change is Qt4/Qt5 neutral. |
FreeCAD: master db345cb6 2015-12-25 07:55:26 Committer: wmayer Details Diff |
Change includes in Spreadsheet to be compatible with Qt5. This change is Qt4/Qt5 neutral. |
| mod - src/Mod/Spreadsheet/Gui/AppSpreadsheetGui.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/qtcolorpicker.h | Diff File | ||
FreeCAD: master 4ef8c970 2016-02-14 08:20:13 Details Diff |
Qt5 compatibility changes. QString::fromAscii() is obsolete in Qt5. Replace it with fromLatin1(). QString::toAscii() is obsolete in Qt5. Replace it with toLatin1(). QChar::fromAscii() is obsolete in Qt5. Replace it with fromLatin1(). This change is Qt4/Qt5 neutral. |
FreeCAD: master 69c241ba 2016-02-16 10:01:45 wwmayer Details Diff |
Merge pull request 0000094 from f3nix/qt5-compatibility-1 Qt5 compatibility changes. |
FreeCAD: master 8de9436c 2016-02-21 19:16:51 Committer: wmayer Details Diff |
Add missing header files Needed for Qt5, recommended for Qt4 |
| mod - src/Gui/iisTaskPanel/src/iisiconlabel.h | Diff File | ||
| mod - src/Gui/iisTaskPanel/src/iistaskbox.h | Diff File | ||
| mod - src/Gui/iisTaskPanel/src/iistaskgroup.h | Diff File | ||
| mod - src/Gui/iisTaskPanel/src/iistaskheader.cpp | Diff File | ||
| mod - src/Gui/iisTaskPanel/src/iistaskheader.h | Diff File | ||
| mod - src/Gui/iisTaskPanel/src/iistaskpanel.h | Diff File | ||
| mod - src/Gui/iisTaskPanel/src/iistaskpanelscheme.h | Diff File | ||
FreeCAD: master 31fd2d17 2016-02-21 19:20:46 Committer: wmayer Details Diff |
Ensure mutexes are always properly unlocked Error exists with Qt4 and Qt5. Qt5 generated helpful warnings that made it easier to debug. |
| mod - src/Gui/Quarter/SignalThread.cpp | Diff File | ||
FreeCAD: master e1f3fe1b 2016-02-21 19:25:13 Committer: wmayer Details Diff |
Change numBytes() to byteCount() numBytes() is obsolete in Qt 4.8 and removed in Qt5. byteCount() is a drop in replacement that works in 4.8 and 5. |
FreeCAD: master 3f3d8a95 2016-02-21 19:33:37 Committer: wmayer Details Diff |
Fix remaining toAscii/fromAscii Qt5 does not have toAscii or fromAscii. Use toLatin1 and fromLatin1 respectively. Both replacement functions exist in Qt4.8. |
| mod - src/Gui/ProgressDialog.cpp | Diff File | ||
| mod - src/Mod/Sandbox/App/DocumentThread.cpp | Diff File | ||
| mod - src/Mod/Sandbox/Gui/Command.cpp | Diff File | ||
| mod - src/Mod/Sandbox/Gui/GLGraphicsView.cpp | Diff File | ||
| mod - src/Mod/Sandbox/Gui/Overlay.cpp | Diff File | ||
| mod - src/Mod/Sandbox/Gui/TaskPanelView.cpp | Diff File | ||
| mod - src/Mod/Sandbox/Gui/Workbench.cpp | Diff File | ||
| mod - src/Tools/ImageTools/ImageConv/imageconv.cpp | Diff File | ||
| mod - src/Tools/ImageTools/ImageConv/main.cpp | Diff File | ||
| mod - src/Tools/plugins/imageformats/svg/qsvgiohandler.cpp | Diff File | ||
FreeCAD: master 657ac1f5 2016-03-06 13:11:55 Committer: wmayer Details Diff |
Update for PyQt5. This change is Qt5 specific. |
FreeCAD: master d9b7a5fb 2016-04-10 06:29:20 Committer: yorik Details Diff |
Use byteCount() instead of obsolete numBytes(). This change is Qt4/Qt5 neutral. |
FreeCAD: master 3df6064e 2016-04-14 19:35:07 Committer: wmayer Details Diff |
| mod - src/Gui/DAGView/DAGModelGraph.h | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskDatumParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskFeaturePick.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskSketchBasedParameters.cpp | Diff File | ||
FreeCAD: master b5519922 2016-04-14 19:37:12 Committer: wmayer Details Diff |
