| 0003365 | Arch | Bug | public | 2018-03-09 22:26 | 2019-01-18 13:50 |
| Reporter | zbigg | Assigned To | yorik | ||
| Summary | 0003365: Shift+B box selection DOES NOT deletes text nor dimension guide/helplines | ||||
| Description | as above | ||||
| Steps To Reproduce | https://www.freecadweb.org/wiki/Arch_tutorial After importing DWG try to remove unwanted parts of the drawing with SHIFT+B | ||||
| Additional Information | OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13381 (Git) Build type: Release Branch: master Hash: d95656d812f56da945f0624d8d4c70412ae17460 Python version: 3.6.4 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.2.0 Locale: Polish/Poland (pl_PL) | ||||
The Box selection tool only "sees" Geom Features, which the Annotation object is not. Geom Features have a bound box, which is required by the box seleciton tool to work. So the annotation object should be turned into a geom feature, and its bound box calculated. But beter do that after the release... |
https://github.com/FreeCAD/FreeCAD/commit/de5390456322afc5fc177a0544675355a6cb8664 The idea is not to change the type of an object but rather change the box selection. Instead of retrieving the bounding box of the geometry one can also compute a bounding box by applying an SoGetBoundingBoxAction on the Inventor sub-graph of a view provider. |
| 2018-03-09 22:26 | zbigg | New Issue | |
| 2018-03-09 22:26 | zbigg | Tag Attached: arch box selection text delete | |
| 2018-03-10 01:39 | Kunda1 | Tag Detached: arch box selection text delete | |
| 2018-03-10 21:37 | yorik | Note Added: 0011034 | |
| 2018-03-10 21:37 | yorik | Assigned To | => yorik |
| 2018-03-10 21:37 | yorik | Status | new => assigned |
| 2018-03-12 09:38 | wmayer | Relationship added | duplicate of 0002706 |
| 2018-12-05 13:08 | yorik | Target Version | => 0.19 |
| 2019-01-18 13:50 | wmayer | Target Version | 0.19 => 0.18 |
| 2019-01-18 13:50 | wmayer | Note Added: 0012459 | |
| 2019-01-18 13:50 | wmayer | Status | assigned => closed |
| 2019-01-18 13:50 | wmayer | Resolution | open => duplicate |
| 2019-01-18 13:50 | wmayer | Fixed in Version | => 0.18 |