| mod - src/Gui/DAGView/DAGFilter.cpp | Diff File | ||
| mod - src/Gui/DAGView/DAGModel.cpp | Diff File | ||
| mod - src/Gui/ViewProviderDocumentObjectGroup.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/CommandBody.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ReferenceSelection.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskBooleanParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskDressUpParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskFeatureParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskLoftParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPrimitiveParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/Utils.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ViewProviderDatum.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ViewProviderLoft.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ViewProviderPipe.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/ViewProviderPrimitive.cpp | Diff File | ||
FreeCAD: master 81b59324 2016-04-14 20:50:47 Committer: wmayer Details Diff |
Fix includes to be compatible with Qt5. This change is Qt4/Qt5 neutral. |
| mod - src/Gui/DAGView/DAGView.h | Diff File | ||
| mod - src/Gui/DlgCheckableMessageBox.cpp | Diff File | ||
| mod - src/Gui/DlgCheckableMessageBox.h | Diff File | ||
FreeCAD: master 80e8ae63 2016-04-16 22:46:00 Committer: wmayer Details Diff |
Use PySide2 tools for Qt5. |
| add - cMake/FindPySide2Tools.cmake | Diff File | ||
FreeCAD: master f188995e 2016-04-17 09:44:32 Committer: wmayer Details Diff |
QGraphicsItem * QGraphicsScene::itemAt(const QPointF & position) const is deprecated in Qt4. Use QGraphicsItem * QGraphicsScene::itemAt(const QPointF & position, const QTransform & deviceTransform) const instead. This change is Qt4/Qt5 neutral. |
FreeCAD: master c50bc176 2016-04-21 22:13:49 Details Diff |
FreeCAD: master 2c79424f 2016-06-05 09:58:42 Committer: yorik Details Diff |
| mod - src/Mod/Web/Gui/CookieJar.cpp | Diff File | ||
FreeCAD: master 8b2f435c 2016-06-26 07:44:32 Committer: yorik Details Diff |
| mod - src/Mod/Fem/Gui/TaskPostBoxes.cpp | Diff File | ||
FreeCAD: master 8c6bede7 2016-08-14 16:48:57 Committer: wmayer Details Diff |
| mod - src/Mod/TechDraw/App/DrawSVGTemplate.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGIProjGroup.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGIView.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGIViewDimension.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/ViewProviderPage.cpp | Diff File | ||
FreeCAD: master 7e018146 2016-08-14 17:01:57 Committer: wmayer Details Diff |
| mod - src/Mod/TechDraw/Gui/MDIViewPage.cpp | Diff File | ||
FreeCAD: master 1cdee209 2016-12-12 14:09:21 Details Diff |
Qt4/Qt5 neutral changes: + replace Q_WS_WIN with Q_OS_WIN + replace Q_WS_X11 with Q_OS_LINUX + replace Q_WS_MACX with Q_OS_MACX + set explicit cast to HWND |
| mod - src/Gui/DlgExpressionInput.cpp | Diff File | ||
| mod - src/Gui/GuiApplicationNativeEventAware.cpp | Diff File | ||
| mod - src/Gui/GuiApplicationNativeEventAware.h | Diff File | ||
| mod - src/Gui/WinNativeGestureRecognizers.h | Diff File | ||
FreeCAD: master 57e7d3ad 2016-12-12 14:35:52 Details Diff |
Qt4/Qt5 neutral changes: + remove class DownloadDialog + remove class HelpView + remove class DlgTipOfTheDay |
| mod - src/Gui/CMakeLists.txt | Diff File | ||
| rm - src/Gui/DlgTipOfTheDay.ui | Diff File | ||
| rm - src/Gui/DlgTipOfTheDayImp.cpp | Diff File | ||
| rm - src/Gui/DlgTipOfTheDayImp.h | Diff File | ||
| rm - src/Gui/DownloadDialog.cpp | Diff File | ||
| rm - src/Gui/DownloadDialog.h | Diff File | ||
| rm - src/Gui/HelpView.cpp | Diff File | ||
| rm - src/Gui/HelpView.h | Diff File | ||
| mod - src/Mod/Web/Gui/BrowserView.cpp | Diff File | ||
FreeCAD: master d2cb4e4a 2016-12-12 14:52:09 Details Diff |
Qt4/Qt5 neutral changes: + remove QCoreApplication::UnicodeUTF8/QApplication::UnicodeUTF8 + remove QCoreApplication::CodecForTr/QApplication::CodecForTr |
FreeCAD: master 07943d2a 2016-12-12 15:22:34 Details Diff |
Qt4/Qt5 neutral changes: + move meta types to own header to avoid double declaration |
| mod - src/Gui/InputField.h | Diff File | ||
| add - src/Gui/MetaTypes.h | Diff File | ||
| mod - src/Gui/QuantitySpinBox.h | Diff File | ||
| mod - src/Gui/propertyeditor/PropertyItem.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/PropertyConstraintListItem.cpp | Diff File | ||
FreeCAD: master 4933e17a 2016-12-12 15:31:35 Details Diff |
Qt4/Qt5 neutral changes: + re-implement built-in HTTP server without using in Qt5 removed classes QHttpResponseHeader and QHttpRequestHeader |
| mod - src/Gui/OnlineDocumentation.h | Diff File | ||
FreeCAD: master ad7234ff 2016-12-12 16:28:28 Details Diff |
Qt4/Qt5 neutral changes: + add missing header files/remove old headers + fix flaws in use of timer |
| mod - src/Gui/Qt4All.h | Diff File | ||
FreeCAD: master b2487828 2016-12-12 17:01:26 Details Diff |
Qt4/Qt5 neutral changes: + change inheritance of PropertyItem to not derive from BaseClass (and QObject) any more to fix crashes with Qt5 |
| mod - src/Mod/Fem/Gui/PropertyFemMeshItem.cpp | Diff File | ||
| mod - src/Mod/Fem/Gui/PropertyFemMeshItem.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/PropertyEditorMesh.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/PropertyEditorMesh.h | Diff File | ||
| mod - src/Mod/Sketcher/Gui/PropertyConstraintListItem.h | Diff File | ||
FreeCAD: master 57e71e5d 2016-12-13 14:22:59 Details Diff |
port C++ code to Qt5 |
| mod - src/Gui/DocumentRecovery.cpp | Diff File | ||
| mod - src/Gui/DownloadManager.cpp | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/SheetTableView.h | Diff File | ||
| mod - src/Mod/TechDraw/Gui/TemplateTextField.cpp | Diff File | ||
FreeCAD: master 5e375a62 2016-12-13 15:53:13 Details Diff |
Add switch to select between Qt4 and Qt5 |
| mod - CMakeLists.txt | Diff File | ||
| mod - src/App/CMakeLists.txt | Diff File | ||
| mod - src/Base/CMakeLists.txt | Diff File | ||
| mod - src/Main/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Complete/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Drawing/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Fem/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Image/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Inspection/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Mesh/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Mesh/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/MeshPart/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Part/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/PartDesign/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Path/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Points/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Raytracing/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/ReverseEngineering/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Robot/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Sketcher/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Spreadsheet/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Start/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/TechDraw/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Test/Gui/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Web/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Web/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Web/Gui/CMakeLists.txt | Diff File | ||
FreeCAD: master 87f28668 2016-12-13 19:47:32 Details Diff |
Linux specific Qt5 port |
FreeCAD: master e5c6bf5b 2016-12-14 09:37:35 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000378 from wwmayer/qt5_port Qt5 port |
| mod - src/Tools/_TEMPLATE_/Gui/CMakeLists.txt | Diff File | ||
FreeCAD: master 92db556a 2016-12-15 13:33:33 Details Diff |
do not use Qt4 macros for Qt5 version of fc_wrap_cpp |
FreeCAD: master fd1c42b3 2016-12-23 10:38:27 Details Diff |
port use of tcp server to Qt5 |
| mod - src/Mod/Web/App/Server.cpp | Diff File | ||
| mod - src/Mod/Web/App/Server.h | Diff File | ||
FreeCAD: master de9aa486 2016-12-23 12:16:58 Details Diff |
Qt4/Qt5 neutral changes: connect to commitDataRequest signal for session management |
| mod - src/Gui/GuiApplication.cpp | Diff File | ||
| mod - src/Gui/GuiApplication.h | Diff File | ||
FreeCAD: master d3ff5171 2016-12-23 14:13:43 Details Diff |
check between Qt4/Qt5 build in cmake |
| mod - src/Mod/Sandbox/Gui/CMakeLists.txt | Diff File | ||
FreeCAD: master cb1ef116 2016-12-23 14:14:46 Details Diff |
make some Qt5 specific changes for session management |
FreeCAD: master 0c3f5230 2016-12-24 15:32:12 Details Diff |
switch to PySide2 for Qt5 |
| mod - src/Gui/ApplicationPy.cpp | Diff File | ||
| mod - src/Gui/ViewProviderPyImp.cpp | Diff File | ||
| mod - src/Gui/ViewProviderPythonFeature.cpp | Diff File | ||
| mod - src/Gui/WidgetFactory.h | Diff File | ||
FreeCAD: master d74e2d5a 2016-12-25 01:16:26 Committer: wmayer Details Diff |
Use PySide2 tools for Qt5 build. |
FreeCAD: master bed8ff74 2016-12-25 02:21:31 Details Diff |
Fix crash in Gui::FileOptionsDialog while using Qt5. |
FreeCAD: master 3bf2cba5 2016-12-25 10:49:40 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000395 from f3nix/qt5-fixes-1 Fix crash in Gui::FileOptionsDialog while using Qt5. |
FreeCAD: master bf94b191 2016-12-26 21:49:31 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000399 from f3nix/qt5-fixes-2 Fix building with Qt < 5.5. |
FreeCAD: master 524ee4a6 2017-01-05 14:24:03 Details Diff |
fix Qt5 port of messageHandler |
FreeCAD: master 5b5189a8 2017-01-16 00:09:39 Details Diff |
workaround for running graphviz under Qt5 |
FreeCAD: master 7f884e8b 2017-01-16 01:24:39 Committer: wmayer Details Diff |
Qt5: cmake install dependencies on macOS * Define QT_PLUGINS_DIR when building Qt5 on macOS * Add Xcode XCTest search path |
| mod - src/MacAppBundle/CMakeLists.txt | Diff File | ||
FreeCAD: master 2ab9ef93 2017-02-08 11:45:16 Details Diff |
Qt4/Qt5 neutral changes fix interface of slot functions in DlgSettingsEditorImp to avoid warnings with Qt5 |
| mod - src/Gui/DlgEditorImp.h | Diff File | ||
FreeCAD: master d7541bcd 2017-02-12 04:46:07 Details Diff |
QStyleOptionViewItemV4 is deprecated in Qt5. Replace it with QStyleOptionViewItem. |
| mod - src/Gui/DAGView/DAGRectItem.cpp | Diff File | ||
FreeCAD: master ec008939 2017-02-12 18:01:27 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000519 from f3nix/qt5-warnings-1 Fix some Qt5 build warnings |
FreeCAD: master 5084b967 2017-02-26 02:36:27 Committer: wmayer Details Diff |
Qt5: build FreeCAD for macOS with both Qt5 and Qt4 * Extend Travis config to build and deploy FreeCAD on macOS with Qt5, in addition to Qt4 * Link PySide wrapper to <bundle>/MacOS * Warn on install_name_tool failures (work-around to confirmed Apple install_name_tool bug) * Reference XCTest "Current" framework versus "A" |
| mod - .travis.yml | Diff File | ||
| add - src/MacAppBundle/FreeCAD.app/Contents/MacOS/PySide | Diff File | ||
| mod - src/Tools/MakeMacBundleRelocatable.py | Diff File | ||
FreeCAD: master 61658e60 2017-03-02 18:16:05 Committer: yorik Details Diff |
Qt5: Enabled HiDPI scaling and Use HiDPI Qt Pixmaps * Enable HiDPI scaling on displays that support it on Qt 5.6 and later * Enable HiDPI Pixmaps on Qt 5.1 and later |
FreeCAD: master 8f5c7b44 2017-03-04 18:37:24 Committer: GitHub Details Diff |
Use new FreeCAD/freecad homebrew formula API for Qt4 & Qt5 (0000590) |
FreeCAD: master 27d76f3a 2017-03-10 18:54:29 wmayer Details Diff |
Qt5OpenGL: port Image rendering mode to make box zoom & selection and cutting work again |
FreeCAD: master 749ace7e 2017-03-11 13:35:19 wmayer Details Diff |
Qt5OpenGL: Framebufferobject rendering works and handles transparency and anti-aliasing |
FreeCAD: master b0cd0a51 2017-03-11 15:28:26 wmayer Details Diff |
Qt5OpenGL: release context when finished |
| mod - src/Gui/GLPainter.cpp | Diff File | ||
FreeCAD: master 6638ff90 2017-03-11 15:29:13 wmayer Details Diff |
Qt5OpenGL: do not use pixel buffer for the moment |
| mod - src/Gui/View3DPy.cpp | Diff File | ||
FreeCAD: master f04badda 2017-03-11 17:23:26 wmayer Details Diff |
Qt5OpenGL: at startup determine some basic information about OpenGL setup |
FreeCAD: master 5bf326c1 2017-03-12 11:27:20 wmayer Details Diff |
Qt5OpenGL: fix creating thumbnals, pdf, print preview and snapshot |
Affected Issues 0002952, 0002986 |
FreeCAD: master ed33adc3 2017-03-12 17:22:36 wmayer Details Diff |
Qt5OpenGL: make off-screen renderer working |
| mod - src/Gui/SoFCOffscreenRenderer.h | Diff File | ||
FreeCAD: master e1c5597a 2017-03-12 18:08:38 wmayer Details Diff |
Qt5OpenGL: implement grabFramebuffer |
FreeCAD: master 2c6f1fd5 2017-03-12 21:34:00 wmayer Details Diff |
Qt5OpenGL: fix transparency issue with framebuffer objects with old OpenGL API |
FreeCAD: master 3ac834c7 2017-03-13 23:02:37 wmayer Details Diff |
Qt5OpenGL: use OpenGL debug logger to locate problems, fix a couple of errors |
| mod - src/Gui/Flag.cpp | Diff File | ||
| mod - src/Mod/Image/Gui/OpenGLImageBox.cpp | Diff File | ||
FreeCAD: master 0568209a 2017-03-15 13:17:24 wmayer Details Diff |
Qt5OpenGL: add OpenGL debug logger (deactivated) |
FreeCAD: master 2ba7d8e6 2017-03-15 13:18:53 wmayer Details Diff |
Qt5OpenGL: update flags when dragging or removing |
FreeCAD: master 2ec2ea5a 2017-03-15 16:28:45 wmayer Details Diff |
Qt5OpenGL: fix flickering on resize |
FreeCAD: master 08a901a0 2017-03-21 12:09:56 wmayer Details Diff |
Qt5OpenGL: fix to make the 3d viewer fit into the mdi area after re-docking it |
FreeCAD: master c193dbe2 2017-03-21 16:36:53 wmayer Details Diff |
enable FREECAD_USE_QTOPENGL_WIDGET by default for Qt5, fixes 0002952, fixes 0001401 |
Affected Issues 0001401, 0002942, 0002952, 0002953, 0002986 |
FreeCAD: master 3da36c16 2017-03-21 16:41:22 wmayer Details Diff |
Qt5OpenGL: add missing header for macOS/Linux builds |
FreeCAD: master 4d9169fa 2017-03-21 16:50:21 Details Diff |
FreeCAD: master e96390e4 2017-03-24 09:28:57 Details Diff |
Qt5OpenGL: replace gluOrtho2D for macOS, move includes of GL stuff from header to source |
| mod - src/Gui/SoFCUnifiedSelection.h | Diff File | ||
FreeCAD: master e006178f 2017-03-24 13:07:32 wwmayer Committer: GitHub Details Diff |
Merge pull request 0000648 from wwmayer/fix_warnings Qt5OpenGL: replace gluOrtho2D for macOS |
FreeCAD: master c5b7c987 2017-03-26 07:58:35 Committer: wmayer Details Diff |
Fix building with GCC and Qt5. issue 0002986 |
| mod - src/Mod/Path/App/CMakeLists.txt | Diff File | ||
FreeCAD: master 6368b2f8 2017-04-26 02:11:34 Ian Rees Details Diff |
TechDraw: Tidy, and fix Qt5 template text edition |
| mod - src/Mod/TechDraw/Gui/DlgTemplateField.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/DlgTemplateField.h | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGISVGTemplate.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGISVGTemplate.h | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGVPage.cpp | Diff File | ||
| mod - src/Mod/TechDraw/Gui/QGVPage.h | Diff File | ||
| mod - src/Mod/TechDraw/Gui/TemplateTextField.h | Diff File | ||
FreeCAD: master d02a34c0 2017-05-01 16:53:58 Details Diff |
Qt5 port: workaround to keep multi-sampling when undocking mdi window |
| mod - src/Gui/Quarter/QuarterWidgetP.h | Diff File | ||
FreeCAD: master 378a1e4f 2017-05-03 20:01:46 Details Diff |
Qt5: workaround for undocking of mdi view fix minor issues reported by clang static analyzer |
| mod - src/Gui/Document.h | Diff File | ||
FreeCAD: master 6bdc3eb2 2017-05-20 14:21:30 wmayer Details Diff |
workaround for broken tree indicators with Qt 5.6 under Windows |
| mod - src/Gui/Icons/resource.qrc | Diff File | ||
| add - src/Gui/Icons/style/windows_branch_closed.png | Diff File | ||
| add - src/Gui/Icons/style/windows_branch_open.png | Diff File | ||
FreeCAD: master 1ec3e5da 2017-05-21 03:02:26 wmayer Details Diff |
FreeCAD: master e6b9ec5d 2017-07-15 10:50:55 wmayer Details Diff |
Qt5 port: make Sandbox module compile with Qt5 |
| 2017-03-27 17:21 | Kunda1 | New Issue | |
| 2017-03-27 17:21 | Kunda1 | Tag Attached: Qt | |
| 2017-03-27 17:21 | Kunda1 | Tag Attached: Qt5 | |
| 2017-03-27 17:22 | Kunda1 | Changeset attached | => FreeCAD master e006178f |
| 2017-03-27 17:22 | Kunda1 | Changeset attached | => FreeCAD master e96390e4 |
| 2017-03-27 17:22 | Kunda1 | Changeset attached | => FreeCAD master 4d9169fa |
| 2017-03-27 17:22 | Kunda1 | Changeset attached | => FreeCAD master 3da36c16 |
| 2017-03-27 17:23 | Kunda1 | Changeset attached | => FreeCAD master c193dbe2 |
| 2017-03-27 17:23 | Kunda1 | Changeset attached | => FreeCAD master 08a901a0 |
| 2017-03-27 17:23 | Kunda1 | Changeset attached | => FreeCAD master 2ec2ea5a |
| 2017-03-27 17:23 | Kunda1 | Changeset attached | => FreeCAD master 2ba7d8e6 |
| 2017-03-27 17:23 | Kunda1 | Changeset attached | => FreeCAD master 0568209a |
| 2017-03-27 17:23 | Kunda1 | Changeset attached | => FreeCAD master 3ac834c7 |
| 2017-03-27 17:24 | Kunda1 | Changeset attached | => FreeCAD master 2c6f1fd5 |
| 2017-03-27 17:24 | Kunda1 | Changeset attached | => FreeCAD master e1c5597a |
| 2017-03-27 17:24 | Kunda1 | Changeset attached | => FreeCAD master ed33adc3 |
| 2017-03-27 17:24 | Kunda1 | Changeset attached | => FreeCAD master 5bf326c1 |
| 2017-03-27 17:25 | Kunda1 | Relationship added | parent of 0002952 |
| 2017-03-27 17:26 | Kunda1 | Relationship added | parent of 0001401 |
| 2017-03-27 17:26 | Kunda1 | Relationship added | parent of 0002868 |
| 2017-03-27 17:27 | Kunda1 | Relationship added | parent of 0002953 |
| 2017-03-27 17:29 | Kunda1 | Changeset attached | => FreeCAD master f04badda |
| 2017-03-27 17:29 | Kunda1 | Relationship added | parent of 0002942 |
| 2017-03-27 17:30 | Kunda1 | Relationship added | parent of 0001867 |
| 2017-03-27 17:31 | Kunda1 | Changeset attached | => FreeCAD master 6638ff90 |
| 2017-03-27 17:32 | Kunda1 | Changeset attached | => FreeCAD master b0cd0a51 |
| 2017-03-27 17:32 | Kunda1 | Changeset attached | => FreeCAD master 749ace7e |
| 2017-03-27 17:32 | Kunda1 | Changeset attached | => FreeCAD master 27d76f3a |
| 2017-03-27 17:32 | Kunda1 | Changeset attached | => FreeCAD master 8f5c7b44 |
| 2017-03-27 17:32 | Kunda1 | Changeset attached | => FreeCAD master 61658e60 |
| 2017-03-27 17:32 | Kunda1 | Changeset attached | => FreeCAD master 5084b967 |
| 2017-03-27 17:33 | Kunda1 | Changeset attached | => FreeCAD master ec008939 |
| 2017-03-27 17:33 | Kunda1 | Changeset attached | => FreeCAD master d7541bcd |
| 2017-03-27 17:33 | Kunda1 | Changeset attached | => FreeCAD master 2ab9ef93 |
| 2017-03-27 17:34 | Kunda1 | Changeset attached | => FreeCAD master 7f884e8b |
| 2017-03-27 17:34 | Kunda1 | Changeset attached | => FreeCAD master 5b5189a8 |
| 2017-03-27 17:34 | Kunda1 | Changeset attached | => FreeCAD master 524ee4a6 |
| 2017-03-27 17:34 | Kunda1 | Changeset attached | => FreeCAD master bf94b191 |
| 2017-03-27 17:34 | Kunda1 | Changeset attached | => FreeCAD master 3bf2cba5 |
| 2017-03-27 17:35 | Kunda1 | Changeset attached | => FreeCAD master bed8ff74 |
| 2017-03-27 17:35 | Kunda1 | Changeset attached | => FreeCAD master d74e2d5a |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master 0c3f5230 |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master cb1ef116 |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master d3ff5171 |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master de9aa486 |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master fd1c42b3 |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master 92db556a |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master e5c6bf5b |
| 2017-03-27 17:36 | Kunda1 | Changeset attached | => FreeCAD master 87f28668 |
| 2017-03-27 17:37 | Kunda1 | Changeset attached | => FreeCAD master 5e375a62 |
| 2017-03-27 17:37 | Kunda1 | Changeset attached | => FreeCAD master 57e71e5d |
| 2017-03-27 17:37 | Kunda1 | Changeset attached | => FreeCAD master b2487828 |
| 2017-03-27 17:37 | Kunda1 | Changeset attached | => FreeCAD master ad7234ff |
| 2017-03-27 17:37 | Kunda1 | Changeset attached | => FreeCAD master 4933e17a |
| 2017-03-27 17:38 | Kunda1 | Changeset attached | => FreeCAD master 07943d2a |
| 2017-03-27 17:38 | Kunda1 | Changeset attached | => FreeCAD master d2cb4e4a |
| 2017-03-27 17:38 | Kunda1 | Changeset attached | => FreeCAD master 57e7d3ad |
| 2017-03-27 17:38 | Kunda1 | Changeset attached | => FreeCAD master 1cdee209 |
| 2017-03-27 17:38 | Kunda1 | Changeset attached | => FreeCAD master 7e018146 |
| 2017-03-27 17:40 | Kunda1 | Changeset attached | => FreeCAD master 8c6bede7 |
| 2017-03-27 17:40 | Kunda1 | Changeset attached | => FreeCAD master 8b2f435c |
| 2017-03-27 17:40 | Kunda1 | Changeset attached | => FreeCAD master 2c79424f |
| 2017-03-27 17:40 | Kunda1 | Changeset attached | => FreeCAD master c50bc176 |
| 2017-03-27 17:40 | Kunda1 | Changeset attached | => FreeCAD master f188995e |
| 2017-03-27 17:40 | Kunda1 | Changeset attached | => FreeCAD master 80e8ae63 |
| 2017-03-27 17:41 | Kunda1 | Changeset attached | => FreeCAD master 81b59324 |
| 2017-03-27 17:41 | Kunda1 | Changeset attached | => FreeCAD master b5519922 |
| 2017-03-27 17:41 | Kunda1 | Changeset attached | => FreeCAD master 3df6064e |
| 2017-03-27 17:41 | Kunda1 | Changeset attached | => FreeCAD master d9b7a5fb |
| 2017-03-27 17:41 | Kunda1 | Changeset attached | => FreeCAD master 657ac1f5 |
| 2017-03-27 17:41 | Kunda1 | Changeset attached | => FreeCAD master 3f3d8a95 |
| 2017-03-27 17:42 | Kunda1 | Changeset attached | => FreeCAD master e1f3fe1b |
| 2017-03-27 17:42 | Kunda1 | Changeset attached | => FreeCAD master 31fd2d17 |
| 2017-03-27 17:42 | Kunda1 | Changeset attached | => FreeCAD master 8de9436c |
| 2017-03-27 17:42 | Kunda1 | Changeset attached | => FreeCAD master 69c241ba |
| 2017-03-27 17:42 | Kunda1 | Changeset attached | => FreeCAD master 4ef8c970 |
| 2017-03-27 17:42 | Kunda1 | Changeset attached | => FreeCAD master db345cb6 |
| 2017-03-27 17:43 | Kunda1 | Changeset attached | => FreeCAD master 5be29861 |
| 2017-03-27 17:43 | Kunda1 | Changeset attached | => FreeCAD master 62ccb845 |
| 2017-03-27 17:43 | Kunda1 | Changeset attached | => FreeCAD master 0aa944a1 |
| 2017-03-27 17:43 | Kunda1 | Changeset attached | => FreeCAD master ab262717 |
| 2017-03-27 17:43 | Kunda1 | Changeset attached | => FreeCAD master 9aa3cfb4 |
| 2017-03-27 17:44 | Kunda1 | Changeset attached | => FreeCAD master c2a31fe0 |
| 2017-03-27 17:44 | Kunda1 | Changeset attached | => FreeCAD master 9beb7d21 |
| 2017-03-27 17:45 | Kunda1 | Changeset attached | => FreeCAD master 99ca18f5 |
| 2017-03-27 17:45 | Kunda1 | Changeset attached | => FreeCAD master 7d0e892d |
| 2017-03-27 17:45 | Kunda1 | Changeset attached | => FreeCAD master e6379ea6 |
| 2017-03-27 17:46 | Kunda1 | Changeset attached | => FreeCAD master d3d01db9 |
| 2017-03-27 17:46 | Kunda1 | Changeset attached | => FreeCAD master 4d85f0e4 |
| 2017-03-27 17:46 | Kunda1 | Changeset attached | => FreeCAD master f7b8135d |
| 2017-03-27 17:46 | Kunda1 | Changeset attached | => FreeCAD master 3b463f21 |
| 2017-03-27 17:46 | Kunda1 | Changeset attached | => FreeCAD master cd2db00f |
| 2017-03-27 17:46 | Kunda1 | Changeset attached | => FreeCAD master d5c074f8 |
| 2017-03-27 18:02 | Kunda1 | Summary | Port from Qt4 to Qt5 => Port from Qt4 to Qt5 (Ongoing) |
| 2017-03-28 07:57 | wmayer | Changeset attached | => FreeCAD master c5b7c987 |
| 2017-03-28 17:10 | Kunda1 | Status | new => confirmed |
| 2017-04-25 12:41 | Kunda1 | Note Added: 0008755 | |
| 2017-04-26 00:10 | Kunda1 | Sticky Issue | No => Yes |
| 2017-05-01 17:55 | Kunda1 | Changeset attached | => FreeCAD master d02a34c0 |
| 2017-05-01 18:04 | Kunda1 | Changeset attached | => FreeCAD master 6368b2f8 |
| 2017-05-04 06:26 | Kunda1 | Changeset attached | => FreeCAD master 378a1e4f |
| 2017-05-22 12:29 | Kunda1 | Changeset attached | => FreeCAD master 1ec3e5da |
| 2017-05-22 12:29 | Kunda1 | Changeset attached | => FreeCAD master 6bdc3eb2 |
| 2017-07-17 23:20 | Kunda1 | Relationship added | parent of 0003130 |
| 2017-07-18 16:04 | Kunda1 | Changeset attached | => FreeCAD master e6b9ec5d |
| 2017-11-26 22:18 | wmayer | Target Version | 0.17 => 0.18 |
| 2018-03-20 13:13 | Kunda1 | Priority | normal => high |
| 2018-03-20 13:13 | Kunda1 | Severity | minor => major |
| 2018-10-05 23:54 | Kunda1 | Relationship added | parent of 0003522 |
| 2019-01-16 16:36 | Kunda1 | Relationship added | parent of 0003774 |
| 2019-05-09 01:08 | yorik | Note Added: 0013085 | |
| 2019-05-09 01:08 | yorik | Assigned To | => wmayer |
| 2019-05-09 01:08 | yorik | Status | confirmed => closed |
| 2019-05-09 01:08 | yorik | Resolution | open => fixed |
